A-body cowl drainage #134234
10/09/08 12:17 PM
10/09/08 12:17 PM
Detroit area
6PAX Online content OP
6PAX  Online Content OP
Detroit area
Can someone please tell me where the cowl drains at on an A-body, specifically 69/70 Darts?
Re: A-body cowl drainage [Re: 6PAX] #134235
10/09/08 12:30 PM
10/09/08 12:30 PM
Texas
txacres1 Offline
txacres1  Offline
Texas
Water drains out from the ends of the top cowl above the hood hindge area under the fender.
Re: A-body cowl drainage [Re: txacres1] #134236
10/09/08 10:18 PM
10/09/08 10:18 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
yes, two holes on each side near the spring/hinge. The larger hole is rectangular, maybe 3/4" long by 1/4" high, the other is next to it but smaller. Set up a garden hose running into the cowl, and stick a coat hanger up into the drain holes and start fishing around. All kinds of rotting tree debris will flush out eventually. If you are a contortionist (or small), you can stick your hand up in the cowl vents under the dash and fish debris out that way also. Just be very careful for sharp edges on the sheet metal up in there, not intended for fingers to be there.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: A-body cowl drainage [Re: 6PAX] #134237
10/10/08 03:53 AM
10/10/08 03:53 AM
alton, ill
Desoto Offline
Desoto  Offline
alton, ill
a picture of what is being described:
Re: A-body cowl drainage [Re: Desoto] #134238
10/10/08 06:50 AM
10/10/08 06:50 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Great picture!! I forgot about the round hole being there also...
Re: A-body cowl drainage [Re: GO_Fish] #134239
10/10/08 11:10 AM
10/10/08 11:10 AM
Detroit area
Detroit area
Thanks everyone for the info. and E racer for the photo.
