Gas tanks and sending units-Which ones to use??? #1316051
10/06/12 12:09 AM
10/06/12 12:09 AM
Dayton, WA
wesgtx440 Offline OP
Dayton, WA
Need to replace the tank, sending unit and fuel line on my GTX and looking for some input on which route to go. Thanks!
Re: Gas tanks and sending units-Which ones to use??? [Re: wesgtx440] #1316052
10/06/12 01:25 AM
10/06/12 01:25 AM
Long Island, NY
mjb765 Offline
mjb765  Offline
Long Island, NY
I just went through several different sending units. Bought 1 from kramer Automotive and was told that is the best since it is made by the same vendor that Chrysler used....it didn't read right. Ended up with a $40 unit from Jegs that works perfectly! And it looks just like the one that came out of the car. I checked when I ordered it to make sure it was returnable--just in case....lucky for me I didn't have to send this one back.
Re: Gas tanks and sending units-Which ones to use??? [Re: wesgtx440] #1316053
10/06/12 01:42 AM
10/06/12 01:42 AM
Sonoran desert, Arizona, USA
moparjo68 Offline
moparjo68  Offline
As far as sending units go, forget it. Just invest in a wooden stick, make marks on the stick for full, another mark for half way, and then another mark for I'd better get to a gas station. Keep wooden stick handy in trunk.
Sorry, I got carried away. Type sending units into search. You will learn very quickly that aftermarket sending units are........well, to say the least, very inaccurate. Its a crap shoot on which one to try and which one to stay away from.
Re: Gas tanks and sending units-Which ones to use??? [Re: moparjo68] #1316054
10/06/12 09:35 AM
10/06/12 09:35 AM
indiana
mcmopars Offline
mcmopars  Offline
indiana
you hit that on the head.we can put men on the moon but can make a sender to correctly work.why dont i design one and make a million.geez
Re: Gas tanks and sending units-Which ones to use??? [Re: moparjo68] #1316055
10/06/12 10:10 AM
10/06/12 10:10 AM
Long Island, NY
mjb765 Offline
mjb765  Offline
Long Island, NY
Re: Gas tanks and sending units-Which ones to use??? [Re: mjb765] #1316056
10/07/12 09:33 AM
10/07/12 09:33 AM
Palmyra, NY
63stabamatic Offline
Palmyra, NY
Back in 2003 I got a new tank and sending unit from Quanta, (Gas tanks.com). I had to send both back, the tank was really beat-up and the sending unit was intermittent when running through the range with an Ohm meter attached. The replacement tank and sending unit were fine and have been working for 9 years now.
Re: Gas tanks and sending units-Which ones to use??? [Re: 63stabamatic] #1316057
10/07/12 01:42 PM
10/07/12 01:42 PM
Dayton, WA
Dayton, WA
Thanks for all the input. Leaning torwards trying the Spectra Premium sending unit and see what happens!
Re: Gas tanks and sending units-Which ones to use??? [Re: wesgtx440] #1316058
10/07/12 04:23 PM
10/07/12 04:23 PM
moparjo68 Offline
moparjo68  Offline
Just keep in mind that if you get a new sending unit and it works perfectly.........straight out of the box, with no tweeking. Then rush to your nearest lottery retailer and buy some powerball tickets. Because you're one lucky sun of a gun.
My sending unit, which was Made in Mexico Mopar unit; when I did the Ohms sweep with the arm (outside the tank), it read correctly. But inside the tank was a different story. My readings were approx. a quarter of a tank off. When the tank was full, the gauge read barely 3/4 full.
So I bent the pick up tube in the down direction (right behind the circular metal plate that goes flush against the tank), tweeked it a couple more times, and NOW it reads correctly. As stated earlier, WHY IS IT SO HARD TO BUY A DECENT FULL SENDING UNIT???
Re: Gas tanks and sending units-Which ones to use??? [Re: wesgtx440] #1316059
10/07/12 06:10 PM
10/07/12 06:10 PM
Central TX
roe Offline
roe  Offline
Central TX
I mention this everytime I see one of these threads but I picked up a Spectre unit from Autozone and it works perfectly. I didnt have to bend anything, and my readings are pretty spot on. When I fill up it reads just under the full line, almost touching it. So I have a very small built in "reserve"
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Gas tanks and sending units-Which ones to use??? [Re: roe] #1316060
10/07/12 06:16 PM
10/07/12 06:16 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
copy and paste is YOUR friend!
Re: Gas tanks and sending units-Which ones to use??? [Re: mikemee1331] #1316061
10/07/12 06:20 PM
10/07/12 06:20 PM
Central TX
roe Offline
roe  Offline
Central TX
Edit: I should mention that I did run a nice fat dedicated ground wire from the frame to the sending unit at the suggestion of some here, it's a much more solid ground than the factory one. And I also pulled the connector apart that's behind the driverside kickpanel. The one that connects your sending unit to your gauge. I cleaned it of rust/corrosion, put dielectric grease and closeout back up.
Re: Gas tanks and sending units-Which ones to use??? [Re: roe] #1316062
10/07/12 07:06 PM
10/07/12 07:06 PM
michigan woods
imfixinmopars426 Offline
michigan woods
spectra/premium is my favorite,and the rest is junk....mike
Re: Gas tanks and sending units-Which ones to use??? [Re: roe] #1316063
10/09/12 02:36 PM
10/09/12 02:36 PM
Iowa
GreenBird Offline
GreenBird  Offline
Iowa
Sorry to hijack the thread, but can you explain more about the connector behind the driver kickpanel? My gauge does not work and I thought I had eliminated all possibilities except a bad circuit board. But I did not do anything behind the kickpanel. What does the wiring look like behind the kickpanel?
Re: Gas tanks and sending units-Which ones to use??? [Re: GreenBird] #1316064
10/09/12 02:50 PM
10/09/12 02:50 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
YMM?
There are many harnesses in muscle car era vehicles. The underdash harness, the engine harness the front lighting harness and the rear harness. Each connect to others. The obvious ones are the bulkhead connectors at the driver's side firewall. The rear harness connects at the driver's side kick panel.
Here's a Valiant picture I found online showing how the harness is routed.
Re: Gas tanks and sending units-Which ones to use??? [Re: GreenBird] #1316065
10/09/12 02:52 PM
10/09/12 02:52 PM
Central TX
roe Offline
roe  Offline
Central TX
I don't know if it's the same in your car, mine is a 71 b body. I just traced my wire from the sending unit up to the dash, and found that there was a connector behind my drivers side kick panel that goes up to the dash. My guess is that it's there to simply allow u to replace the wire if necessary.
Re: Gas tanks and sending units-Which ones to use??? [Re: RodStRace] #1316066
10/09/12 02:54 PM
10/09/12 02:54 PM
Iowa
GreenBird Offline
GreenBird  Offline
Iowa
YMM?
Thanks. 69 Road Runner. I will pull off the kickpanel and take a look.
Re: Gas tanks and sending units-Which ones to use??? [Re: GreenBird] #1316067
10/09/12 03:02 PM
10/09/12 03:02 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Re: Gas tanks and sending units-Which ones to use??? [Re: GomangoCuda] #1316068
10/09/12 04:10 PM
10/09/12 04:10 PM
Iowa
GreenBird Offline
GreenBird  Offline
Iowa
Yeah, that photo about sums it up.
