PGClassic slotted tips didn't hold the red paint either #1316541
10/07/12 11:12 AM
10/07/12 11:12 AM
Valencia, España
NachoRT74 Offline OP
Valencia, España
I made a roadtrip on an interstate highway. Going down from my city ( I live at 900-1000 meters height city ) to a 500 meters city the red paint hold the heat and exhaust fumes mixture. I didn't need to give a lot of gas to the car though.
But now, going up for 1 hour, 80 MPH average when I had to give more gas and produce more heat due the hill, the paint didn't hold
what to use now ?
I have heard powdercoating
Re: PGClassic slotted tips didn't hold the red paint either [Re: NachoRT74] #1316542
10/07/12 11:40 AM
10/07/12 11:40 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i'll go out on a limb here and say most likely the tips are painted red AFTER they are chromed and there's no way it's gonna stick. i highly doubt its a heat issue too much since the exaust has cooled quite a bit by the time it hits the tips. that said it's mostly the constant exaust movement and the increased heat ON a chromed surface that is doing it.
Re: PGClassic slotted tips didn't hold the red paint either [Re: mikemee1331] #1316543
10/07/12 11:50 AM
10/07/12 11:50 AM
Valencia, España
Valencia, España
PG Classic are stainless steel
If I have to powdercoat, would need to cut the welding points to remove the inner pipe, and then reassembly.
Re: PGClassic slotted tips didn't hold the red paint either [Re: NachoRT74] #1316544
10/07/12 12:04 PM
10/07/12 12:04 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
this will sound silly but fingernail polish sticks really well on stainless.
Re: PGClassic slotted tips didn't hold the red paint either [Re: NachoRT74] #1316545
10/07/12 02:38 PM
10/07/12 02:38 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Why? You can mask the areas that don't get powder, they have tape for powder coating that lives in the oven... The powder is attracted by an electrical charge so when fogged it will find any exposed metal... And personally before powder coating I would mask the polished areas one with masking tape then a second time with duct tape & run then through my blast cabinet... A little etching of the surfaces that are to be powder coated should help...
Re: PGClassic slotted tips didn't hold the red paint either [Re: 1_WILD_RT] #1316546
10/07/12 03:05 PM
10/07/12 03:05 PM
Valencia, España
Valencia, España
mmmm... dunno... will check further in that. I'm worried about get inside the slots the best as posible.
beside that, to powdercoat and stick well, needs to be REALLY GOOD cleaned
I wouldn't care to dissasemble it anyway because the pieces I got are not really aligned. The outer SS finish pipe is not aligned with the hanger so if you look at the tip I fit on passenger side it looks like pointing out.
like this guy
http://www.clicmas1.com/wp-content/uploads/2011/08/Cani_bizco.jpeg
LOL
do you think REALLY powdercoat holds heat and exhaust fumes ?
if so... it can be brilliant finish or need to be matte ?
I think found some guys offering the service locally.
Re: PGClassic slotted tips didn't hold the red paint either [Re: NachoRT74] #1316547
10/07/12 03:44 PM
10/07/12 03:44 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Powder coat is baked at 400 degrees so the back end of the exhaust should be fine, near the manifolds would require high temp powder which is hard to source & spendy but the tips shouldn't get over 200 degrees which is easily within the abilities of regular powder..... Like I mentioned powder will cover, you can be spraying the face of a part & the material that oversprays the edge will attach itself to the rear of the part.... Durability wise Gloss is usually better...
