Need suggestions for a 100+ amp 3 wire alternator #1329829
11/02/12 11:46 AM
11/02/12 11:46 AM
Tampa
DusterDave Offline OP
Tampa
The only 3 wire 100 amp alternator I can find is made by Tuff Stuff. Anyone know of any other company that makes a decent 3 wire 100 amp? I don't want to do another 1 wire alt.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Need suggestions for a 100+ amp 3 wire alternator [Re: DusterDave] #1329830
11/02/12 12:05 PM
11/02/12 12:05 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: Need suggestions for a 100+ amp 3 wire alternator [Re: DusterDave] #1329831
11/02/12 01:17 PM
11/02/12 01:17 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Powermaster?.......
Re: Need suggestions for a 100+ amp 3 wire alternator [Re: DusterDave] #1329832
11/02/12 01:45 PM
11/02/12 01:45 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I got the 120 kit from mancini's its a 3 wire denso man does it char good idle up
http://chucker54.stores.yahoo.net/delialbrpk.html
Mine came with double pully??
changed to a low mount this year
Re: Need suggestions for a 100+ amp 3 wire alternator [Re: DusterDave] #1329833
11/02/12 01:52 PM
11/02/12 01:52 PM
Cab_Burge Online work
Cab_Burge  Online Work
I bought the 100 amp 3 wire Tough Stuff alternator from Summit last year, it works fine
Re: Need suggestions for a 100+ amp 3 wire alternator [Re: DusterDave] #1329834
11/02/12 06:57 PM
11/02/12 06:57 PM
PA
bwhackd34 Offline
bwhackd34  Offline
PA
I have a 136 amp ext. reg. unit from a late 90's dodge ram on my 340 Duster.....and a 160 amp unit in store for a 468 small block in the works....bought both from ebay.....brand new in mopar boxes..nos.....they are real mopar/denso units.. ..retail for over 300 got each for around 75....i dont know if i would use cheapo china repops....i have used delco pulleys on them already and actually have also used go-cart spindle spacers behind to get pulley alignment right
Re: Need suggestions for a 100+ amp 3 wire alternator [Re: DusterDave] #1329835
11/02/12 09:58 PM
11/02/12 09:58 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
My Powermaster is a three wire 60a idle and 99a max unit. Is that close enough? If so, I will give you the Powermaster sales rep's email address.
mailto:bbasner@powermasterperformance.com
Tell Brady that you are looking for the best amp 3 wire Chrysler 75a that he can make. PM calls it a 75a unit but it is just shy of a 100a 3 wire Chrysler square back that will be a direct bolt in unit!!
Re: Need suggestions for a 100+ amp 3 wire alternator [Re: bwhackd34] #1329836
11/02/12 10:04 PM
11/02/12 10:04 PM
Tampa
Tampa
Thanks. I see one NOS Mopar 136 amp on ebay right now. It's for a 2001-2002 2.5L Dakota. Does the specified engine and year matter as far as hole locations on the case and wiring are concerned? Also, what brackets did you use to make it work? This will be going on an LA smallblock with power steering.
Re: Need suggestions for a 100+ amp 3 wire alternator [Re: DusterDave] #1329837
11/03/12 04:18 PM
11/03/12 04:18 PM
PA
bwhackd34 Offline
bwhackd34  Offline
PA
It will not be a bolt on.....i made my own brackets and set it up as a low mount.... i will post a pic...
Re: Need suggestions for a 100+ amp 3 wire alternator [Re: bwhackd34] #1329838
11/03/12 04:49 PM
11/03/12 04:49 PM
PA
bwhackd34 Offline
bwhackd34  Offline
PA
pic 1
Re: Need suggestions for a 100+ amp 3 wire alternator [Re: bwhackd34] #1329839
11/03/12 04:49 PM
11/03/12 04:49 PM
PA
bwhackd34 Offline
bwhackd34  Offline
PA
pic 2
Re: Need suggestions for a 100+ amp 3 wire alternator [Re: bwhackd34] #1329840
11/03/12 04:52 PM
11/03/12 04:52 PM
PA
bwhackd34 Offline
bwhackd34  Offline
PA
you also need to be sure it is externally regulated......I believe that one is.....some are internal....I needed to also find a plug for the one I have as it is not studded....some are.....it is a little bit of work but I like the look of the Denso and think it is cool that it is what is used on newer Chryslers....
