Finally installed my cutout switch. #1329759
11/01/12 11:37 PM
11/01/12 11:37 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
I finally decided where to put my cutout switch as since my battery is in the trunk I need to have one. I put it in the L/R taillite in the upper right corner. All I had to do was drill a hole in the taillite lens. I did not want to drill any holes in the car. So it worked great and since my battery box is on that side I bolted the switch to the battery box. Works good as its a push-pull and when you push it in it is flush with the lite bezel. Ron
Re: Finally installed my cutout switch. [Re: 383man] #1329760
11/01/12 11:39 PM
11/01/12 11:39 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Here you can see some of the switch on the battery box and the rod hooked to it. Actually you can only see the top of the switch as the solenoid you see behind the box is for the starter. Ron
Re: Finally installed my cutout switch. [Re: 383man] #1329761
11/01/12 11:47 PM
11/01/12 11:47 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
i don't see a on/off sticker.
Re: Finally installed my cutout switch. [Re: rickraw] #1329762
11/01/12 11:51 PM
11/01/12 11:51 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
I had not put it on yet when I took the pic. It says......Push off. I decided and put it on the bumper. Its black letters and stands out fine on the bumper. Ron
Re: Finally installed my cutout switch. [Re: 383man] #1329763
11/01/12 11:55 PM
11/01/12 11:55 PM
Ambridge, Pa.
Ambridge, Pa.
Re: Finally installed my cutout switch. [Re: rickraw] #1329764
11/02/12 12:08 PM
11/02/12 12:08 PM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
Hey Ron I avoided puttin the switch on my car for a long time too. Had no choice but to just do it . Mine stick out like a sore thumb.
6.50 @105.26
Re: Finally installed my cutout switch. [Re: 383man] #1329765
11/02/12 03:47 PM
11/02/12 03:47 PM
Western MA, +121 posts on old ...
sixpacstac Offline
super gas
sixpacstac  Offline
super gas
Nice job. Where did you get the strap for the battery box? Looks kind of familiar.
-'76 Volare, 340, 950 Holley HP, 3500 stall, 8 3/4 w/4.11's, 11.80 E.T., 113 MPH
Re: Finally installed my cutout switch. [Re: Kindafast] #1329766
11/02/12 03:50 PM
11/02/12 03:50 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
on my real slow street strip(high to mid 10,s) car its kinda hard to see but on my not as slow car(low nines)car, i want to make sure nobody has a prob seein it.i like the tail light deal,mind if i copy it.
Re: Finally installed my cutout switch. [Re: bonefish] #1329767
11/02/12 06:22 PM
11/02/12 06:22 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Looks great, Ron. I need to do something to make mine a little more subtle (big red handle on the bumper).
Your battery box is definately not NHRA legal. Don't know if the tech guy at your track will make much of a hassle out of it, but it could be an issue.
Re: Finally installed my cutout switch. [Re: StealthWedge67] #1329768
11/02/12 08:11 PM
11/02/12 08:11 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Thanks. A few years back the guy at the track told me it just had to be bolted down inside of the box as the box needs to be bolted to the floor and the battery had to be bolted to the box floor with a battery hold down setup. Rules may have changed as this was some years back. But if its legal just bolted to the floor in a battery hold down setup I would think this would be better then that as I see alot of batteries just bolted to the floors in race cars. But they have never said anything to me about it at my local tracks. Ron
Re: Finally installed my cutout switch. [Re: 383man] #1329769
11/02/12 08:44 PM
11/02/12 08:44 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
Technically, the trunk floor is not a proper mount, there should be a bar or tabs off the frame rail for the bolts pass thru.
Also, the boat battery box is an acceptable cover (with 3/8" bolts to the frame for the battery itself) as long as there is a proper firewall between the trunk and the drivers compartment.
