Overdrive automatic tranny for slant 6? #1329011
10/31/12 09:31 AM
10/31/12 09:31 AM
Bartonville, Illinois
Fishyink Offline OP
Fishyink  Offline OP
A guy I work with has a late 70's Dodge truck with a slant 6 and an automatic tranny. He was wanting to know if there is an automatic tranny with overdrive that would work with the slant 6?
Thanks,
Shad
Shad Burkiett
Bartonville, IL
2014 Dodge Dart GT
08 Dodge Dakota TRX 4X4 4.7
08 Dodge Viper SRT-10
70 Plymouth Duster 408 6-barrel
Re: Overdrive automatic tranny for slant 6? [Re: Fishyink] #1329012
10/31/12 10:43 AM
10/31/12 10:43 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Not a bolt-together, but with an adapter plate an A-500 will probably fit pretty good in a truck. I have a buddy who put one in a Dart, and he had some cutting to do.
The same guy is getting together an group buy on adapters to use a Turbo 200. Should be plenty good for a Slant, and is smaller so it will require less surgery.
http://slantsix.org/forum/viewtopic.php?t=49981
Re: Overdrive automatic tranny for slant 6? [Re: slantzilla] #1329013
10/31/12 01:39 PM
10/31/12 01:39 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Did the factory at one point make adapter plates to put SB transmissions behind slants? I thought I read something about that one. However, if I had to spend several hundred bucks to get an adapter plate to put that trans behind a slant, IMO he would be money ahead finding a complete 2wd 5.2 magnum donor truck and putting the engine/trans in as a unit.
Re: Overdrive automatic tranny for slant 6? [Re: DaytonaTurbo] #1329014
10/31/12 02:08 PM
10/31/12 02:08 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Prior to '69 all /6's equipped with a 727 used an adapter plate to adapt the SB to the six...in '69 the /6 got its own dedicated 727 case.
Same adapter could be used to adapt the A500 or A518.
Re: Overdrive automatic tranny for slant 6? [Re: John_Kunkel] #1329015
11/01/12 12:17 AM
11/01/12 12:17 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Great info, John
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Overdrive automatic tranny for slant 6? [Re: Evil Spirit] #1329016
11/01/12 07:36 AM
11/01/12 07:36 AM
Fishyink Offline OP
Fishyink  Offline OP
Thank you for the replies I'll forward this info to him.
Shad Burkiett
Bartonville, IL
2014 Dodge Dart GT
Re: Overdrive automatic tranny for slant 6? [Re: Fishyink] #1329017
11/01/12 11:58 PM
11/01/12 11:58 PM
AndyF Offline
AndyF  Offline
I used to make adapters for that swap. They weren't very popular so I gave up on that idea.
