Page 2 of 8 1 2 3 4 5 6 7 8
Re: Change at Indy Cylinder Heads [Re: Mopar Grandpa] #1342035
11/27/12 02:32 PM
11/27/12 02:32 PM
USA
Hooligan Offline
Hooligan  Offline
USA
OK...sorry. I'll have to bite my lip very hard every time I see the word "Indy" from now on, but I wish Indy would "bite me"! Oops! Sorry again!
Re: Change at Indy Cylinder Heads [Re: Hooligan] #1342036
11/27/12 02:43 PM
11/27/12 02:43 PM
Indy
joshking440 Offline OP
Lunch is on me!
Lunch is on me!
Indy
What Happened Sash???
Re: Change at Indy Cylinder Heads [Re: joshking440] #1342037
11/27/12 02:51 PM
11/27/12 02:51 PM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
Josh, I'll throw you and Indy a bone, price and availability on a RB offset distributor?
Thanks,
Mike Gray
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: Change at Indy Cylinder Heads [Re: joshking440] #1342038
11/27/12 02:57 PM
11/27/12 02:57 PM
USA
Hooligan Offline
Hooligan  Offline
USA
Hi Josh, I think it is best that I let go of my anger and move on, because I'll get kicked off of Moparts if I start up again. A total refund of my money would not even make up for what they did and said to me! Their arrogance is unbelievable!
Re: Change at Indy Cylinder Heads [Re: Plumb Wired] #1342039
11/27/12 02:59 PM
11/27/12 02:59 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Thanks,
Mike Gray
I just want to throw Josh the bone.
I just called and ordered a pizza with peperoni
Re: Change at Indy Cylinder Heads [Re: B G Racing] #1342040
11/27/12 03:29 PM
11/27/12 03:29 PM
fresno ca
mikeysmopars Offline
fresno ca
I heard Mitt Romni durned that job down
Hope to see things turn around
Founder and CEO of the Central Valley Mopar Drag Pack
Re: Change at Indy Cylinder Heads [Re: mikeysmopars] #1342041
11/27/12 03:43 PM
11/27/12 03:43 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Good luck Josh. I hope that you can make a positive change.
Lots of organization take on the personality of the figureheads... sometimes that's good, others, not so much...
Re: Change at Indy Cylinder Heads [Re: RobX4406] #1342042
11/27/12 03:49 PM
11/27/12 03:49 PM
gregsdart Offline
gregsdart  Offline
Good luck Josh, it will be nice to have someone from the board that is held in high regard to contact
Re: Change at Indy Cylinder Heads [Re: gregsdart] #1342043
11/27/12 04:25 PM
11/27/12 04:25 PM
ontario canada kingston
aspenrt360 Offline
aspenrt360  Offline
i must be one lucky guy! i bought a set of heads from indy last summer, got them prepped and sent to me on time and for the right price. inspected them once they got here and all was well. it is a real shame if they have had issues because my dealings were good and we need guy's out there with the right products for our stuff! damm it was not so long ago we had almost no choices! good luck with your job make them understand how much more they could sell if they had awesome service it makes a difference!
2013 Chrysler 300 touring 1974 Dodge Charger SE. 360-727-8.75-3.23 sure grip 1972 Dodge Dart Swinger 1995 Dodge Ram 1500 4x4
Re: Change at Indy Cylinder Heads [Re: Hooligan] #1342044
11/27/12 05:21 PM
11/27/12 05:21 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
they riped me off too. i have spent over $40.000 with them. bought direct, so paid full retail. i paid to have my new set of cnc sr,s milled to get the chamber to 65cc. i did not check to see that it was done. checked everthing else thou. bolted them on and took 2 years to find the " problem". when i called them, they told me i was lying. fu*k indy....
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: Change at Indy Cylinder Heads [Re: joshking440] #1342045
11/27/12 05:42 PM
11/27/12 05:42 PM
Texas Afghanistan Iraq etc.
DakFink Offline
DakFink  Offline
Good luck Josh!!
I think you'll be a good asset. God knows they need it.
Long as you and the guy that owns the place get a long and can work together and he lets you be the FACE for them. Then we'll all be in good hands.
