Pros and cons of a 70 K frame in a 65 B body
#1322333
10/18/12 05:54 PM
10/18/12 05:54 PM
Posts: 61 Northwest
Four40mopar
Northwest
I have asked this question before with not many answers. What are the pro and cons of putting a 70-72 B body K frame into a 65 B body? Will I be able to use a 66-69 transmission crossmember and driveline?
Re: Pros and cons of a 70 K frame in a 65 B body
[Re: 1_WILD_RT]
#1322337
10/18/12 07:30 PM
10/18/12 07:30 PM
Posts: 9,140 Tucson, AZ
Ramrod39
My New Title
My New Title
Tucson, AZ
Why?
Improved weight distribution which helps the car stop, turn & handle better.. More header choices.. Fairly common upgrade...
I did not know that....
[Re: Four40mopar]
#1322341
10/18/12 08:31 PM
10/18/12 08:31 PM
Posts: 75,080 U.S.S.A.
JohnRR
U.S.S.A.
Was looking at buying one from a 72 charger, do you know if that would be a problem
The steering box angle is different on 71/72 B/E k , you want to find a 70 B body K.
[Re: CompSyn]
#1322343
10/19/12 08:32 AM
10/19/12 08:32 AM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
Moves the motor back gets more rad clearance.But also moves the trans back so cross member has to be moed.You get to use newer motor mounts also.I have polys in my 65 so I dont rip them anymore.Just scraped a complete K from a Charger that would have fit.Rocky
Chrysler Firepower
[Re: Mr. Smurf]
#1322345
10/19/12 01:37 PM
10/19/12 01:37 PM
Posts: 5,112 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Putting the 68-70 style of B body K member into a 65 makes sense if you not running a cross ram. If it is a 4 speed you will have to reconfigure the clutch linkage and pivots. 4 speed or auto you have to rework the trans mount also, not to mention shorten the driveshaft. You will be able to use the 66 up style of big block oil pan and headers.
...FAFO...
[Re: skicker]
#1322347
10/19/12 03:39 PM
10/19/12 03:39 PM
therocks
Niles , Ohio
Ive found that even the newer pans fit the 65 K.I ran a 67 C body then went to Moroso 8 qt for the 66 up.Fits just fine.Rocky
Chrysler Firepower
[Re: therocks]
#1322348
10/19/12 08:23 PM
10/19/12 08:23 PM
Posts: 1,443 Maryland
Dads426
Maryland
We did the swap a few years ago in our 64 Plymouth. Later B-body headers fit, better radiator/fan clearance, firewall clearance is OK with a single 4-bbl (but not with a cross ram), but you have to flatten the pinch weld in the trans tunnel and use a BFH ( ) where the band apply piston is near the tunnel.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: Dads426]
#1322349
10/19/12 08:27 PM
10/19/12 08:27 PM
Dads426
Maryland
Not sure if the later trans crossmember will work, but I sectioned the original one and moved the "box" back to correspond to the new location. Used a cheapie late 60's trans mount instead of the more expensive early B trans mount.
[Re: Dads426]
#1322350
10/19/12 08:29 PM
10/19/12 08:29 PM
Dads426
Maryland
