will a 9x30 on a 10" rim work
#1340680
11/24/12 05:54 PM
11/24/12 05:54 PM
Posts: 635 mississippi
bentwheel43
mississippi
I am thinking of getting 9x30 I can get 8 or 10" rims what would be better.Right now I have 29x10 on 8 1/2 rims,456gear with a 511rb motor,308r cam it gets 1.404 to 1.41 60ft and 6.40s 1/8 mile.~~ bent
Section 8 Racing We are nuts about racing.
Re: will a 9x30 on a 10" rim work
[Re: skrews]
#1340682
11/24/12 07:48 PM
11/24/12 07:48 PM
bentwheel43
mississippi
Well the 8 1/2" that I have now are 4 1/2" bs the 10" will be 5 1/2" bs I will make room for the 30".The 29" is close real close. I will get the 10" I may get 10.5s later.~~bentwheel
[Re: Cab_Burge]
#1340684
11/25/12 12:36 PM
11/25/12 12:36 PM
Posts: 16,506 On the run…
BloFish
On the run…
Are saying you could use a 9x30 tire on a 12" rim?
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: Cab_Burge]
#1340685
11/25/12 12:51 PM
11/25/12 12:51 PM
bentwheel43
mississippi
I hope the 9" hold the car with the 511" it has SD intake,eddy head,850 holley.It will be 50# lighter on the front-a fiberglass hood,mini starter,2 135x15r tires on 4" rims it had 6"rims and tires.The 10"x29 that I have is 91.5" rollout worked good but the 9"x30 rollout is 94" maybe will work better with 456 gear. Dose anyone run in the high 9s on 9" tires.
[Re: bentwheel43]
#1340687
11/25/12 09:41 PM
11/25/12 09:41 PM
Posts: 1,608 Rudolph, Ohio
moparguy7074
Rudolph, Ohio
I don't know about high 9s, but I have a buddy that has a 72 Duster that has SS springs and 28x9 rear slicks, and he just ran a 10.23 at Milan two weeks ago.
[Re: sixpackbee]
#1340690
11/27/12 10:27 AM
11/27/12 10:27 AM
bentwheel43
mississippi
Are they running on 10" rims?
[Re: tboomer]
#1340692
11/27/12 11:31 AM
11/27/12 11:31 AM
bentwheel43
mississippi
The 10"rims sound better and better for 9x30 tires,I think I will try the radials thay are a few different sizes wonder what is the best for a big block?
[Re: bentwheel43]
#1340694
11/27/12 04:14 PM
11/27/12 04:14 PM
Posts: 535 Ohio
racerAL
Ohio
its at least a 10 inch wheel, maybe even 12, like Cab suggested.
-1967 Plymouth Satellite #3555 446 cid on E-85 best 1/4 et 10.577 @ 127.58 best 1/8 et 6.722 @ 100.68 best 60ft. 1.419
[Re: racerAL]
#1340695
11/27/12 04:39 PM
11/27/12 04:39 PM
bentwheel43
mississippi
Thats killer it must be the hold the tire flat is posible.
[Re: racerAL]
#1340696
11/27/12 04:45 PM
11/27/12 04:45 PM
Posts: 535 Ohio
racerAL
Ohio
not low 9's..but here's a pic of my car. im using 30x9 Hoosiers radial slicks and a 10 inch wheel. 3550# 60ft 1.4x's. the radials are great on a well prepped track, not so great on marginal tracks. they were over .10 in et better than my bias-ply slicks,and they are much more stable at the big end. we run around 18.5 lbs of air pressure.
