Barracuda Idler Arm Seems too Short!
#1329020
10/31/12 09:40 AM
10/31/12 09:40 AM
Posts: 856 1.5 hours SE of Pittsburg, Pa
geno440
I put the front suspension parts on my 68 Cuda 340. My steering linkage hits the oil pan when i turn all the way to the left. Viewing it from the back side, it appears that my idler arm is about .5 to 1 inch shorter that the rest of the suspension. It is almost like the arm is an inch shorter that it should be. I checked and found that they make only one idler arm. Anyone else ever run into this?
Love them 68 MOPARS! GTS 340 auto, Charger R/T 440 4-speed, Superbee 383 auto, GTX 440 auto, D100 (new front frame 5.7 hemi - in process), Formula S 340 4-Speed A/C (it's green), 383 auto Roadrunner (maybe a hemi - waiting) and a 68 W200 Power Wagon. Drivers: 07 Cummins and 14 Ecodiesel 4x4.
Re: Barracuda Idler Arm Seems too Short!
[Re: geno440]
#1329021
10/31/12 10:26 AM
10/31/12 10:26 AM
RapidRobert
I'm assuming you dont have the old one to compare it to
[Re: RapidRobert]
#1329022
10/31/12 11:04 AM
10/31/12 11:04 AM
geno440
I have the old one. It appears to be the same. The only thing I noticed is that the knuckle is worn very badly and I wonder how it did not fall appart.
[Re: geno440]
#1329023
11/01/12 11:12 PM
11/01/12 11:12 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Factory A body oil pans had clearance notches for this reason.. you sure your pan is the correct one?
[Re: Supercuda]
#1329024
11/02/12 01:58 AM
11/02/12 01:58 AM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
[Re: BulletBob]
#1329025
11/02/12 08:48 AM
11/02/12 08:48 AM
geno440
I need to post a picture. LOL. The pan is correct with notches.
The drag link sits higher on the idler arm side when the steering is pointed forward. (unlevel) The problem gets worse as you steer to the left and the idler arm side linkage moves towards the oil pan. The tie rode end hits the oil filter.
[Re: geno440]
#1329026
11/02/12 10:53 AM
11/02/12 10:53 AM
RapidRobert
I'd say the new arm is bent wrong. I'd get another idler arm & take that new one with you to compare and you want the one you select to be different as in have a lower drag link end to lower/level the drag link out. What's confusing me is you said the old/new ones are identical if I read that right (exc for the old one falling apart)
[Re: geno440]
#1329027
11/02/12 11:13 AM
11/02/12 11:13 AM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Do you have the correct/bent drag link on it and not the straight slant 6 drag link?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#1329028
11/03/12 03:09 PM
11/03/12 03:09 PM
Posts: 27,465 So Cal
autoxcuda
So Cal
On a 67-76 A-body there is no such thing as a /6 centerlink.
That is only for the 66 and earlier cars that they made a seperate centerlink for /6 and then V8 cars.