Re: PGClassic slotted tips didn't hold the red paint either [Re: 1_WILD_RT] #1316548
10/07/12 08:07 PM
10/07/12 08:07 PM
Valencia, España
Valencia, España
I'm wondering if these tips are also already powdercoated. The red finish is chiping/peeling off like if was somekind of metallic skin, like a damaged chrome on a bumper. Dunno if the powdercoat fits like this
some areas are kinda goldish, then the rest black burnt
if you make the close up, will notice some cracks between slots. Inside the pipe you see a clear area, thats the exposed pipe. The paint there peeled off like I described
same tip on opposite side... the gray areas on slotted areas is the paint peel off.
the other side pipe doesn't looks so bad but still bad. ( it can be noticed on the second pic )
wondering if really is temp issue or fumes polution issue ( mixture/chemical related ), being maybe passenger side bank on engine burning worst than driver side
Re: PGClassic slotted tips didn't hold the red paint either [Re: NachoRT74] #1316549
10/07/12 10:27 PM
10/07/12 10:27 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
That's awful!!! For what those things cost, you should NOT have to worry about that stuff coming off! They look like 30 year old tips! Now I'm even more glad that I made the decision to not use tips on my car.
Re: PGClassic slotted tips didn't hold the red paint either [Re: pinkduster] #1316550
10/08/12 09:25 AM
10/08/12 09:25 AM
Valencia, España
Valencia, España
pic taken 1 week ago
now wondering... how much last longed original tips on drivers cars back in the days like they were( like my car useage ), even on highway useage!
and what kind of paint was used on them?
( note, SS on mine is pristine, just dirty )
Re: PGClassic slotted tips didn't hold the red paint either [Re: NachoRT74] #1316551
10/08/12 11:44 AM
10/08/12 11:44 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I bought some chrome tips off ebay a few years back and I painted the inside black thru the slots in the tips. The paint never came off or peeled. I just used regular spray can paint I bought at the hardware store. I don`t think the heat caused your peeling problem.
Re: PGClassic slotted tips didn't hold the red paint either [Re: mopars4ever] #1316552
10/08/12 12:10 PM
10/08/12 12:10 PM
Ohio
rck850 Offline
rck850  Offline
Ohio
I've had BE/A slotted tips on the back of my 360 Roadrunner for six years now. Other than being a pain to clean, I have not had any problems.
Re: PGClassic slotted tips didn't hold the red paint either [Re: NachoRT74] #1316553
10/08/12 12:32 PM
10/08/12 12:32 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Re-worked a set of OEM Charger tips...
Eliminated the stock 'insert', fabbed a new one out of aluminized...
Straight shot...No more 'flange' to rust-out...
Had 'em re-chromed, taped 'em off and shot the inserts with orange engine enamel...
15 years...No issues...
Re: PGClassic slotted tips didn't hold the red paint either [Re: RSNOMO] #1316554
10/08/12 01:04 PM
10/08/12 01:04 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
Glass bead the area you are going to paint first. The paint will then stick to the chrome.
Re: PGClassic slotted tips didn't hold the red paint either [Re: Steve340] #1316555
10/08/12 01:59 PM
10/08/12 01:59 PM
Valencia, España
Valencia, España
I'm pretty sure will dissasemble them
ok, for those who say didn't got a problem... HAVE YOU REALLY USED YOUR CARS ? my tips hold the finish for a week, but just driving around the city, but things changed going interstate, as I described, returning to my city
Engine enamel was the first try on my tips, what came out on the first return to my city
so if you think heat is not the problem... what could be ? exaust fumes due mixture ?
Re: PGClassic slotted tips didn't hold the red paint either [Re: NachoRT74] #1316556
10/08/12 08:37 PM
10/08/12 08:37 PM
Harrisburg, Pa.
screamindriver Online content
screamindriver  Online Content
Harrisburg, Pa.
I'm just ending the road runner's second season on the stainless set I bought{about a thousand miles a year}...No evidence of the paint peeling yet...And I've got it tuned very well so there's no black soot flying out and covering the paint... ...Strange I was just thinking how well they've been holding up the other day..
Re: PGClassic slotted tips didn't hold the red paint either [Re: NachoRT74] #1316557
10/09/12 02:54 PM
10/09/12 02:54 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
15 years...
20,000 miles...
Holding up well...
If yer blowing off paint that soon, you got adhesion issues...
