BBM solid or hydraulic roller cams on the street questi #1345223
12/03/12 12:23 AM
12/03/12 12:23 AM
Hanover, Ontario, Canada
Moparmatty Offline OP
I've been getting some information lately that running roller cams on the street in our beloved Mopars is bad news. Ive been hearing stories of the distributor gears burning up rather quickly.
I want to run a hydraulic roller in a 500" motor. I also want to be able to drive it 2000 miles at a time if I choose to do so.
Is the burning up of distributor gears an actual problem that exists? If so, what's the fix?
GM and Ford small blocks have been running rollers for years from the factory with out issue.
Matt Tebbutt
Ontario, Canada
Re: BBM solid or hydraulic roller cams on the street questi [Re: Moparmatty] #1345224
12/03/12 01:29 AM
12/03/12 01:29 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
FWIW, I built a 496 stroker with a solid roller cam w/ MP bronze oil pump drive gear for my buddies 70 challenger. He has put quite a few miles on it on the street over the last 5 years. I too have heard stories about them not lasting so, I pulled the oil pump drive gear to inspect it recently. It had little to no wear on it. Looked good enough to me, so I stuck it back in. The timing has stayed put and no bronze has been found in the oil filters.
I wouldn't worry about it if I were you.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: BBM solid or hydraulic roller cams on the street questi [Re: Moparmatty] #1345225
12/03/12 04:50 AM
12/03/12 04:50 AM
Cab_Burge Online work
Cab_Burge  Online Work
I heard the same urban myth years ago. I called Crane Cams to order two piece BB Mopar roller cam, stock front distributor drive welded onto a steel core, and they ask me why I wanted one, I siad for the street. The rep siad that they had a employee that had a Roadrunner with a big inch Indy motor in it that had been on the Hot Rod tour multiple yeas as well as the One Lap Around America, I assumed it was a advertisement for the company, and it had around 77,000 mile ssn the original bronze distributor drive with no porblems at that time. My 518 C.I. pump gas Duster has going on five years of street(under 2000 miles total) and strip use on its gear and still looks new The other alternative is a composite gear
Re: BBM solid or hydraulic roller cams on the street questi [Re: Moparmatty] #1345226
12/03/12 09:52 AM
12/03/12 09:52 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I'm running a locking collar on the distributor shaft to keep the bronze gear from climbing up the cam gear. It stabilized the contact interface and decreased the wear on it. It helped stabilize my timing too.
About 1500 miles on the motor and it still looks good. If I have to change it again, I will have the next one cryogenically treated too.
Re: BBM solid or hydraulic roller cams on the street questi [Re: jbc426] #1345227
12/03/12 07:23 PM
12/03/12 07:23 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
How does the locking collar (I use two on my dist drive) help the oil pump/dist grive gear from climbing cam gear when the dist drive is fully seated against the oil pump/dist drive gear?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: BBM solid or hydraulic roller cams on the street questi [Re: Von] #1345228
12/03/12 08:45 PM
12/03/12 08:45 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
The first few hours I ran my motor without the collars on the distributor shaft.
I could clearly see that the wear marks on the gear were bigger on the gear teeth than they should be with the gear all the way seated on the bushing. The only way the cam gear could make such long wear patterns on the gear, was if the gear was moving up off the bushing while the motor was running, causing the longer contact marks.
Once I installed the collars(I run two as well), there was no more free play. The bronze gear stayed down on the bushing in the block, and the wear pattern of the gear became smaller/shorter.
Re: BBM solid or hydraulic roller cams on the street questi [Re: jbc426] #1345229
12/03/12 10:32 PM
12/03/12 10:32 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
Does anyone want to explain WHY this happens? What's different about a roller cam setup that causes this interaction?
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: BBM solid or hydraulic roller cams on the street questi [Re: VincentVega] #1345230
12/04/12 01:08 AM
12/04/12 01:08 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I think they all do it to some degree, and that's part of the reason the timing jumps around without the collars on. The gear floats up and down as it spins within the up & down freeplay. That changes timing slightly.
Once you tighten it up using the collars on the distributor shaft, the free play is reduced and the gear has to spin within the reduced freeplay. It has less up and down motion because the collars restrict that motion.
The steel gears just handle abuse and wear better.
I wonder if anyone has tried cryogenically treating the bronze gears and seen what the results are.
Re: BBM solid or hydraulic roller cams on the street questi [Re: jbc426] #1345231
12/04/12 10:49 AM
12/04/12 10:49 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Crane cams has developed a gear that is compatible with a roller that isn't bronze. I don't remember exact material right now, it's a little early yet.
Re: BBM solid or hydraulic roller cams on the street questi [Re: Skeptic] #1345232
12/04/12 11:02 AM
12/04/12 11:02 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
hughes sells a coated gear going by the PN may be crane.
http://www.hughesengines.com/Index/produ...mp;partid=26734
Re: BBM solid or hydraulic roller cams on the street questi [Re: Dodgem] #1345233
12/04/12 10:50 PM
12/04/12 10:50 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
I have a solid roller cam in my 440 and the timing does not jump around and I do not use a collar, motor has appox 2500 miles on it.
Re: BBM solid or hydraulic roller cams on the street questi [Re: Moparmatty] #1345234
12/04/12 11:46 PM
12/04/12 11:46 PM
NEW HAMPSHIRE AND MAINE
BIGSTROKER Offline
BIGSTROKER  Offline
i have a solid roller in my 500 inch motor
12000 street miles no problems at all
bronze gear with the collar
crane ultra pro rollers $800
Re: BBM solid or hydraulic roller cams on the street questi [Re: Darryls-Demon] #1345235
12/04/12 11:55 PM
12/04/12 11:55 PM
IN
ahy Offline
ahy  Offline
IN
I went the solid FT route. I've got about 10k miles on an aggressive MM lobe cam without difficulty. I like the benefits of roller but don't care for the bronze gear wear. I understand the collar helps, a standard volume oil pump helps (hope you don't need high volume for hot idle OP on the street), running light oil helps. Still its a wear item while the steel gear is reliably good for the life of the engine and isn't bothered by a high volume pump. Plus roller is expensive.
