Quick question on harmonic damper installation #1327312
10/28/12 12:43 PM
10/28/12 12:43 PM
Tampa
DusterDave Offline OP
Tampa
I'm in the middle of installing an aftermarket damper on my 318 stroker, and I've never installed one on smallblocks before. Is there a precise stop on the crank snout, or do I have to check pulley alignment as I go?
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Quick question on harmonic damper installation [Re: DusterDave] #1327313
10/28/12 12:51 PM
10/28/12 12:51 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
it will stop against the crank gear. u might hone the damper a little. some have too much interference fit. may gauld on the crank snout. use some antiseize on the snout.
Re: Quick question on harmonic damper installation [Re: rickraw] #1327314
10/28/12 12:52 PM
10/28/12 12:52 PM
Tampa
Tampa
Honing already done by the machinist. Thanks!
Re: Quick question on harmonic damper installation [Re: DusterDave] #1327315
10/28/12 04:09 PM
10/28/12 04:09 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Damper fit should be checked while degreeing the cam.. just to check accuracy of timing marks on true TDC. Makes it a lil easier.
