I believe my Rimblow switch has finally crapped out. How might I simulate an activated switch? In other words, how do I get the horn to blow without using the Rimblow switch?
There is a backstory here that's too long to tell, so I don't need to know how to test the switch necessarily. I just need the horn to blow. Can I connect a 12V lead to the spade at the column, or what?
