Cast Iron Dual 4 BBL intake 2264877 #1328666
10/30/12 12:12 PM
10/30/12 12:12 PM
Indiana USA
RStoner Offline OP
RStoner  Offline OP
Indiana USA
I found this dual 4 bbl cast iron intake, and looking for some answers. The casting number is 2264877 , which from what I can find, is a 1962 used on B and C bodies with a 413 engine. There is a casting date of 11-?- 67. No pentastar, but it looks like a W inside of a circle. Did Weiand make intakes with Mopar casting numbers?
Re: Cast Iron Dual 4 BBL intake 2264877 [Re: RStoner] #1328667
10/30/12 01:04 PM
10/30/12 01:04 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The last Chrysler in line 413 2x4 was on the 62 300H,the manifold and all the necessary components were avaliable from Direct Connection into the early 70's,I don't think any aftermarket company would/did make a cast iron intake.
Re: Cast Iron Dual 4 BBL intake 2264877 [Re: RStoner] #1328668
10/30/12 01:53 PM
10/30/12 01:53 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
Chrysler 1959 413 300-E 2264877 Cast iron 2x4
Chrysler 1960 413 300-F 2264877 Cast iron 2x4
Chrysler 1961 413 300-G 2264877 Cast iron 2x4
Chrysler 1962 413 300-H 2264877 Cast iron 2x4
found this on google I had one for my 62 dart i was gonna use.
Re: Cast Iron Dual 4 BBL intake 2264877 [Re: moparsquid] #1328669
10/30/12 02:34 PM
10/30/12 02:34 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Sounds cool. How about some pics?
Keep old mopars alive.
Re: Cast Iron Dual 4 BBL intake 2264877 [Re: 2boltmain] #1328670
10/30/12 04:17 PM
10/30/12 04:17 PM
Indiana USA
RStoner Offline OP
RStoner  Offline OP
Indiana USA
I will take a picture and post it.
Re: Cast Iron Dual 4 BBL intake 2264877 [Re: RStoner] #1328671
10/30/12 04:44 PM
10/30/12 04:44 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Does it look like this? This is the 383 version, the RB is quite similar.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: Cast Iron Dual 4 BBL intake 2264877 [Re: Fury Fan] #1328672
10/30/12 05:16 PM
10/30/12 05:16 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
When did the dual plane design start being utilized? The factory 2x4 intakes- just like the Offenhauser dual quad manifolds are a big open single plane. Look inside and compare to the Edelbrock CH28. (The old open plenum dual quad manifolds make good subjects for blower manifold conversion)
Re: Cast Iron Dual 4 BBL intake 2264877 [Re: 2boltmain] #1328673
10/30/12 09:36 PM
10/30/12 09:36 PM
moparx Offline
Buying your homeless and unwanted bolt on battery terminals
moparx  Offline
my old, feeble mind wants to say the "w" cast mark stands for the WINTERS[co.] foundry.
Re: Cast Iron Dual 4 BBL intake 2264877 [Re: moparsquid] #1328674
10/30/12 10:34 PM
10/30/12 10:34 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The 60/61 were long ram engines same as the 63/64 300J and K.
Re: Cast Iron Dual 4 BBL intake 2264877 [Re: 62maxwgn] #1328675
10/31/12 04:11 PM
10/31/12 04:11 PM
Indiana USA
RStoner Offline OP
RStoner  Offline OP
Indiana USA
here is a picture. any idea of what it is worth?
Re: Cast Iron Dual 4 BBL intake 2264877 [Re: RStoner] #1328676
10/31/12 06:40 PM
10/31/12 06:40 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Is that a threaded hole on the right front corner? If so it is probably a marine intake.
Re: Cast Iron Dual 4 BBL intake 2264877 [Re: 62maxwgn] #1328677
10/31/12 08:37 PM
10/31/12 08:37 PM
dogdays Offline
dogdays  Offline
At least 10 cents a pound.
R.
Re: Cast Iron Dual 4 BBL intake 2264877 [Re: dogdays] #1328678
11/01/12 07:49 AM
11/01/12 07:49 AM
Indiana USA
RStoner Offline OP
RStoner  Offline OP
Indiana USA
No tapped hole in the front, only a 3/8" NPT in the back for the vacuum line.
Thanks to all of you that tried to answer my question. Moparts is a great site, with a lot of members that are willing to help someone out. Not sure about the 10 cents a pound answer.
Re: Cast Iron Dual 4 BBL intake 2264877 [Re: RStoner] #1328679
11/01/12 10:43 AM
11/01/12 10:43 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
It's been modified. Originally, they had four holes per carb.
Re: Cast Iron Dual 4 BBL intake 2264877 [Re: Jim_Lusk] #1328680
11/05/12 09:54 AM
11/05/12 09:54 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
Randy - There's an older guy in teh north room of the Indy swap meet at 38th St (you may know who I mean, he looks like Santa Claus) that has been carrying it for at least 4 years. He wants $450 for it. I got teh B I posted earlier for $125 and paid a little more for an RB one I have.
So, somewhere between $.10 and $450. Not much demand for them except from resto guys.
Re: Cast Iron Dual 4 BBL intake 2264877 [Re: Fury Fan] #1328681
11/05/12 11:33 AM
11/05/12 11:33 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Around $200/$250 is a fair price,at $400 he'll have it forever.
Re: Cast Iron Dual 4 BBL intake 2264877 [Re: 62maxwgn] #1328682
11/05/12 07:32 PM
11/05/12 07:32 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
I've had a 383 cast iron 2x4 for 30 years. I paid $3.00 for it. I've used it on several different street motors through the years, it's a nice street manifold. Dave
