8.75 axle bearings anyone have a part # #1315980
10/05/12 09:50 PM
10/05/12 09:50 PM
this world
drifter Offline OP
drifter  Offline OP
this world
For the 8.75 rear i'm looking for a part # for the good axle bearings the non adjustable ones mopar i think calls them there green bearings does anyone have a bearing manufacture part #
Re: 8.75 axle bearings anyone have a part # [Re: drifter] #1315981
10/05/12 09:57 PM
10/05/12 09:57 PM
MD
floyd Online content
floyd  Online Content
MD
Re: 8.75 axle bearings anyone have a part # [Re: floyd] #1315982
10/06/12 12:56 AM
10/06/12 12:56 AM
this world
drifter Offline OP
drifter  Offline OP
this world
yeah thats it i better buy the kit the retainers look like there a heavier piece then the org. thanks
Re: 8.75 axle bearings anyone have a part # [Re: drifter] #1315983
10/06/12 07:14 AM
10/06/12 07:14 AM
scratchnfotraction Offline
the mopar greens with the crimped on retainer are not the better ones.IIRC
the M-400 is the better bearing IIRC
check "DoctorDiff" here on mopars, he has the best deals on the right bearings at 65$ a set.
and he can fix you up with all of the 8 3/4 needs you may have.
great member to deal with.
IMHO,the mopar bearing is not the ones to use.
I am on my 2nd set of greens,been running them since 00' and replaced them again in 08'
daily driver with lots of street duty
FYI... you can run them with or with out the inner axle seals,i ran seals with the first set and no seals on 2nd set. no leaks so far.
also there is talk about the thrust block and no end play adjustments.
if you have a suregrip with the removable buttons.. remove them. if it has a floating thrust block open or suregrip it can stay.
I run a 742 open with no thrust block( I removed it) and run the 489 sg with the thrust block in place.
I have had no trouble with it either way so far.
endplay adjustment with stock bearings is not hard or time consuming but it is one less thing to do when swaping gears at the track. just bolt it together ond go.
Re: 8.75 axle bearings anyone have a part # [Re: drifter] #1315984
10/06/12 02:19 PM
10/06/12 02:19 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
"Good" is in the eye of the beholder.
