Re: 400 Flywheel
[Re: jrn88]
#132831
10/06/08 12:41 PM
10/06/08 12:41 PM
Posts: 4,285 Ohio
64dodge572
Ohio
The 400/440 cast crank share the same flywheel. Give us a call, we can balance one for you.
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
Re: 400 Flywheel
[Re: 440beep]
#132838
10/08/08 12:59 AM
10/08/08 12:59 AM
DaytonaTurbo
Manitoba, Canada
Balancer on front of engine should say Cast Crank Only or something like that on it.
is not on 400 on a 440 yes
Really, I thought they would have used the same? If not, I think 440source.com has as nice page showing off all the factory big block balancers.
Re: 400 Flywheel
[Re: jrn88]
#132839
10/08/08 01:02 AM
10/08/08 01:02 AM
Posts: 1,183 eganville ont
440beep
eganville ont
I have a 1972 400 and I want to put it in my Fury with a 4 speed Tranny ....I believe the 400 is externally balanced is there a specific flywheel for a 400 or do I need to just get one balanced?
#3614374, used on 400's with external balance cast cranks, which can usually be found in a passenger car and/or automatic trans application (applications with 400 engines and manual transmission applications used forged cranks.) It measures 7 1/4" diameter by about 7/8" wide. Although it is similar to the "six pack" dampers above, the weight on these is much thicker, and more closely resembles the weights on the cast crank 440 models below, even though the ring thickness is similar to an internal balance damper. One easy way to identify these (and not confuse them with six pack models) is the small half circle that is cut into one side of the counterweight. This is visible in the picture above at about the 3 o'clock position. This is the only damper that will have this small cut. all 72-74 400 4speed cars are factory steel cranks damper 3614371damper
Plymouth's gonna getcha!
There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters
71 gtx 440 4speed air grabber blue on blue with white vinyl roof
Re: 400 Flywheel
[Re: dave571]
#132843
10/08/08 08:40 AM
10/08/08 08:40 AM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
I thought there was a template in the archives for drilling a neutral flywheel, so it will work
There is but that is a PRECISE operation , ESPECIALLY if someone is doing it AFTER an engine was balanced using something else . How many people have a rotary table for thier HOME drill press .... don't all stand up at once
YMMV
Re: 400 Flywheel
[Re: JohnRR]
#132844
10/08/08 12:59 PM
10/08/08 12:59 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
sorry the highjack, but being the diff balancer dampeners came out to float!!!
are the PULLEYS to both dampeners diff ?
I mean of a 4 grooves pulley to cast assembly is the same than a 4 grooves pulley to forged assembly ?
Re: 400 Flywheel
[Re: NachoRT74]
#132845
10/08/08 01:24 PM
10/08/08 01:24 PM
JohnRR
U.S.S.A.
pulleys are neutral and not balancer specific EXCEPT for the bolt circle change from asymmetric to symmetric around 1971 , or was it 1970 ??? ...
Re: 400 Flywheel
[Re: John_Kunkel]
#132847
10/08/08 02:54 PM
10/08/08 02:54 PM
JohnRR
U.S.S.A.
Modern devices have spoiled creativity, a protractor and 12-inch scale would do the job equally well.
Re: 400 Flywheel
[Re: John_Kunkel]
#132849
10/11/08 04:09 PM
10/11/08 04:09 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
and doing it from the diagram or any other method with care at home, and it will be AT LEAST as close as the factory balance was, AND as good as a reman torque converter from a rebuilder who welded the weights on himself.
