Re: Rare 1971 Charger H/Lamp Washer Harness Photos Needed
[Re: EL5 71]
#1342537
11/28/12 02:04 PM
11/28/12 02:04 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
This is what I have.. I have some more somewhere and have a complete setup at home... I too had to create that one harness. The factory underdash harness already had the plug and then you have the switch mounted to the dash frame. I just made one and routed it in the most obvious manner that would be out of the way.
This is from my former survivor..
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: autoxcuda]
#1342540
11/29/12 10:37 AM
11/29/12 10:37 AM
hemi68charger
Houston, Tx
I know in the past on Moparts someone posted the differences between a C-body headlight waster system and a B-body system with pictures.
IIRC, it had some great detail and info. Try the Moparts and Moparts Google powered search features.
Anyone remember that thread? And how long ago it was? Hopefully it wasn't in the WIW section and lost forever.
I think I either created that thread or replied to it. I tried in vain for YEARS to find an original harness for the thing ( that one same connector from the switch to the main underdash harness ) and I never did find it, hence me creating one..
[Re: hemi68charger]
#1342541
11/29/12 10:42 PM
11/29/12 10:42 PM
Posts: 562 New York
EL5 71
New York
Well, here's what I created using the 1971 Factory Service Manual diagram to guide me. I had to carefully pick through about 12 underdash wiring harnesses from various Mopar cars I stripped to get the correct Brown wire with the White tracer with a Female Bullitt end on it. What a pain! I have a small photo of an untouched 71 Charger's washer switch still in the car and that had the unique Red 4 terminal plug (but only uses 2 of the terminals). I duplicated this as well because I believe it to be factory original. Now if I could just see the entire harness from a car to get the correct length and part number on the tag, that would be awesome! I believe I have the harness length pretty darn close on the one I made though. Here's a few pics.
[Re: EL5 71]
#1342542
11/29/12 10:43 PM
11/29/12 10:43 PM
Posts: 562 New York
EL5 71
New York
[Re: EL5 71]
#1342543
11/29/12 10:44 PM
11/29/12 10:44 PM
Posts: 562 New York
EL5 71
New York
[Re: EL5 71]
#1342544
11/29/12 10:45 PM
11/29/12 10:45 PM
Posts: 562 New York
EL5 71
New York
[Re: EL5 71]
#1342545
11/29/12 10:46 PM
11/29/12 10:46 PM
Posts: 562 New York
EL5 71
New York
[Re: EL5 71]
#1342546
11/29/12 10:47 PM
11/29/12 10:47 PM
Posts: 562 New York
EL5 71
New York
[Re: billrabe]
#1342550
07/15/13 04:11 PM
07/15/13 04:11 PM
hemi68charger
Houston, Tx
I have a box full of headlamp washer stuff.. Let me pull it out. You are correct, the differences between the B and C body wiper arms are very small.........
Cheers, Troy
[Re: hemi68charger]
#1342551
07/15/13 04:47 PM
07/15/13 04:47 PM
Posts: 562 New York
EL5 71
New York
Here's the Charger specific bottle with riveted mounting bracket. The C Body (Imperial) bottle is identicle except for it does not have the bracket attatched to it.
[Re: EL5 71]
#1342552
07/15/13 04:56 PM
07/15/13 04:56 PM
Posts: 562 New York
EL5 71
New York
[Re: EL5 71]
#1342553
07/15/13 04:59 PM
07/15/13 04:59 PM
Posts: 562 New York
EL5 71
New York
[Re: EL5 71]
#1342554
07/15/13 04:59 PM
07/15/13 04:59 PM
hemi68charger
Houston, Tx
You sure? I had the system in my former '71 Charger R/T and the bottle lined up perfectly with the OEM pre-punched holes on the headlamp bezel it mounted to......... I believe the C-body has the bracket.....
