Pros and cons of a 70 K frame in a 65 B body #1322333
10/18/12 05:54 PM
10/18/12 05:54 PM
Northwest
Four40mopar Offline OP
Northwest
I have asked this question before with not many answers. What are the pro and cons of putting a 70-72 B body K frame into a 65 B body? Will I be able to use a 66-69 transmission crossmember and driveline?
Re: Pros and cons of a 70 K frame in a 65 B body [Re: Four40mopar] #1322334
10/18/12 06:38 PM
10/18/12 06:38 PM
Tucson, AZ
Ramrod39 Online work
My New Title
Ramrod39  Online Work
My New Title
Tucson, AZ
Why?
Re: Pros and cons of a 70 K frame in a 65 B body [Re: Ramrod39] #1322335
10/18/12 06:53 PM
10/18/12 06:53 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Why?
Improved weight distribution which helps the car stop, turn & handle better.. More header choices.. Fairly common upgrade...
Re: Pros and cons of a 70 K frame in a 65 B body [Re: 1_WILD_RT] #1322336
10/18/12 07:27 PM
10/18/12 07:27 PM
dogdays Offline
dogdays  Offline
Not advisable if you're truly anal about "originality".
R.
Re: Pros and cons of a 70 K frame in a 65 B body [Re: 1_WILD_RT] #1322337
10/18/12 07:30 PM
10/18/12 07:30 PM
Tucson, AZ
My New Title
My New Title
Tucson, AZ
Why?
I did not know that....
Re: Pros and cons of a 70 K frame in a 65 B body [Re: Ramrod39] #1322338
10/18/12 07:59 PM
10/18/12 07:59 PM
Northwest
Northwest
The main reason is to get 70-72 in frame sway bar, original is not an issue.
Re: Pros and cons of a 70 K frame in a 65 B body [Re: Four40mopar] #1322339
10/18/12 08:10 PM
10/18/12 08:10 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
One of the pros is you can front hang disc brake calipers on the front of the disc without sway bar interference and safely routing your brake hoses without the hassles.
The cons, going through the trouble and expense of finding a good one.
BTW, although a 71-72 B-Body K-member will bolt to the frame rails, the 1970 B-Body K-member has the correct steering box angle that will work on your 65. There are many different K-member part numbers and a few variations among them.
Re: Pros and cons of a 70 K frame in a 65 B body [Re: CompSyn] #1322340
10/18/12 08:14 PM
10/18/12 08:14 PM
Northwest
Northwest
Was looking at buying one from a 72 charger, do you know if that would be a problem
Re: Pros and cons of a 70 K frame in a 65 B body [Re: Four40mopar] #1322341
10/18/12 08:31 PM
10/18/12 08:31 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
The steering box angle is different on 71/72 B/E k , you want to find a 70 B body K.
Re: Pros and cons of a 70 K frame in a 65 B body [Re: JohnRR] #1322342
10/18/12 08:34 PM
10/18/12 08:34 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Yep! Read this: https://board.moparts.org/ubbthreads/showflat.php?Number=5427320
Re: Pros and cons of a 70 K frame in a 65 B body [Re: CompSyn] #1322343
10/19/12 08:32 AM
10/19/12 08:32 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Moves the motor back gets more rad clearance.But also moves the trans back so cross member has to be moed.You get to use newer motor mounts also.I have polys in my 65 so I dont rip them anymore.Just scraped a complete K from a Charger that would have fit.Rocky
Chrysler Firepower
Re: Pros and cons of a 70 K frame in a 65 B body [Re: therocks] #1322344
10/19/12 10:39 AM
10/19/12 10:39 AM
Mid Michigan
Mr. Smurf Offline
Mr. Smurf  Offline
Mid Michigan
The swap also does a nice job of making a mess of a 4spd clutch linkage.....
Ed
Re: Pros and cons of a 70 K frame in a 65 B body [Re: Mr. Smurf] #1322345
10/19/12 01:37 PM
10/19/12 01:37 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Putting the 68-70 style of B body K member into a 65 makes sense if you not running a cross ram. If it is a 4 speed you will have to reconfigure the clutch linkage and pivots. 4 speed or auto you have to rework the trans mount also, not to mention shorten the driveshaft. You will be able to use the 66 up style of big block oil pan and headers.
...FAFO...
Re: Pros and cons of a 70 K frame in a 65 B body [Re: skicker] #1322346
10/19/12 03:07 PM
10/19/12 03:07 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
take a look at your firewall versus a 66 up----you have a peak sticking out toward the motor and the 66 up is flat----the peak means interference with the motor if it is moved back---the peak is part of heater intake area---when i fitted a V10 to a 64 i cut the peak out so i could move the motor back, which meant i could have a radiator---drag race guys do it all the time to move the center of gravity back a couple of inches and they dont want a heater in the car anyway....bob
Re: Pros and cons of a 70 K frame in a 65 B body [Re: skicker] #1322347
10/19/12 03:39 PM
10/19/12 03:39 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Ive found that even the newer pans fit the 65 K.I ran a 67 C body then went to Moroso 8 qt for the 66 up.Fits just fine.Rocky
Chrysler Firepower
Re: Pros and cons of a 70 K frame in a 65 B body [Re: therocks] #1322348
10/19/12 08:23 PM
10/19/12 08:23 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
We did the swap a few years ago in our 64 Plymouth. Later B-body headers fit, better radiator/fan clearance, firewall clearance is OK with a single 4-bbl (but not with a cross ram), but you have to flatten the pinch weld in the trans tunnel and use a BFH ( ) where the band apply piston is near the tunnel.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: Pros and cons of a 70 K frame in a 65 B body [Re: Dads426] #1322349
10/19/12 08:27 PM
10/19/12 08:27 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Not sure if the later trans crossmember will work, but I sectioned the original one and moved the "box" back to correspond to the new location. Used a cheapie late 60's trans mount instead of the more expensive early B trans mount.
Re: Pros and cons of a 70 K frame in a 65 B body [Re: Dads426] #1322350
10/19/12 08:29 PM
10/19/12 08:29 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
Bottom:
Re: Pros and cons of a 70 K frame in a 65 B body [Re: Dads426] #1322351
10/20/12 12:52 AM
10/20/12 12:52 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I never changed mine as I still use the original 383 K-frame in my 63 Sport Fury. Really dont have a good pic to tell how the eng is about 1-1/2 to 2 inches more to the front with the original K-frame. Dont know it the little bit of weight transfer would help it hook better. It has pulled a best 60 of 1.50 running 10.76 on 9" slicks. Its basically an all stock suspension car with SS springs and CE 90/10 shocks up front. Ron
Re: Pros and cons of a 70 K frame in a 65 B body [Re: 383man] #1322352
10/20/12 12:55 AM
10/20/12 12:55 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
It seems to hook ok for what it is and have ok weight transfer. But its basically a street car I like to race a couple times a year. Ron
