Valley Plate w/ Stage 6 Heads #1321485
10/16/12 09:36 PM
10/16/12 09:36 PM
Gibsonburg, Ohio USA
dodgem_doug Offline OP
I’m building a 500 with the Mopar Stage 6 heads. I bought an Indy Valley plate but it won’t work with these heads. Anyone have suggestions for manufactures where I can get a solid valley plate. I don’t see anything on Mancini’s website.
Re: Valley Plate w/ Stage 6 Heads [Re: dodgem_doug] #1321486
10/17/12 12:34 AM
10/17/12 12:34 AM
Oh Canada
E
EV2CUDA Offline
EV2CUDA  Offline
E
Oh Canada
Custom only. I cut a new tin tub and fit below Indy valley plate with silicone. 400 block
71 Barracuda 383 4spd (500ci)
69 camaro 598, NOS
69 barracuda bbc procharger
77 t/a 6.0 turbo project
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
78 Warlock 5.7 hemi project
Re: Valley Plate w/ Stage 6 Heads [Re: dodgem_doug] #1321487
10/17/12 02:35 AM
10/17/12 02:35 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I simply cut a piece of flat aluminum plate and cut it to fit close to the heads. Sealed it up with a bead of RTV. Worked great. Need spacers, RB M1 4150 intake, bunch of MP stage VI intake gaskets of different thicknesses, and the valley plate? PM me!
Re: Valley Plate w/ Stage 6 Heads [Re: J_BODY] #1321488
10/17/12 03:43 AM
10/17/12 03:43 AM
Arizona
Chris'sBarracuda Offline
Arizona
I just welded a valley plate to the manifold.. Done..
I'll find, if I can, pics and post them..
Chris..
Re: Valley Plate w/ Stage 6 Heads [Re: dodgem_doug] #1321489
10/17/12 08:23 AM
10/17/12 08:23 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
This engine is a 440 w/ stage VI heads. When I got it, it had the indy block off plate. I had to switch to a 440 source block off because of the heat crossover under the six pack. I had to bend one lip a tiny bit, but it fit fine and I have no leaks or any other issue.
Coming soon!!!!
Re: Valley Plate w/ Stage 6 Heads [Re: Mr.Yuck] #1321490
10/17/12 06:12 PM
10/17/12 06:12 PM
Stockholm, Sweden
fed Offline
fed  Offline
Stockholm, Sweden
Im running a Indyplate on my RB500.
Works perfect, just a bead of hightemp silcon to the heads.
Cuda, -70
Valiant-65 AWB,
Valiant Signet200 -65 Topchopped dragcar.
Topolino Fuel Altered.
NostalgiaFED Sold,
SuperComp Bantam Altered, Sold
Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
Re: Valley Plate w/ Stage 6 Heads [Re: dodgem_doug] #1321491
10/17/12 09:45 PM
10/17/12 09:45 PM
Regina Sask, Canada
V
Viper469 Offline
Viper469  Offline
V
Regina Sask, Canada
My engine builder just made one. Just bolts on at the ends and some silly cone along the sides. I think he charged about $50.
Re: Valley Plate w/ Stage 6 Heads [Re: Viper469] #1321492
10/18/12 09:23 AM
10/18/12 09:23 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
I'd like to keep my engine as clean as possible and also be able to just use the paper intake gaskets if possible. Is a valley plate a good idea for a street engine or should I just stick to the bathtub gasket?
This is the land of the free because of the brave
Re: Valley Plate w/ Stage 6 Heads [Re: Viper469] #1321493
10/18/12 09:53 AM
10/18/12 09:53 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
keep in mind that if you are running an intake w/ a heat crossover such as an RPM, CH4B, 6-pack or the like IT WILL NOT fit unless you have a recessed pan.
Re: Valley Plate w/ Stage 6 Heads [Re: Mr.Yuck] #1321494
10/18/12 12:23 PM
10/18/12 12:23 PM
Thanks everyone for the information. My starting foundation on this build is a 400 block. I'm looking at making my own valley plate with some 1/4" aluminum. Everything will be topped of with a Team "G" intake. I'll post pictures when I got it completed.
Re: Valley Plate w/ Stage 6 Heads [Re: dodgem_doug] #1321495
10/18/12 02:44 PM
10/18/12 02:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What block , B or RB , if it's a B , return the Valley plate and get the indy RB plate and modify it ...
Re: Valley Plate w/ Stage 6 Heads [Re: dodgem_doug] #1321496
10/18/12 04:40 PM
10/18/12 04:40 PM
Cincinnati OH
Bishop Offline
Bishop  Offline
Cincinnati OH
Doug
Call up Monicattti Chysler (248-439-0261) and order P4876847 its for a low deck with stage 6 heads, I baught one about a month ago and it was $60.15 to my door.
Brian
