CHARGING PROBLEM
#1323375
10/20/12 02:50 PM
10/20/12 02:50 PM
Posts: 236 Richmond , Virginia
chagjr
Richmond , Virginia
OK, I recently installed a 2 field square back alternator, Powermaster. I have grounded one of the field connection so it will properly work with my 69 Bee. It charges fine but the voltage is going to 15 volts. I have burned up the MP constant out put. A 50.00 NAPA unit starts smoking after 30 seconds, the other regulator I am using goes to 15 volts but does not smoke. If I turn on head lights voltage drops to 14 to 14.5 vclts. New wiring harness. HELP!
F.A.S.T/1969 SUPER BEE/383/AUTO/AVS 11.58 @ 117.98 1.71 60ft mph F.A.S.T Legal
1969 DART SWINGER/340(420CI)/6.52 @ 105.39 1.45 60ft (1/8 mile)10.22 @130.5 (1/4 mile)
Harry
Re: CHARGING PROBLEM
[Re: Andrewh]
#1323377
10/20/12 05:04 PM
10/20/12 05:04 PM
Posts: 1,526 North Carolina
cjskotni
North Carolina
what does the voltage read at the VR. and are you sure you have a good ground to it?
I second this. Make sure the VR is very well grounded. If not, it will not be able to "sense" propeerly and corectly meter the voltage.
Good Luck
[Re: cjskotni]
#1323378
10/20/12 06:36 PM
10/20/12 06:36 PM
RapidRobert
I'd check the voltages at every pertinent connection and might toss an orig alt back on to see if the problem is inside the alt
[Re: chagjr]
#1323380
10/22/12 02:58 PM
10/22/12 02:58 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
get a good ground wire between batt and rad core support ground provision, then the ground strap between block and firewall and you should be done.
that's how factory did
