Re: 1992 dakota pcm
[Re: poorboy]
#1325113
10/23/12 10:04 PM
10/23/12 10:04 PM
DaytonaTurbo
Manitoba, Canada
Convert to an electronic voltage regulator and carry on, until something else craps out on the pcm.
Use an ignition hot wire to power the regulator and wire it like the old race cars were done for the electronic regulator. Then disconnect the alt field wire out of the computer and tape it up good. Gene
Just keep in mind the computer will be throwing codes if you do this.
Re: 1992 dakota pcm
[Re: poorboy]
#1325114
10/23/12 10:07 PM
10/23/12 10:07 PM
Posts: 28,399 Posting from 1893 in NW FL
TheBlueBeast
If not already done this would make a good tech article for the archives. Pictures would be important with the directions.
Re: 1992 dakota pcm
[Re: volaredon]
#1325120
10/24/12 11:24 AM
10/24/12 11:24 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
To both OP and Mr Yuck I have computers here for both of those collecting dust... I have 1 for the 88 RC and should have 2 or 3 for the Dakota I know I have a 93 Dak V8 one, and "should" have both a 92 and a 94 V8 in the attic have to dig a bit; I also have a 94/95 3.9 one.
the good part is that from 92-95 you can interchange different year computers between them. I am running a 94 M/T one on my 93 Dakota that I converted from an A/T
Thanks. I let you know if I need it. I know on my 95 Dak the MP computer really woke up the engine. If the 95 works on the 92 I'd get one.
Re: 1992 dakota pcm
[Re: Mr.Yuck]
#1325121
10/24/12 05:44 PM
10/24/12 05:44 PM
Posts: 112 sw mo
meanmothermagnum
sw mo
I would welcome a performance pcm if I could find one. They don't make them anymore and are hard to find in good/usable condition. If you do find one they are stupid expensive and I'm on a cheep beer budget!!
Re: 1992 dakota pcm
[Re: Mr.Yuck]
#1325122
10/24/12 07:48 PM
10/24/12 07:48 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
I have a 92/93 5.2 Mopar Performance PCM if anyonwe needs/wants one.
