Page 2 of 3 1 2 3
Re: GM metric rear disc conversion [Re: mopar65] #1313414
09/30/12 11:07 PM
09/30/12 11:07 PM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
no I sure dont.
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: GM metric rear disc conversion [Re: 440W8 Duster] #1313415
10/01/12 01:09 AM
10/01/12 01:09 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I used 93 jeep Cherokee rotors. You don't need a measurement to place the caliper bracket. Just bolt on the rotors put the pads in the calipers and bolt them to the brackets. Install them over the rotor and it helps if you have someone hold the brake pedal one you have them where you want them, this will square them up to the rotor. Then just tack the brackets on, remove everything and weld them up. Here's some pics from mine.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: GM metric rear disc conversion [Re: DemonDust] #1313416
10/01/12 05:26 AM
10/01/12 05:26 AM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
I used 93 jeep rotors. You don't need a measurement to place the caliper bracket. Just bolt on the rotors put the pads in the calipers and bolt them to the brackets. Install them over the rotor and it helps if you have someone hold the brake pedal one you have them where you want them, this will square them up to the rotor. Then just tack the brackets on, remove everything and weld them up. Here's some pics from mine.
I used the front rotors from a 2000 Grand Cherokee, Speedway brackets, Autozone calipers and pads. I drilled the rotors for 5/8" studs, mocked it up on the axle, and put shop air to the calipers to hold them in place while welding. My rear lines are flex lines that were also purchased along with the fittings from Speedway.
Randy
Re: GM metric rear disc conversion [Re: DemonDust] #1313417
10/01/12 05:38 PM
10/01/12 05:38 PM
Rome, Ga
sbhpcb Offline
sbhpcb  Offline
Rome, Ga
What about a parking brake?
Re: GM metric rear disc conversion [Re: sbhpcb] #1313418
10/01/12 05:51 PM
10/01/12 05:51 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
no parking brake with these calipers.
I'll also mention that a couple tabs for the hoses to clip on are a nice addition while you have the welder out...
Make sure you leave enough slack so the caliper can be removed from the rotor for pad replacement.
Re: GM metric rear disc conversion [Re: RodStRace] #1313419
10/01/12 06:22 PM
10/01/12 06:22 PM
dogdays Offline
dogdays  Offline
You put a cable-operated disc brake on the rear end pinion.
What I don't understand is why one wouldn't use a rear caliper with a disk brake provision?
R.
Re: GM metric rear disc conversion [Re: dogdays] #1313420
10/01/12 06:58 PM
10/01/12 06:58 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
thanks for all the ideals guys and how easy they are to set up.I am wanting to do this this way on my car because i don't need a park brake for my street/strip car. but if i was going to use a set up with a park brake. there is a guy over at FABO site that took the complete rear disc break set up off of a jeep. looked pretty easy to do.its is in the brakes section.
OK back to the gm disc conversion what did you guys do with the factory proptioning valve? i mean did you leave it be, bypass it or just remove it and add a adjustable one for the rear breaks. I already have a aluminum latter mod brake master cylinder. also the conversion brake line kits on found on ebay and speed way have kits that come with everything. like the little brackets that you weld to the axle, so you can mount the brake line.i think this is a very keep way to have disc breaks for the rear of your car.it will be a couple of weeks before i get all the parts bought and will put up some pics when i get it installed.going to have to hit up the parts store to see if i can fine the brake lines to build me a kit cheaper that what eBay or speedway is wanting.Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: GM metric rear disc conversion [Re: mopar65] #1313421
10/01/12 08:14 PM
10/01/12 08:14 PM
Dartin Offline
Dartin  Offline
I also didn't see the need for a parking brake on mine. As for the proportioning valve, I went with an adjustable one. There are a bunch of brands and styles out there in a variety of prices. Check out the ones speedway has while you are ordering up the brackets, lines, fittings, caliper bolts, clips, etc.... saves on shipping too!
Randy
Re: GM metric rear disc conversion [Re: Dartin] #1313422
10/01/12 08:50 PM
10/01/12 08:50 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
The only thing I got from speedway were the brackets. Everything else i got from Oreilly. Everything from O'Reilly cost less than $115 ( rotors, calipers, pads, hoses, banjo bolt)
When you buy the brackets just get the flat ones, I bought the gusseted first and they were a pita.
