904 torque convert problems #1318200
10/09/12 10:47 PM
10/09/12 10:47 PM
Canada
onig Offline OP
onig  Offline OP
Canada
Who is using a 904 trany in their race car and has had a converter hub/snout problem.
If so, what was the problem and what was the fix.
onig
69 Dart
Re: 904 torque convert problems [Re: onig] #1318201
10/09/12 11:01 PM
10/09/12 11:01 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i found a crack in my hub( corner of the pump gear slot). sent it to lupo. they welded on a chromemoly hub & rebalanced. u have to have the ring on the stator shaft machined off if there is one there. it restricts flow.
Re: 904 torque convert problems [Re: onig] #1318202
10/09/12 11:11 PM
10/09/12 11:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Cracked hubs are common on the 904... send it to a
conv company for repair
Re: 904 torque convert problems [Re: onig] #1318203
10/10/12 12:13 AM
10/10/12 12:13 AM
Albert Lea, MN
GTX5877 Offline
GTX5877  Offline
Albert Lea, MN
Need to index the bellhousing like a 4 speed or it can happen again.
1967 Dart GTS 426 Gen III Hemi
1968 Hemi Cuda 572 SS/AH Clone
1988 Chrysler LeBaron Coupe S/S
2003 Dodge Ram 1500 4dr SLT lowered
2012 Ram 1500 2wd Lowered
1970-1/2 Camaro Z-28
1974 VW Karman-Ghia
Re: 904 torque convert problems [Re: GTX5877] #1318204
10/10/12 12:15 AM
10/10/12 12:15 AM
Toronto
mshred Offline
mshred  Offline
Toronto
how would you do this with the automatic?
Re: 904 torque convert problems [Re: mshred] #1318205
10/10/12 01:10 AM
10/10/12 01:10 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The proper way is to use the case(empty) that you will
be running and index the pump housing with the dial
indicator then build the trans
Re: 904 torque convert problems [Re: onig] #1318206
10/10/12 11:53 AM
10/10/12 11:53 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
My converters now use A500 front pump gears and converter snouts. A500's have flats to drive pump gears and eliminate the crack issue. This is the best fix. Have your converter switched to this drive and use late A500 pump gears.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: 904 torque convert problems [Re: Evil Spirit] #1318207
10/10/12 04:36 PM
10/10/12 04:36 PM
Canada
onig Offline OP
onig  Offline OP
Canada
Will the A500 pump gears just drop in the 904 pump housing?
69 Dart
Re: 904 torque convert problems [Re: mshred] #1318208
10/10/12 04:37 PM
10/10/12 04:37 PM
Canada
onig Offline OP
onig  Offline OP
Canada
I was also wondering this myself.
69 Dart
Re: 904 torque convert problems [Re: onig] #1318209
10/10/12 04:40 PM
10/10/12 04:40 PM
Canada
onig Offline OP
onig  Offline OP
Canada
So are these cracked hubs due to alignment/indexing issues or are there other reasons.
69 Dart
Re: 904 torque convert problems [Re: onig] #1318210
10/10/12 05:43 PM
10/10/12 05:43 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
A500 pump gears are the best solution in my mind. Another solution that turbo action uses is to make the converter snout thicker. However this requires the stator support lube dam to be machined off.
I don't think it has anything to do with indexing. There isn't an inherant problem with 904's that 727's wouldn't have. The issue is the diameter of the converter snout (small), that crack from the pump gear load. My guess it happens in race cars more because of the increased pump pressure.
Re: 904 torque convert problems [Re: dizuster] #1318211
10/10/12 05:44 PM
10/10/12 05:44 PM
Toronto
mshred Offline
mshred  Offline
Toronto
so just changing the pump gears to A-500 stuff and getting a converter with an A-500 snout is the solution? Is there any issue with dropping the A-500 pump gears into the 904? or is it a direct swap?
Re: 904 torque convert problems [Re: onig] #1318212
10/10/12 05:56 PM
10/10/12 05:56 PM
Toronto
mshred Offline
mshred  Offline
Toronto
oops, looks like I asked the same question as you
Re: 904 torque convert problems [Re: mshred] #1318213
10/11/12 12:17 AM
10/11/12 12:17 AM
Toronto
mshred Offline
mshred  Offline
Toronto
anybody have the answer for this? my local transmission parts house has pump gears 78-92 pump gears (2 lugs style on inner gear) and pump gears for 93-04 (2 flats style on inner gear), the latter which I am assuming for the A-500. If these will just drop right in, I should be good to go.
Can anyone confirm this?
Re: 904 torque convert problems [Re: mshred] #1318214
10/11/12 08:50 AM
10/11/12 08:50 AM
NC USA
U
ultimatelenny Offline
U
NC USA
I recently built a few 8" converters for the 904 with the A500 pump. You could give Chris Andrews a call at Andrews Racing in Colorado, his number is 720-939-4896. He has done a few of these with good results. Hope this helps you out.
Lenny Croteau www.ultimateconverter.com Phone 704-892-6837 Fax 704-892-6880
Re: 904 torque convert problems [Re: ultimatelenny] #1318215
10/11/12 12:26 PM
10/11/12 12:26 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Yes they just drop right in. You just need the converter updated.
Re: 904 torque convert problems [Re: dizuster] #1318216
10/11/12 01:09 PM
10/11/12 01:09 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
they also have a replacement snout that is not only thicker but has a larger radius at the bottom of the drive slots, that is how my new one is done, but the newer style with the flats is interesting to me, I believe Ford used that style for years.
Re: 904 torque convert problems [Re: dartman366] #1318217
10/11/12 11:14 PM
10/11/12 11:14 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
This is another one of the best kept secrets that for some reason nobody seems to have caught on to. I know I've personally posted this quite a few times myself. These 904/A500 pump gears with the flats instead of the drive tabs came out in the early 90's.
One of the inherent flaws of the lugs can be partially corrected - by shimming the converter back into the pump, so the tabs on the pump gear go deeper into the slots on the converter pump drive (snout). Most of the drive hubs I saw cracked or broken showed that the lugs were towards the outside end of the slot. While I try to make it so you only pull the converter forward about 1/16" to the flexplate, sometimes at that depth the weld that holds the drive stub on is poor and will tear up the seal.
And as others have said - there are redesigned (tab style) drive stubs and pump gears, but they are more pricey than the stock "flats" style parts.
Re: 904 torque convert problems [Re: Evil Spirit] #1318218
10/11/12 11:18 PM
10/11/12 11:18 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Thanks for all this information guys! I have searched high and low for this stuff and never found anything about the different pump gears mentioned, or the different updated hub. When I order the converter I will more than likely just go the A-500 hub route with the later pump gears, especially if they almost totally eliminate the broken hub issue that the standard style seems to have
Re: 904 torque convert problems [Re: mshred] #1318219
10/11/12 11:24 PM
10/11/12 11:24 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
A bit of advice - have a set of the flat drive style gears in your hands before you have the converter built for them. There have been times my supplier hasn't been able to get them - they were back/ordered.