FYI: Post on the website any Mopar Pieces that they have available. I know several times they have had stuff that Mopar no longer carries available, BUT you'd never know unless you called and someone just happened to mention it.
Re: Change at Indy Cylinder Heads [Re: DakFink] #1342046
11/27/12 05:58 PM
11/27/12 05:58 PM
sing sing
U
unknown Offline
unknown  Offline
U
sing sing
I will be in the market for a new aluminum Hemi block soon. For 4395.00 the Indy block looks like a good deal, Ill give you a ring when I'm ready.
Re: Change at Indy Cylinder Heads [Re: joshking440] #1342047
11/27/12 07:44 PM
11/27/12 07:44 PM
Delray beach, Florida
P
Performance Only Offline
P
Many have listed customer service as something that needs to be addressed. I would agree with that based on conversations i've had with them in the past. They have had some very polite people over the years as well and that's always a plus. the real problem as i see it from being in the industry is that almost nothing they sell in regards to heads and blocks can be used as delivered. I'm wondering how being polite when a ticked off customer calls is going to help his situation of having to drop a bunch more money to correct what should've been correct when he bought it.
I've worked with a lot of Indy parts over the years, but i've never seen a pair of heads that didn't need work, especially the valve job, or a block that didn't need align-honing on the mains, or more. If i'm ordering the parts in I just let the customer know to expect it, but when a customer orers the same parts they always expect them to be great right out of the box.
Now, with all that being said, i'm only stating my experience. In the end i make money fixing those things so this isn't necesarilly a complaint, just an observation.
Maybe Indy should just sell their parts as semi-finished, that way people know what to expect and wouldn't complain so much. That would sure make it easier for anyone in customer service.
By the way, congratulations on the new job.
machine shop owner and engine builder
Re: Change at Indy Cylinder Heads [Re: Performance Only] #1342048
11/27/12 07:48 PM
11/27/12 07:48 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Dan sums it up nicely!
WIZE
In Car:
Re: Change at Indy Cylinder Heads [Re: Performance Only] #1342049
11/27/12 07:52 PM
11/27/12 07:52 PM
gregsdart Offline
gregsdart  Offline
Very good point!
Re: Change at Indy Cylinder Heads [Re: gregsdart] #1342050
11/27/12 08:00 PM
11/27/12 08:00 PM
Salina ks
572_dup2 Offline
Back On The Bumper!!
572_dup2  Offline
Salina ks
I bought stuff from years ago. It wasnt as advertised had to get a lawyer to get my money back. Best of luck!
Shawn Jennings
Re: Change at Indy Cylinder Heads [Re: 572_dup2] #1342051
11/27/12 08:11 PM
11/27/12 08:11 PM
IL. Jerseyville
jg309 Offline
jg309  Offline
IL. Jerseyville
i needed so block work done, keep getting owner,told him i wanted the shop forman so icould mak arragements to get my block done without trouble & the ass hole said he told them what to do & he'd take care of it,just found someone else so i didn't have to talk to the [Edited by Moparts - Family Friendly Site - Keep it clean] again
Re: Change at Indy Cylinder Heads [Re: jg309] #1342052
11/27/12 08:22 PM
11/27/12 08:22 PM
Washington
skrews Offline
skrews  Offline
Washington
Next time you see Russ, kick him in the nuts for me.
good luck
Re: Change at Indy Cylinder Heads [Re: skrews] #1342053
11/27/12 08:54 PM
11/27/12 08:54 PM
I needed a set of set screws for my indy heads that go under the rockers. $32.95 for freakin set screws which cost 7 cents each.They put a little packet of set screws in a 18 x 18" box and charged me $34.95 for shipping.
And I bypassed Indy and bought them from Mancini Racing and Mancini Racing got them dropped shipped from Indy to boot. What a bunch of crooks.
I'm scared to death to buy anything from them again and I need a Indy Tunnelram badly by Christmas.
Re: Change at Indy Cylinder Heads [Re: joshking440] #1342054
11/27/12 09:50 PM
11/27/12 09:50 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Unless I really had to, I would never drag my good name through the mud to work for such heartless people.
