Re: horn won't sound
[Re: PAINT IT BLACK]
#1318719
10/11/12 08:39 AM
10/11/12 08:39 AM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
Ground the wire under the center button.Ive foxed a few by taking the wheel off and cleaning the contact under the wheel.They have a tendency to get a ridge in them.With the wheel off you can see the contact on the wheel and the pieve that sticks up to contact it.First thing I would do is check the relay and the horns.Relay is easy.Has to have power and then gets a ground when you blow the horn.Power then should be at horns.You can test the horn by removing it and using the batt to activate it.Rocky
Chrysler Firepower
#1318720
10/11/12 12:32 PM
10/11/12 12:32 PM
RapidRobert
seperate the dangling electrical connector under the column and in the bulkhead half of the connector ground the horn wire (might be black but check) & see if the horn sounds. this'll tell you if the problem is in the steering wheel (likely as said) or upstream (check/clean the bulkhead 1st) then the horn relay. I would jump 12V to the horns and jump their cases' to batt neg to ground them but not likely both horns went out at the same time and horns are pretty reliable but it would be an easy first check
[Re: RapidRobert]
#1318721
10/12/12 07:09 AM
10/12/12 07:09 AM
therocks
Niles , Ohio
RR true about both quiting at the same time.But my 65 after it sits all winter at times both will quit.The I just tap them with a screwdriver handle a few times and they work.Thing is they are 40 years old and get used very little when I drive the car.Rocky
Chrysler Firepower
