2010 2.4L question #1328714
10/30/12 04:28 PM
10/30/12 04:28 PM
South Lyon, MI.48178
K
kwhmopar1 Offline OP
K
I have an issue with a no start condition on my 2010 Avenger 2.4L. Went over on an Avenger forum, browsing posts for no start. Read a post that the 2.4L engine has a timing chain, not a belt. Can anyone verify this? Any help is appreciated. Thanks, Kevin
Junk is something you throw away just before you need it.
Re: 2010 2.4L question [Re: kwhmopar1] #1328715
10/30/12 05:08 PM
10/30/12 05:08 PM
Ringtown, Pa.
Dartsport540 Offline
Ringtown, Pa.
Yes, It has a timing chain, according to ALLDATA......
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
Re: 2010 2.4L question [Re: Dartsport540] #1328716
10/30/12 05:37 PM
10/30/12 05:37 PM
K
K
Thank you, well that hopefully rules out a broke belt/chain. Chains don't usually break.
Re: 2010 2.4L question [Re: kwhmopar1] #1328717
10/30/12 05:50 PM
10/30/12 05:50 PM
SE PA
Yellow Fever Offline
SE PA
If it's the cam sensor you should be able to unplug it then start it. It will take some cranking but it should start if that's the problem. Did you check for codes?
Re: 2010 2.4L question [Re: Yellow Fever] #1328718
10/30/12 06:18 PM
10/30/12 06:18 PM
Morningside
AdventurerSport Offline
waaaay out there in left field
Morningside
I agree. I had a 2008 Avenger and the 2.4L in these definitely has a timing chain, not a belt. The cam sensor failed on my Dad's 2010 Avenger 2.4 and that's how we got it started and to the dealership. It was only a week old when it happened, too...
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red
06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II
06 Chrysler 300C AWD 5.7L Hemi
10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI
10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI
11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red
16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
Re: 2010 2.4L question [Re: AdventurerSport] #1328719
10/31/12 12:15 PM
10/31/12 12:15 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Is the cam sensor something that could be changed on the side of the road with a few tool? My 2010 Avenger has 75,000 miles, it might be a good idea to put a spare sensor in the glovebox.