2012 Rule book
8:1 BATTERIES
All batteries must be securely mounted; must be of sufficient capacity to start vehicle at any time. Batteries may not be relocated into the driver or passenger compartments. Rear firewall of .024-inch steel or .032-inch aluminum (including package tray) required when battery is relocated in trunk. In lieu of rear firewall, battery may be located in a sealed .024-inch steel, .032-inch aluminum, or NHRA-accepted poly box. If sealed box is used in lieu of rear firewall, box may not be used to secure battery and must be vented outside of body. Relocated battery(s) must be fastened to frame or frame structure with a minimum of two 3/8-inch-diameter bolts. OEM located batteries without complete OEM hold-down hardware must be secured to OEM battery box/tray using the same 3/8-inch diameter bolt hold-down method described in previous sentence. (“J” hooks prohibited or must have open end welded shut.) Metal battery hold-down straps mandatory. Strapping tape prohibited. A maximum of two automobile batteries, or 150 pounds combined maximum weight (unless otherwise specified in Class Requirements), is permitted. Maximums may vary according to Class Requirements.
My question is, why is the battery on the left side of the trunk? Most cars have the battery on the right side to add a little extra weight to the passenger side of the car to help "pre-load" the right tire for more even traction. Is this a ladder bar car or leaf spring? If it is ladder bar, the pre-load can be set with the bars. On a leaf spring setup, I would think the left placement of the battery would tend to drive the car to the right on the launch.
Scott
Re: Finally installed my cutout switch. [Re: ProStDodge] #1329770
11/02/12 08:56 PM
11/02/12 08:56 PM
fullmetaljacket Offline
My trunk mounted Battery is bolted through the far rear longitude frame rails on two parts. The four bolts holding down the battery boxed frame are long enough to exit through the bottom of the frame longitudes with big pressure washers and lock nuts securing them. The battery itself is then secured down with two vertical 3/8 thick Aluminum straps on each side of the battery with a cross over strap bolted on top. Every time the track tech Mafia looks, they want me to set up their cars for them.LOL. The way the battery is set up computes to them that the rest of the car is correct and no more questions are asked.
Re: Finally installed my cutout switch. [Re: ProStDodge] #1329771
11/02/12 09:01 PM
11/02/12 09:01 PM
Bellevue, NE
Charger453 Offline
Charger453  Offline
Bellevue, NE
Looks good, Ron. You had the same idea I did. It's much easier to just get another taillight and slap it in than it is to fill a hole in the body.
Re: Finally installed my cutout switch. [Re: ProStDodge] #1329772
11/02/12 09:15 PM
11/02/12 09:15 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
2012 Rule book
8:1 BATTERIES
Scott
Basically I did what it says as the battery tray is in the box bolted thru the box to the floor and the battery is bolted down with a battery hold down. I guess thats what I was trying to say before.
The actuall reason its on the left side is I got the battery cable free from a buddy as things were tight when I did it and it was not long enough to reach the right side. Really did not matter to me as its a street car and I really dont notice it on launch. I wanted to put it on the right side but this saved me money and I wanted the battery in some kind of box since I put many things in my trunk that I did not want any battery acid getting on. Thanks , Ron
Re: Finally installed my cutout switch. [Re: 383man] #1329773
11/02/12 11:22 PM
11/02/12 11:22 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Here is the Push Off sticker that came with it. Ron
Re: Finally installed my cutout switch. [Re: 383man] #1329774
11/03/12 09:38 AM
11/03/12 09:38 AM
Im glad to see your back is feeling better.Its tough bending over in that trunk area.
Re: Finally installed my cutout switch. #1329775
11/03/12 10:52 AM
11/03/12 10:52 AM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Actually my back its hurting bad this morning. I have good and bad days and the bad days I need a few more pain meds. Not what I like but it will get so bad sometimes I have no choice. Oh and thanks. Ron
Re: Finally installed my cutout switch. [Re: 383man] #1329776
11/03/12 10:55 AM
11/03/12 10:55 AM
tboomer Offline
tboomer  Offline
Looks good,Ron! Hope ya get feeling better and I hope next year is better for us all!
Re: Finally installed my cutout switch. [Re: tboomer] #1329777
11/03/12 01:49 PM
11/03/12 01:49 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
DITTO!!!!
Re: Finally installed my cutout switch. [Re: smokinwoody] #1329778
11/03/12 02:13 PM
11/03/12 02:13 PM
Work thru the pain Ron.I do every day.Sometimes it hurts so bad I don't want to get out of bed but racing is all I live for so I deal with it.go getum Ron!
