70 RT/SE Challenger Overhead Console #1342886
11/29/12 11:46 AM
11/29/12 11:46 AM
Oklahoma City, OK. USA
Dr. Red Offline OP
Dr. Red  Offline OP
Hey guys, I need some help. I am building this 70 Challenger rt/se and I am finally at the interior stage. I ordered just about everything Legendary had for this car. However they did not have a overhead console. I had 2 old original beat up pieces of junk ones though. So I used the original and made a mold then made a new one out of glass. Now my question is this How does it mount in the car?? I cannot for the life of me figure it out! So any help would be greatly received!Pics of hardware, location etc. Also I posted a question about 70 dart hood scoops location
Re: 70 RT/SE Challenger Overhead Console [Re: Dr. Red] #1342887
11/29/12 02:56 PM
11/29/12 02:56 PM
W
wate Offline
wate  Offline
W
overhead headliner board is first secured on the sides with special headliner clips that came on these cars originally. regular h/liner has small rounded metal clips, these are flat and about a 1/2 inch square. don't have one in front of me or I'd send a pic. so you hold the h/liner board up, attach three clips on each side, will hold it up. now I'm assuming you left the special overhead console brackets in the center of the roof and those brackets in the rear that look like saws. those saws are special to these models only, different than regular headliner part. make sure the wiring from the console is coming down correctly. then you'd do the sail panels, then the rear plastic surround. finish with the long metal trim pieces on each side, finally the front pillar moldings. anyway, might not have remembered everything but that's how I've done it.
Re: 70 RT/SE Challenger Overhead Console [Re: wate] #1342888
11/29/12 03:17 PM
11/29/12 03:17 PM
Dr. Red Offline OP
Dr. Red  Offline OP
This is what I have
so how do I attach the console?
Re: 70 RT/SE Challenger Overhead Console [Re: Dr. Red] #1342889
11/29/12 03:38 PM
11/29/12 03:38 PM
W
wate Offline
wate  Offline
W
overhead console has sharp clips on the bottom side, you'll need to measure where the console goes, then make holes in your fiberglass to attach to headliner board. again, don't have one in front of me but the front of the overhead console is pretty close to the front of the h/liner board, maybe an inch back.
first problem I see is that you still have the regular headliner bows installed. you'll need to get rid of them before attempting to install. .also, have ready the screws that attach the rear of the console to the center roof bracket, looks like its in place.
Re: 70 RT/SE Challenger Overhead Console [Re: wate] #1342890
11/29/12 03:47 PM
11/29/12 03:47 PM
W
wate Offline
wate  Offline
W
OK, here's anyother key to this puzzle. you've already got the wiring harness installed. I would remove the wiring and h/liner bows. you need to put the entire assembly of the console, board and wiring in the car as one subassembly. best with a buddy to help. I didn't understand at first that you're all disassembled.
hopefully, another member has some pics.
Re: 70 RT/SE Challenger Overhead Console [Re: wate] #1342891
11/29/12 04:20 PM
11/29/12 04:20 PM
Dr. Red Offline OP
Dr. Red  Offline OP
<b>first problem I see is that you still have the regular headliner bows installed. you'll need to get rid of them before attempting to install.</b>
What do you mean "get rid of" I need them for my headliner from Legendary... You also said that it attaches to the headliner, is that vinyl headliner that strong? Thanks...
Re: 70 RT/SE Challenger Overhead Console [Re: Dr. Red] #1342892
11/29/12 04:30 PM
11/29/12 04:30 PM
NJ
EV2RTSE Offline
EV2RTSE  Offline
NJ
It looks like someone converted your SE headliner back into a standard Challenger headliner. Headliner bows are not used on SE cars, you need one of these:
www.seheadliners.com
Your overhead console attaches to this hardboard headliner and then the whole thing attaches to the roof of the car with the hardware Wate is describing.
