Does anyone reproduce this? #1323449
10/20/12 05:59 PM
10/20/12 05:59 PM
New York
E
EL5 71 Offline OP
EL5 71  Offline OP
E
New York
Just wondering if if this rare little setup is being reproduced by anyone? It's the rear U-joint grease cap retainer clips used on the assemly line. I'm assuming it was to keep the caps in place before and during drive shaft installation at the plant. I removed this from a 22,000 mile Lynch Road assembled 1971 Charger. Thanks for any help.
Re: Does anyone reproduce this? [Re: EL5 71] #1323450
10/21/12 09:47 AM
10/21/12 09:47 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Not that I'm aware of
Re: Does anyone reproduce this? [Re: gtx6970] #1323451
10/21/12 11:06 AM
10/21/12 11:06 AM
New York
E
EL5 71 Offline OP
EL5 71  Offline OP
E
New York
My thoughts are if this is an item that our cars came with from the factory, it might be a pretty simple little detail item for me to reproduce (or to have someone reproduce). I should have taken a couple of photos of this strap still installed on the rear U-Joint just for reference but it's pretty obvious how it's installed. I'll have to do more research to find out if it was installed on all cars.
Re: Does anyone reproduce this? [Re: EL5 71] #1323452
10/21/12 12:42 PM
10/21/12 12:42 PM
WI
RestoRick Offline
RestoRick  Offline
WI
I've made a few of them...
two different styles of end fold seem to have been used or maybe bent differently on some.
The strip part is easily made.. those special cap rings are the part that I've not been able to find.
Re: Does anyone reproduce this? [Re: RestoRick] #1323453
10/21/12 01:25 PM
10/21/12 01:25 PM
New York
E
EL5 71 Offline OP
EL5 71  Offline OP
E
New York
I agree and now looking at it... now I don't think it's gonna be too easy to make those unique cap clips like you said. They appear to be flat spring steel. Probably be pointless to have a machinist try to duplicate them because it's likely they'll break installing them onto the caps. Hmm... any ideas? I know this is a super small detail item that you really..and I mean really, gotta look to find, but it would be cool to have them available to put back on our cars if going that far on a restoration. As for now, I can't even say for certain that all cars had them.
Re: Does anyone reproduce this? [Re: RestoRick] #1323454
10/21/12 01:29 PM
10/21/12 01:29 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
They can be laser cut from spring steel.
Re: Does anyone reproduce this? [Re: DoctorDiff] #1323455
10/21/12 01:32 PM
10/21/12 01:32 PM
New York
E
EL5 71 Offline OP
EL5 71  Offline OP
E
New York
Awesome!! I knew someone out there would know more about this than me. I'll check into that. Thanks.
Re: Does anyone reproduce this? [Re: EL5 71] #1323456
10/21/12 01:36 PM
10/21/12 01:36 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
A better method may be water jet cutting, as this won't create a heat zone.
Re: Does anyone reproduce this? [Re: DoctorDiff] #1323457
10/21/12 06:26 PM
10/21/12 06:26 PM
N.Y.
V
VZCharger Offline
VZCharger  Offline
V
N.Y.
Saw this post earlier, and I was just out under my Ram and noticed it had these on at least the u-joints on the front axle.
70 Charger blown injected BB 07 Charger Daytona Plum Crazy #389 69 Coronet ragtop 96 Ram "Garlits Edition" 88 Conquest TSi
Re: Does anyone reproduce this? [Re: VZCharger] #1323458
10/21/12 08:21 PM
10/21/12 08:21 PM
WI
RestoRick Offline
RestoRick  Offline
WI
I'd think there's a supplier somewhere that has the clips.
I've simply detailed originals for the few I've done.
Laser or jet cutting them wouldn't give the correct edge appearance. I know that sounds nit-picky, but this is a small detail item that someone who's that particular about a piece this small will care about.
I think that last sentence made sense..
Re: Does anyone reproduce this? [Re: RestoRick] #1323459
10/21/12 09:09 PM
10/21/12 09:09 PM
Land of 10,000 Lakes
44D6PAKCUDA Online content
44D6PAKCUDA  Online Content
Wonder who that could be.....
Re: Does anyone reproduce this? [Re: 44D6PAKCUDA] #1323460
10/21/12 09:19 PM
10/21/12 09:19 PM
WI
RestoRick Offline
RestoRick  Offline
WI
Re: Does anyone reproduce this? [Re: VZCharger] #1323461
10/21/12 10:48 PM
10/21/12 10:48 PM
New York
E
EL5 71 Offline OP
EL5 71  Offline OP
E
New York
Well, maybe if it's gonna be really difficult to reproduce this item, at least we might know another place to look for them and see if they would work on our cars. Thanks for posting that you saw them elsewhere also.
Re: Does anyone reproduce this? [Re: RestoRick] #1323462
10/21/12 11:40 PM
10/21/12 11:40 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
You could always sand the exposed, kerf cut edges, then tumble the parts.
I don't think a small detail item like this made on a punch press, then hardened would be cost effective. The super-picky guys usually want the real thing, regardless of how accurate the repro is.
