Has anybody ran those Hughes rocker arms #1314996
10/04/12 02:33 PM
10/04/12 02:33 PM
Portage,michigan
B3422W5 Online content OP
B3422W5  Online Content OP
Portage,michigan
The US made ones they are selling on any smallblock standard head stuff that has some spring pressure?
One minute i am thinking old school, the next minute Gen 3 hemi
But as i am old, i think i have an idea what i want to do with my Demon
http://www.hughesengines.com/Index/produ...mp;partid=27161
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Has anybody ran those Hughes rocker arms [Re: B3422W5] #1314997
10/04/12 03:03 PM
10/04/12 03:03 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
I have em there very descent....would i use em if i had to rev it 7500 every pass..um no.
Re: Has anybody ran those Hughes rocker arms [Re: fishy340] #1314998
10/04/12 03:09 PM
10/04/12 03:09 PM
Portage,michigan
Portage,michigan
Roller or flat tappet, and what do you not like about them?
1.41 best 60 foot
6.56 at 104.17
Re: Has anybody ran those Hughes rocker arms [Re: B3422W5] #1314999
10/04/12 03:12 PM
10/04/12 03:12 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
I use same brand in a bb stroker whit roller cam and i give them
/Pat
Re: Has anybody ran those Hughes rocker arms [Re: Mopar Guy] #1315000
10/04/12 03:55 PM
10/04/12 03:55 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Have them, love them, and wouldn't hesitate to turn them to 7500rpm.... The are very nice quality and I have never heard of a problem with them... Mind you my cams have been small compared to others here, but I wouldn't change them even if I had crazy solid roller setup going on
Re: Has anybody ran those Hughes rocker arms [Re: B3422W5] #1315001
10/04/12 04:37 PM
10/04/12 04:37 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
After talking(or should I say, TRYING to talk) to 'em on the phone...
NEVER AGAIN...
Went with Harland's and ain't looking back...
Re: Has anybody ran those Hughes rocker arms [Re: RSNOMO] #1315002
10/04/12 06:04 PM
10/04/12 06:04 PM
Renton Washington
Triple Threat Offline
Renton Washington
NEVER AGAIN...
This about sums up my business dealings with Hughes.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Has anybody ran those Hughes rocker arms [Re: RSNOMO] #1315003
10/04/12 06:06 PM
10/04/12 06:06 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I've been running them on my small block for 8 or 9 years. At first with Hughes 1111 springs and now with Comp 930 springs.....I think. I had to grind the pi$$ out of them to clear the Comp spring because of the installed height and diameter. They've been ran for three years like this with no issues .
Re: Has anybody ran those Hughes rocker arms [Re: fishy340] #1315004
10/04/12 07:33 PM
10/04/12 07:33 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
After askin the builder if they would be ok on my motor i have now...he damn near lost his drink out his nostrils...they are ok for a 500hp type deal
Re: Has anybody ran those Hughes rocker arms [Re: fishy340] #1315005
10/04/12 08:36 PM
10/04/12 08:36 PM
BPE Offline
BPE  Offline
Don,
Take this for what it is, but may be worth reading. I know they are not going to to put things on their site that doesn't make them look good. I'm going to run the offset rockers on my current build but they are not treated.
http://www.hughesengines.com/TechArticles/2cryogenicallytreatedrockerarms.php
Rod
Re: Has anybody ran those Hughes rocker arms [Re: BPE] #1315006
10/04/12 08:47 PM
10/04/12 08:47 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
And that got u to buy them? Well best wishes
Re: Has anybody ran those Hughes rocker arms [Re: RSNOMO] #1315007
10/04/12 08:48 PM
10/04/12 08:48 PM
PA
moparacer Offline
moparacer  Offline
PA
NEVER AGAIN...
You too? I just called them earlier in the week and I was a little put off by the attitude to say the least.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Has anybody ran those Hughes rocker arms [Re: moparacer] #1315008
10/04/12 08:58 PM
10/04/12 08:58 PM
Portage,michigan
Portage,michigan
Thanks Rod
Yeah I had read that a while back, regards the treating.
I know these particular rockers are different than the I believe it was Probe stuff they used to carry or maybe still do.
Just looking at what options are out there for roller cams on stock style heads that don't require clearancing and can hold up to probably 550-600 spring pressures
The HS stuff doesn't impress me and requires being whittled on to run 1.55 springs from what I have heard.
1.41 best 60 foot
6.56 at 104.17
Re: Has anybody ran those Hughes rocker arms [Re: B3422W5] #1315009
10/04/12 09:07 PM
10/04/12 09:07 PM
California
Mad Dart Offline
Mad Dart  Offline
California
Yes I have ran them. 410 SB, 4spd. Revved it up all day to 7200RPM. They work well. This was with as Solid Flat Tappet though, 262@50 w/.624 Lift. They held the valve adjustment very well, hardly ever needed to adjust them and if so only a few exhaust valves. Was using Manton Ball Cup push Rods, oil thru on LA Heads. Pressureized oil on the ball and cup. Was also running Johnson Oil through EMD Lifters. FWIW
Re: Has anybody ran those Hughes rocker arms [Re: moparacer] #1315010
10/04/12 09:09 PM
10/04/12 09:09 PM
NEVER AGAIN...
Really!? I have NEVER heard that before...
Hughes and Indy. Where customer service is #1,356. Right on the priority list after cleaning the toilets.
Re: Has anybody ran those Hughes rocker arms [Re: B3422W5] #1315011
10/04/12 09:17 PM
10/04/12 09:17 PM
BPE Offline
BPE  Offline
FWIW I purchased the SB offset rockers as kind of an experiment so we could open up the pushrod pinch to slow air speed and gain a little port volume. I don't know of any SBM rockers for a factory type head that isn't going to require some clearancing for that size spring.
Rod
Re: Has anybody ran those Hughes rocker arms [Re: BPE] #1315012
10/04/12 09:57 PM
10/04/12 09:57 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I have not run them on anything yet,but would not hesitate to do so.
I looked them over at the M.M.race in Indy. I like the way they oil,better than many others I've seen. Plus the roller trunions on other brands require cutting too much meat out of them,all to put roller bearings on a part that just pivots and does not rotate.
Unless I was stepping up to T&D or something,they look pretty decent. Hughes makes their own now as opposed to out sourcing like years past.
Keith
Re: Has anybody ran those Hughes rocker arms [Re: Dunnuck Racing] #1315013
10/04/12 10:55 PM
10/04/12 10:55 PM
Portage,michigan
Portage,michigan
Do Jesel or T&D make standard head rocker gear
1.41 best 60 foot
6.56 at 104.17
Re: Has anybody ran those Hughes rocker arms #1315014
10/04/12 11:01 PM
10/04/12 11:01 PM
louisiana
71440dart Offline
71440dart  Offline
louisiana
NEVER AGAIN...
same thing here, horrible customer service, and quite a wise @$$ Dave is.
71 dodge dart race car,440/727 best so far: 11.23 @119 74 plymoth duster, 408SB/727
Re: Has anybody ran those Hughes rocker arms [Re: 71440dart] #1315015
10/04/12 11:14 PM
10/04/12 11:14 PM
Northern Indiana
Northern Indiana
I have such a hard time understanding how you guys have gotten poor customer service. I have used him a couple times and service wa awesome. A friend just ordered a cam kit,gave the wrong information and they shipped the correct one right away?
I called six different places about camshafts recently. Dave Hughes was the absolute best at asking the right questions and giving a good recommendation. Some of the other companies I called really just did not want to take the time to get things right. Some were good,some were not,but Dave was the best.
