will a 9x30 on a 10" rim work #1340680
11/24/12 05:54 PM
11/24/12 05:54 PM
mississippi
bentwheel43 Offline OP
mississippi
I am thinking of getting 9x30 I can get 8 or 10" rims what would be better.Right now I have 29x10 on 8 1/2 rims,456gear with a 511rb motor,308r cam it gets 1.404 to 1.41 60ft and 6.40s 1/8 mile.~~ bent
Section 8 Racing We are nuts about racing.
Re: will a 9x30 on a 10" rim work [Re: bentwheel43] #1340681
11/24/12 06:01 PM
11/24/12 06:01 PM
Washington
skrews Offline
skrews  Offline
Washington
10" will work the best. All the stock eliminator guys use 30X9 on 10", thats enough evidence for me. The question is will they fit the wheel openings.
Re: will a 9x30 on a 10" rim work [Re: skrews] #1340682
11/24/12 07:48 PM
11/24/12 07:48 PM
mississippi
mississippi
Well the 8 1/2" that I have now are 4 1/2" bs the 10" will be 5 1/2" bs I will make room for the 30".The 29" is close real close. I will get the 10" I may get 10.5s later.~~bentwheel
Re: will a 9x30 on a 10" rim work [Re: bentwheel43] #1340683
11/25/12 01:11 AM
11/25/12 01:11 AM
I know NHRA stock class racxers that used 8,8.5, 9, 10 ,11 and some used 12 inch wide rims. I liked and used the tens
Re: will a 9x30 on a 10" rim work [Re: Cab_Burge] #1340684
11/25/12 12:36 PM
11/25/12 12:36 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Are saying you could use a 9x30 tire on a 12" rim?
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: will a 9x30 on a 10" rim work [Re: Cab_Burge] #1340685
11/25/12 12:51 PM
11/25/12 12:51 PM
mississippi
mississippi
I hope the 9" hold the car with the 511" it has SD intake,eddy head,850 holley.It will be 50# lighter on the front-a fiberglass hood,mini starter,2 135x15r tires on 4" rims it had 6"rims and tires.The 10"x29 that I have is 91.5" rollout worked good but the 9"x30 rollout is 94" maybe will work better with 456 gear. Dose anyone run in the high 9s on 9" tires.
Re: will a 9x30 on a 10" rim work [Re: BloFish] #1340686
11/25/12 01:45 PM
11/25/12 01:45 PM
Yes Sir
Re: will a 9x30 on a 10" rim work [Re: bentwheel43] #1340687
11/25/12 09:41 PM
11/25/12 09:41 PM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
I don't know about high 9s, but I have a buddy that has a 72 Duster that has SS springs and 28x9 rear slicks, and he just ran a 10.23 at Milan two weeks ago.
Re: will a 9x30 on a 10" rim work [Re: moparguy7074] #1340688
11/25/12 09:54 PM
11/25/12 09:54 PM
mississippi
mississippi
My car mite do better with 4.10 or 3.91 gears,but it mite just need the taller tires.I run 1/8 mile.
Re: will a 9x30 on a 10" rim work [Re: bentwheel43] #1340689
11/25/12 10:04 PM
11/25/12 10:04 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
Almost mid 8's at 160ish. The Cobre Jets are close to 1,000HP too.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: will a 9x30 on a 10" rim work [Re: sixpackbee] #1340690
11/27/12 10:27 AM
11/27/12 10:27 AM
mississippi
mississippi
Are they running on 10" rims?
Re: will a 9x30 on a 10" rim work [Re: bentwheel43] #1340691
11/27/12 10:53 AM
11/27/12 10:53 AM
tboomer Offline
tboomer  Offline
When I won the footbrake championship at my home track in 2006,I was running 9x30 Hoosier radials on a 10" wheel.
Re: will a 9x30 on a 10" rim work [Re: tboomer] #1340692
11/27/12 11:31 AM
11/27/12 11:31 AM
mississippi
mississippi
The 10"rims sound better and better for 9x30 tires,I think I will try the radials thay are a few different sizes wonder what is the best for a big block?
Re: will a 9x30 on a 10" rim work [Re: bentwheel43] #1340693
11/27/12 11:53 AM
11/27/12 11:53 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
2011 Drag Pak Challengers came with 9" x 30" tires on 10" wheels.
Re: will a 9x30 on a 10" rim work [Re: bentwheel43] #1340694
11/27/12 04:14 PM
11/27/12 04:14 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
its at least a 10 inch wheel, maybe even 12, like Cab suggested.
-1967 Plymouth Satellite #3555
446 cid on E-85
best 1/4 et 10.577 @ 127.58
best 1/8 et 6.722 @ 100.68
best 60ft. 1.419
Re: will a 9x30 on a 10" rim work [Re: racerAL] #1340695
11/27/12 04:39 PM
11/27/12 04:39 PM
mississippi
mississippi
Thats killer it must be the hold the tire flat is posible.
Re: will a 9x30 on a 10" rim work [Re: racerAL] #1340696
11/27/12 04:45 PM
11/27/12 04:45 PM
Ohio
racerAL Offline
racerAL  Offline
Ohio
not low 9's..but here's a pic of my car. im using 30x9 Hoosiers radial slicks and a 10 inch wheel. 3550# 60ft 1.4x's. the radials are great on a well prepped track, not so great on marginal tracks. they were over .10 in et better than my bias-ply slicks,and they are much more stable at the big end. we run around 18.5 lbs of air pressure.
446 cid on E-85
best 60ft. 1.419
Re: will a 9x30 on a 10" rim work [Re: racerAL] #1340697
11/27/12 06:36 PM
11/27/12 06:36 PM
mississippi
mississippi
That car is hooking up good.
Re: will a 9x30 on a 10" rim work [Re: bentwheel43] #1340698
11/27/12 07:20 PM
11/27/12 07:20 PM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
racerAL, can you give me more details like are you springs in the stock location? What backspacing on the wheels? Stock wheelwells or minitubs? Thanks!
Re: will a 9x30 on a 10" rim work [Re: 67Satty] #1340699
11/28/12 01:42 AM
11/28/12 01:42 AM
Ohio
racerAL Offline
racerAL  Offline
Ohio
..lets not hi-jack the thread..u got mail.
446 cid on E-85
best 60ft. 1.419