Re: 70 RT/SE Challenger Overhead Console [Re: EV2RTSE] #1342893
11/29/12 05:04 PM
11/29/12 05:04 PM
Dr. Red Offline OP
Dr. Red  Offline OP
Well (insert about 27 4 letter words) I guess I will be having a B5 blue REGULAR head liner for sale....What is it with Mopar's and Pink Elephants?
Re: 70 RT/SE Challenger Overhead Console [Re: Dr. Red] #1342894
11/29/12 07:15 PM
11/29/12 07:15 PM
OHIO
faud88 Offline
faud88  Offline
OHIO
Dr. Red,
I've done two R/T SE's now and yes you def. have the standard headliner setup currently. The old headliner boards typically warped badly or crumbled when removed as I expect the same happened to yours. There is a vendor I saw at the Nats this year making the consoles, Headliner boards and sail panels. There advertised on Moparts as a vendor and the website is www.seheadliners.com. The stuff looked really good! No idea of the cost but its the only option other than making your own or find a very expensive used one.
Re: 70 RT/SE Challenger Overhead Console [Re: Dr. Red] #1342895
11/29/12 08:22 PM
11/29/12 08:22 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
That's the fun of them...Not everyone can find and deal with the pink elephant so they buy a camaro or mustang..
Be glad you were'nt at this point a few years ago or you'd really be looking for an original headliner...Not sure what colors are offered on the repops...Anyhow
I hope you measured and glassed in the metal anchors on the backside of the overhead console you made...You need those to slide the clips on... Then the unit secures to the headliner board as others have mentioned here...
Re: 70 RT/SE Challenger Overhead Console [Re: screamindriver] #1342896
11/29/12 08:26 PM
11/29/12 08:26 PM
Dr. Red Offline OP
Dr. Red  Offline OP
Yes I got the "slides" in but both of my originals only had 4 not six as your shows....
Re: 70 RT/SE Challenger Overhead Console [Re: Dr. Red] #1342897
06/14/13 07:31 PM
06/14/13 07:31 PM
Poland
BartekP Offline
BartekP  Offline
Poland
Hi
Anybody has some pictures of Challenger SE sail panels?
how they are mounted?
do I need small wire rods/springs? or these are only for standard headliner?
'70 Challenger SE '77 Dodge M880/W200 '08 Magnum R/T
Re: 70 RT/SE Challenger Overhead Console [Re: BartekP] #1342898
06/15/13 07:00 AM
06/15/13 07:00 AM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
Hi
The 70 SE sail panels just pull off and snap back on via a regular looking door panel clip mounted in the center of the sail panel. If you need a picture, I can get you one later today.
Re: 70 RT/SE Challenger Overhead Console [Re: Suregrip391] #1342899
06/15/13 08:00 AM
06/15/13 08:00 AM
Poland
BartekP Offline
BartekP  Offline
Poland
if you can please take some pictures of the panel itself and its mounting
I do not have it at all and need to make one, is it originally moulded? or just cutted from cardboard?
Re: 70 RT/SE Challenger Overhead Console [Re: BartekP] #1342900
06/15/13 09:26 AM
06/15/13 09:26 AM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
Originals are definitely moulded, I have heard that repops were out and just cardboard. I'll try to attach a pic, if it does not work, send me a PM with your email address.
Re: 70 RT/SE Challenger Overhead Console [Re: Suregrip391] #1342901
06/15/13 09:29 AM
06/15/13 09:29 AM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
I don't know why my posted pics won't show up anymore. Never had a problem till last week..... Might be my iPhone. It shows that the pic was accepted because I did not get alerted it was too large of file,,, dunno
Re: 70 RT/SE Challenger Overhead Console [Re: Suregrip391] #1342902
06/16/13 12:46 AM
06/16/13 12:46 AM
Dr. Red Offline OP
Dr. Red  Offline OP
On the ones I made I just got some of the Cardboard / fibreboard stuff mentioned, then used some box cardboard to make a pattern( with the headliner and rear 1/4 inserts installed) then I wet down the fibreboard and molded it to my pattern and let it dry and tada! cover it with the same stuff you covered your headliner with and your are done. I will post some pics up in a few..
