WTK: torque specs > 426 hemi w/alum intake/alum heads? #1336449
11/17/12 11:36 AM
11/17/12 11:36 AM
Ohio
Cincylance Offline OP
Ohio
Have the intake off my 426 hemi and need to know the torque specs. OEM style alum heads and a newer inline 2x4 MP alum intake. I don't want to crack those beautiful heads! Anyone have an online source for this information?
Cincylance
Re: WTK: torque specs > 426 hemi w/alum intake/alum heads? [Re: Cincylance] #1336450
11/17/12 03:31 PM
11/17/12 03:31 PM
Cincylance
The factory service manual calls for torqueing the inner four bolts to 72 inch lbs. and the outers to 48 inch pounds. I use that on both iron and aluminum heads, carb. intakes and blower manifolds with no problems in a lot of years working on Hemiroid motors I do retorque them sevearl times until they take a hard set, that's when they all stay tight and don't take anymore movement when retorquing Make sure and have flat washers under the head of the 1/4 inch bolts if your not using the original style or replacement intake bolts that have the captive washers on them
Re: WTK: torque specs > 426 hemi w/alum intake/alum heads? [Re: Cab_Burge] #1336451
11/17/12 03:49 PM
11/17/12 03:49 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Mine have always come loose over time. 48 in/lbs. equates to 4 ft/lbs, and 72 in/lbs. is 6 ft./lbs. That is not much torque to keep them from coming loose.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: WTK: torque specs > 426 hemi w/alum intake/alum heads? [Re: DusterDave] #1336452
11/17/12 07:18 PM
11/17/12 07:18 PM
Ohio
Ohio
Thanks, guys. Got it. I'll check and re-torque in a few days.
Cincylance
Re: WTK: torque specs > 426 hemi w/alum intake/alum heads? [Re: Cincylance] #1336453
11/18/12 03:40 PM
11/18/12 03:40 PM
Cincylance
They do need to be checked and retorque regularly , esecially after warming up the motor when the gaskets and bolts are new
Re: WTK: torque specs > 426 hemi w/alum intake/alum heads? [Re: Cincylance] #1336454
11/19/12 12:59 AM
11/19/12 12:59 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I torqued them about 14 times, everytime I went around they would get just a little bit more of a turn. Took about an hour....and that torque is plenty considering there is like 16-20 bolts. Tim
Cincylance