SDG Motorsports
Re: GM metric rear disc conversion [Re: DemonDust] #1313423
10/01/12 10:36 PM
10/01/12 10:36 PM
mopar65 Offline
mopar65  Offline
thanks that what i plan on doing. i already have all the parts and prices looked up on orielys web site. but on the hoses do you have a part number for them on what year make car etc you found the part number for the hose? also can you show a pic of how you mounted your break lines? thanks Mopar65
Re: GM metric rear disc conversion [Re: Dartin] #1313424
10/01/12 10:41 PM
10/01/12 10:41 PM
mopar65 Offline
mopar65  Offline
Randy
thanks for the info. i have used the adjustable one before on my 65 but that was with wildwood brakes front and back. so did you just plug the rear break line coming off the factory valve and run a new line from the master cylinder etc? Mopar65
Re: GM metric rear disc conversion [Re: mopar65] #1313425
10/01/12 11:21 PM
10/01/12 11:21 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
The part number is BH36847. I used a 79 Malibu for my reference.
My brake lines are the stock lines that ran to the cylinders, I just shortened them and reflared them so they worked with the flex hoses.
SDG Motorsports
Re: GM metric rear disc conversion [Re: mopar65] #1313426
10/02/12 05:21 AM
10/02/12 05:21 AM
Dartin Offline
Dartin  Offline
Randy
Yep, I plumbed the adjustable prop valve into the rear line coming from the master cylinder. For the lines I used the braided flex lines that Speedway sells. I didn't use banjo bolt type lines. They sell a fitting that adapts a flex line to the banjo thread size (can't remember the size off the top of my head though).
Randy
Re: GM metric rear disc conversion [Re: DemonDust] #1313427
10/21/12 04:30 AM
10/21/12 04:30 AM
Bellevue, NE
Charger453 Offline
Charger453  Offline
Bellevue, NE
Has anybody done a weight comparison when swapping from a set of 10" drums? Just curious if this sheds any weight as well.
Re: GM metric rear disc conversion [Re: Charger453] #1313428
10/21/12 02:28 PM
10/21/12 02:28 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Funny.... was just looking at Willwoods for the rear this am.
can't imagine alot of weight savings... factory calpers are usually not light weight.
Re: GM metric rear disc conversion [Re: J_BODY] #1313429
10/22/12 01:53 AM
10/22/12 01:53 AM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
I used a caliper for a s10 and a rotor for rear of 92 jeep got bracket from jegs
calipers were 10 bucks rotors were 40 pads were 12 bucks
for same price on the rotors can get them drilled and sloted off ebay (think was like (70.00)
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: GM metric rear disc conversion [Re: mopar65] #1313430
11/04/12 11:26 AM
11/04/12 11:26 AM
Fl. USA
PS Arrow Offline
PS Arrow  Offline
Fl. USA
I have not done the lines yet, but I am under $70.00.
Re: GM metric rear disc conversion [Re: 440W8 Duster] #1313431
04/23/13 07:46 PM
04/23/13 07:46 PM
MN
JERICOGTX Offline OP
MN
Jeff I used rotors from a Jeep Grand Cherokee with GM metric calipers and brakes from any circle track shop for the rear.
Sorry to bring up a old post, but Jesse, what is the difference in the brake pads from circle track, compared to a regular set of pads?
Jeff
Re: GM metric rear disc conversion [Re: JERICOGTX] #1313432
04/23/13 09:02 PM
04/23/13 09:02 PM
dogdays Offline
dogdays  Offline
That wasn't his point. The lower-cost circle track classes use a "metric GM" caliper. It may even be a requirement in some classes. Anyway, circle track stores should have them and pads out on the shelves so it's easy to just walk in and buy a pair. You don't need to wrestle with the parts guy's computer like you would at Autozone.
R.
Re: GM metric rear disc conversion [Re: dogdays] #1313433
04/23/13 09:05 PM
04/23/13 09:05 PM
MN
MN
R.
Jesse, is/was a parts counter guy, that is why I asked. If a simple set from the local parts store is the same for $13 I'll just pick them up, and run a spacer from Speedway.
Jeff
Page 2 of 3 1 2 3
