Re: Can't get Motor and 4 Speed Tranny to mate up?
[Re: FC7AARcuda]
#1319718
10/13/12 03:10 PM
10/13/12 03:10 PM
Posts: 43,624 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Making normal assumptions here but I am sure you used a clutch alignment tool when you bolted the pressure plate on. Did you make sure that nothing was done to the pilot bushing? I had an issue once where there was way too much grease packed into the pilot bushing and the trans would not go all the way into the bushing. You got the trans in neutral? Is the throwout bearing moving freely on the input shaft bearing retainer?
JB Rhinehart, Realist
A-Body's RULE!
[Re: FC7AARcuda]
#1319721
10/13/12 04:23 PM
10/13/12 04:23 PM
Posts: 1,650 Harm City Md.
Dan Halen
Harm City Md.
I would NEVER try to put an engine in with a manual trans sitting in the car. Bolt them together first or install engine first! They're enough of a PIA getting them out that way.
[Re: FC7AARcuda]
#1319722
10/13/12 04:27 PM
10/13/12 04:27 PM
Rhinodart
Rhinotruck
Rhinotruck
I did use a clutch alignment tool. It slips in and out with no problem. I've tried installing the motor with the car in gear and in neutral. The through out bearing moves fine. The pressure plate is not far enough back to touch the bearing so it must be the pressure plate that is catching.
I'm trying to avoid pulling the trans because I would then have to pull the exhaust, driveshaft, shifter linkage, etc. That's my last resort if I can't get the engine on with the trans in the car.
I hear ya there. I am just getting ready to install a 340 in a 73 Cuda and will be doing the same thing you are shortly, so this post kinda helps me too before I start my install. I have put dozens of engines and 4-speeds together and have run into all kinds of issues, some that I posted above. The pressure plate should have nothing to do with the two mating together, it is usually the clutch disc that does that. If you moved the disc after installing it with tool then the trans will not mate.
A-Body's RULE!
[Re: Rhinodart]
#1319723
10/13/12 04:44 PM
10/13/12 04:44 PM
Posts: 621 Iowa
coronetville
Iowa
Is the pressure plate in the right way? Slide the motor in as far as you can get it to the transmission, than bolt 4 extra long bolts and adjust the bolts so that all four corners are square. You should be able to giggle either the motor or the transmission and it should slide right together. If it doesn't, try turning each bolt a little at a time and see if it will slide together that way. Do NOT use excessive force. If you can't get it together that way. I suggest your pilot bushing is too tight and needs to be reamed out.[It happens all the time} or something else is wrong and it will need to come apart.
[Re: FC7AARcuda]
#1319727
10/13/12 06:35 PM
10/13/12 06:35 PM
Posts: 1,899 MYRTLE BEACH SOUTH CAROLINA
ek3
i know you used the tool before, and it slides out "freely " however, loosen the pressure plate bolts ... insert alignment tool .. lift up " slightly " on the alignment tool while keeping the disc lifted / centered , cross tighten your pressure plate bolts. snug each one firmly in a pattern, then tq. to specs! the slightest mis-alignment feels like you hit a brick wall ! that is the issue. .. Bw.
[Re: 70HemiGTX]
#1319729
10/13/12 06:58 PM
10/13/12 06:58 PM
Posts: 926 MICHIGAN
BB65Barracuda
MICHIGAN
Wait a Minute!!! Your trying to stab the engine in the car with the 4 speed mounted in?? Dude, pull the trans back, mount the engine in place with the bell and clutch installed and then install the 4 speed. You will have a heck of a time if you plan on installing it any other way. Or even easier why not pull the trans and mount it to the engine outside of the car and drop it in as one piece and save yourself hours of frustration? Listen to Bobs66440!
1957 Power wagon wm300 original 10.000 mile truck, 1964 dodge Polara Convertible numbers matching
[Re: BB65Barracuda]
#1319730
10/13/12 07:45 PM
10/13/12 07:45 PM
Rhinodart
Rhinotruck
Rhinotruck
I have done it with the trans in the car quite a few times, if everything is in line then there is no issue. I quit using the plastic alignment tools years ago, have a nice Snap-On steel tool that comes with several different ends that screws that goes in the pilot bushing. I do agree with loosening up the pressure plate bolts, have had to do that before.
A-Body's RULE!
[Re: FC7AARcuda]
#1319731
10/14/12 02:01 AM
10/14/12 02:01 AM
Posts: 1,880 Out in Left Field, NY
bobs66440
With all the work and aggravation you're going through, it seems it would be much easier to do and you won't have to wrestle with it. Heck, the driveshaft takes about 15 minutes. The shifter is a pain admittedly, but I think it took me about 20-30 minutes max. I didn't have to remove my exhaust, I just dropped it down out of the way. I have an "H" pipe, but I split and sleeved it so it would be easier. I think the whole process was about 3 hours start to finish, not counting welding up new custom header pipes for the new headers, re-installing the carbs, radiator, hood, etc..
And I used the shorty headers, so I could install the engine with them BOLTED UP!
[Re: FC7AARcuda]
#1319735
10/16/12 10:55 PM
10/16/12 10:55 PM
Posts: 5,140 East Aurora (Buffalo) NY
RoadRunner
Here is a couple of things I have run against. First, the plastic alignment tool has some pretty loose tolarences. I usually just snug the pressure plate bolts enought to hold the disk, but loose enough to allow disk to slide. I'll install transmission then tighten the pressure plate bolts by rotating the engine. Second, I have run into a crank that was drilled for a 4 speed and had a bushing installed, but it wasn't deep enough. It was about a 1/4" to shallow.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
