904 torque convert problems
#1318200
10/09/12 10:47 PM
10/09/12 10:47 PM
Posts: 361 Canada
onig
Canada
Who is using a 904 trany in their race car and has had a converter hub/snout problem. If so, what was the problem and what was the fix.
Thanks onig
69 Dart
Re: 904 torque convert problems
[Re: onig]
#1318203
10/10/12 12:13 AM
10/10/12 12:13 AM
Posts: 148 Albert Lea, MN
GTX5877
Albert Lea, MN
Need to index the bellhousing like a 4 speed or it can happen again.
1967 Dart GTS 426 Gen III Hemi 1968 Hemi Cuda 572 SS/AH Clone 1988 Chrysler LeBaron Coupe S/S 2003 Dodge Ram 1500 4dr SLT lowered 2012 Ram 1500 2wd Lowered 1970-1/2 Camaro Z-28 1974 VW Karman-Ghia
[Re: GTX5877]
#1318204
10/10/12 12:15 AM
10/10/12 12:15 AM
Posts: 3,415 Toronto
mshred
Toronto
how would you do this with the automatic?
[Re: mshred]
#1318205
10/10/12 01:10 AM
10/10/12 01:10 AM
Posts: 52,972 Romeo MI
MR_P_BODY
The proper way is to use the case(empty) that you will be running and index the pump housing with the dial indicator then build the trans
[Re: onig]
#1318209
10/10/12 04:40 PM
10/10/12 04:40 PM
Posts: 361 Canada
onig
Canada
So are these cracked hubs due to alignment/indexing issues or are there other reasons.
69 Dart
[Re: dizuster]
#1318211
10/10/12 05:44 PM
10/10/12 05:44 PM
mshred
Toronto
A500 pump gears are the best solution in my mind. Another solution that turbo action uses is to make the converter snout thicker. However this requires the stator support lube dam to be machined off.
I don't think it has anything to do with indexing. There isn't an inherant problem with 904's that 727's wouldn't have. The issue is the diameter of the converter snout (small), that crack from the pump gear load. My guess it happens in race cars more because of the increased pump pressure.
so just changing the pump gears to A-500 stuff and getting a converter with an A-500 snout is the solution? Is there any issue with dropping the A-500 pump gears into the 904? or is it a direct swap?
[Re: onig]
#1318212
10/10/12 05:56 PM
10/10/12 05:56 PM
mshred
Toronto
My converters now use A500 front pump gears and converter snouts. A500's have flats to drive pump gears and eliminate the crack issue. This is the best fix. Have your converter switched to this drive and use late A500 pump gears.
Will the A500 pump gears just drop in the 904 pump housing?
oops, looks like I asked the same question as you
[Re: dizuster]
#1318216
10/11/12 01:09 PM
10/11/12 01:09 PM
dartman366
Mt. Vernon, Ohio
they also have a replacement snout that is not only thicker but has a larger radius at the bottom of the drive slots, that is how my new one is done, but the newer style with the flats is interesting to me, I believe Ford used that style for years.
[Re: dartman366]
#1318217
10/11/12 11:14 PM
10/11/12 11:14 PM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
This is another one of the best kept secrets that for some reason nobody seems to have caught on to. I know I've personally posted this quite a few times myself. These 904/A500 pump gears with the flats instead of the drive tabs came out in the early 90's.
One of the inherent flaws of the lugs can be partially corrected - by shimming the converter back into the pump, so the tabs on the pump gear go deeper into the slots on the converter pump drive (snout). Most of the drive hubs I saw cracked or broken showed that the lugs were towards the outside end of the slot. While I try to make it so you only pull the converter forward about 1/16" to the flexplate, sometimes at that depth the weld that holds the drive stub on is poor and will tear up the seal.
And as others have said - there are redesigned (tab style) drive stubs and pump gears, but they are more pricey than the stock "flats" style parts.
Free advice and worth every penny... Factory trained Slinky rewinder.........
