CHARGING PROBLEM #1323375
10/20/12 02:50 PM
10/20/12 02:50 PM
Richmond , Virginia
chagjr Offline OP
chagjr  Offline OP
Richmond , Virginia
OK, I recently installed a 2 field square back alternator, Powermaster. I have grounded one of the field connection so it will properly work with my 69 Bee. It charges fine but the voltage is going to 15 volts. I have burned up the MP constant out put. A 50.00 NAPA unit starts smoking after 30 seconds, the other regulator I am using goes to 15 volts but does not smoke. If I turn on head lights voltage drops to 14 to 14.5 vclts. New wiring harness.
HELP!
F.A.S.T/1969 SUPER BEE/383/AUTO/AVS 11.58 @ 117.98 1.71 60ft mph F.A.S.T Legal
1969 DART SWINGER/340(420CI)/6.52 @ 105.39 1.45 60ft (1/8 mile)10.22 @130.5 (1/4 mile)
Harry
Re: CHARGING PROBLEM [Re: chagjr] #1323376
10/20/12 04:18 PM
10/20/12 04:18 PM
Andrewh Offline
Andrewh  Offline
what does the voltage read at the VR.
and are you sure you have a good ground to it?
Re: CHARGING PROBLEM [Re: Andrewh] #1323377
10/20/12 05:04 PM
10/20/12 05:04 PM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
I second this. Make sure the VR is very well grounded. If not, it will not be able to "sense" propeerly and corectly meter the voltage.
Good Luck
Re: CHARGING PROBLEM [Re: cjskotni] #1323378
10/20/12 06:36 PM
10/20/12 06:36 PM
I'd check the voltages at every pertinent connection and might toss an orig alt back on to see if the problem is inside the alt
Re: CHARGING PROBLEM [Re: cjskotni] #1323379
10/21/12 01:55 PM
10/21/12 01:55 PM
Richmond , Virginia
chagjr Offline OP
chagjr  Offline OP
Richmond , Virginia
Good Luck
THANK YOU! You would think going to the firewall like before would be sufficient. I ran an additional ground to the copper ground on the 3 speed wiper motor. Problem solved... holding 13.5 volts with Fuel pump and other electronial funtions Thanks again
Harry
Re: CHARGING PROBLEM [Re: chagjr] #1323380
10/22/12 02:58 PM
10/22/12 02:58 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
get a good ground wire between batt and rad core support ground provision, then the ground strap between block and firewall and you should be done.
that's how factory did
Re: CHARGING PROBLEM [Re: NachoRT74] #1323381
10/22/12 03:43 PM
10/22/12 03:43 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Glad you fixed it as I was also going to say it almost had to be a bad ground to the reg on the way that system functions. Ron
Re: CHARGING PROBLEM [Re: 383man] #1323382
10/22/12 06:00 PM
10/22/12 06:00 PM
Iowa
GreenBird Offline
GreenBird  Offline
Iowa
I am having a similar problem (voltage is spiking off and on) and I assumed it was a grounding problem. But I have one of those Denso alternators with the internal voltage regulator. How would I address a ground issue with that setup?
