Factory mis stamped engine/trans engine code? #1316271
10/06/12 03:40 PM
10/06/12 03:40 PM
Virginia
mopars4life Offline OP
Virginia
My charger is numbers matching but the factory misstamped the engine and trans as an F code vice H code. All the other numbers match the car perfectly and the car is an H code 69 383 magnum 4 speed car. Was this something that was common? I know that the QA was lacking back then but just thought I'd check with others on this since it was surprising. The date code on the engine matches the cars build date as well.
Re: Factory mis stamped engine/trans engine code? [Re: mopars4life] #1316272
10/06/12 03:48 PM
10/06/12 03:48 PM
Castlegar, BC, Canada
That AMC Guy Offline
I had a '68 New Yorker once that I traded to a friend. He pulled the engine for a '68 Charger he was working on. Now, I'm not familiar with 1968 engine stampings, but he told me the engine was stamped to be a TNT/Magnum engine, but that letter was crossed out and the correct letter for the 350-horse 440 followed.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: Factory mis stamped engine/trans engine code? [Re: mopars4life] #1316273
10/06/12 06:54 PM
10/06/12 06:54 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Is your Charger a pre-Jan. '69 car with the full VIN# stamped on it?
& you're saying it has XP29F9B123456 stamped on a 383 block & your VIN# is XP29H9B123456?
I've seen a 440 block with the same deal - GOT a pic? I think I have a pic of the 440, I'll see if I can find it. (bet they're same day, on the line)
Re: Factory mis stamped engine/trans engine code? [Re: 6bblgt] #1316274
10/06/12 07:58 PM
10/06/12 07:58 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The 413 in my 64 300 was stamped T for 63, then over stamped with a V for 64. Everything about the engine was 63, 4 bolt valve covers, casting numbers, etc.
Don't be the exception.
Re: Factory mis stamped engine/trans engine code? [Re: Supercuda] #1316275
10/07/12 08:57 AM
10/07/12 08:57 AM
sw chicago
RAH Offline
RAH  Offline
sw chicago
My 1968 dodge Hemi charger has original engine and trans. . the person who stamped the vin on the engine and trans missed one digit on both the engine ant trans vin XS29J8b3062xx engine and trans are stamped 8b362xx the 0 was missed on the engine and trans.
Re: Factory mis stamped engine/trans engine code? [Re: RAH] #1316276
10/07/12 11:24 AM
10/07/12 11:24 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
I have a 68 hemi 4-speed that is missing the same digit, 5th from the end, same plant.
Re: Factory mis stamped engine/trans engine code? [Re: 4406bbl] #1316277
10/07/12 11:40 AM
10/07/12 11:40 AM
Virginia
Virginia
Interesting - I had a feeling that there would be others. You'd think that they would be a little more particular with it. To answer an earlier question - it does have the full VIN on it. I was thinking of selling the car but want to hold on it - it has a lot of rust but is a nice color and options combo.
Re: Factory mis stamped engine/trans engine code? [Re: Supercuda] #1316278
10/09/12 03:17 PM
10/09/12 03:17 PM
dogdays Offline
dogdays  Offline
To: supercuda, the stamp on the Engine ID pad only tells you how the engine was built and for which model year. So your '64 left the factory with a leftover '63 engine.
Chrysler had terrible inventory control and they had a habit of finding a bunch of blocks or heads or engines that had been "hiding" in the corner of a warehouse somewhere and putting them in the next car down the line. Remember, these are the guys that built engines with one or more rod or main journals, piston or lifter with repair sizes.
They salvaged everything they could.
R.
Re: Factory mis stamped engine/trans engine code? [Re: mopars4life] #1316279
10/11/12 05:22 PM
10/11/12 05:22 PM
CT
3
340KID Offline
340KID  Offline
CT
on my 1972 Cuda 340 - the vin plate is coded BS23G4xxxxx, while it should be BS23H4xxxxx
vin says it's a 318 while i have the original 340 in it, build sheet also denotes BS23G but all the specs point to the 340 and the vin numbers agree on the block
Re: Factory mis stamped engine/trans engine code? [Re: 340KID] #1316280
10/11/12 05:39 PM
10/11/12 05:39 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
What's the fender tag say?
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Factory mis stamped engine/trans engine code? [Re: 340KID] #1316281
10/11/12 06:43 PM
10/11/12 06:43 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
both those examples would be 1974 GOT PICS?
Re: Factory mis stamped engine/trans engine code? [Re: 6bblgt] #1316282
10/11/12 07:07 PM
10/11/12 07:07 PM
DPelletier Offline
DPelletier  Offline
yep, something fishy there...
Re: Factory mis stamped engine/trans engine code? [Re: DPelletier] #1316283
10/11/12 07:37 PM
10/11/12 07:37 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Well, it is a Cuda.
Re: Factory mis stamped engine/trans engine code? [Re: 6bblgt] #1316284
10/12/12 12:04 AM
10/12/12 12:04 AM
CT
3
340KID Offline
340KID  Offline
CT
Why 1974 ?
Re: Factory mis stamped engine/trans engine code? [Re: 340KID] #1316285
10/12/12 12:18 AM
10/12/12 12:18 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Why 1974 ?
The 4 in that position is the model year, 1974.
But - The VIN you listed - "BS23H4xxxxx" is two digits short. So, what is the whole thing?
Re: Factory mis stamped engine/trans engine code? [Re: Alaskan_TA] #1316286
10/12/12 12:22 AM
10/12/12 12:22 AM
CT
3
340KID Offline
340KID  Offline
CT
Just checked BS23G2B 4xxxxx
I forgot the 2B
Re: Factory mis stamped engine/trans engine code? [Re: 340KID] #1316287
10/12/12 12:31 AM
10/12/12 12:31 AM
CT
3
340KID Offline
340KID  Offline
CT
I forgot the 2B
I need to pull build sheet , but I recall engine code was E55
Re: Factory mis stamped engine/trans engine code? [Re: 340KID] #1316288
10/12/12 12:58 AM
10/12/12 12:58 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
G & H are right next to each other on a keyboard, so it would be an easy typo. Can you get clear photos of the engine & transmission VIN stamps & the engine serial number on the front of the block? It is right below the driver's side head surface.
