Ductile rocker contact patch issue #1312435
09/29/12 03:28 PM
09/29/12 03:28 PM
Colo
P
PJ68RT Offline OP
PJ68RT  Offline OP
P
Colo
See pic. The rockers are only toucing on the side of the valves. I tryed several and they all seem to only be touching the side. There's .002-.003 clearance on the side of the rocker that doesn't touch the valve. What you think? What can i do here? New rockers?
Re: Ductile rocker contact patch issue [Re: PJ68RT] #1312436
09/29/12 03:32 PM
09/29/12 03:32 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Pic no workie
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Ductile rocker contact patch issue [Re: MoparBilly] #1312437
09/29/12 03:44 PM
09/29/12 03:44 PM
Colo
P
PJ68RT Offline OP
PJ68RT  Offline OP
P
Colo
Here's another..
Re: Ductile rocker contact patch issue [Re: PJ68RT] #1312438
09/29/12 03:50 PM
09/29/12 03:50 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Are those isky rockers ? hard to tell where it's hitting the on the stem .
Re: Ductile rocker contact patch issue [Re: PJ68RT] #1312439
09/29/12 04:05 PM
09/29/12 04:05 PM
Az
Crizila Offline
Crizila  Offline
Az
You could have the pads refaced, but for 2-3 thou, I'd runem as is.
Fastest 300
Re: Ductile rocker contact patch issue [Re: JohnRR] #1312440
09/29/12 04:09 PM
09/29/12 04:09 PM
Colo
P
PJ68RT Offline OP
PJ68RT  Offline OP
P
Colo
They are Crane ductile rockers. In the second pic its a little easier to see that the contact sweep is right on the right edge of the valve.
Re: Ductile rocker contact patch issue [Re: PJ68RT] #1312441
09/29/12 04:12 PM
09/29/12 04:12 PM
Colo
P
PJ68RT Offline OP
PJ68RT  Offline OP
P
Colo
another pic...
Re: Ductile rocker contact patch issue [Re: PJ68RT] #1312442
09/29/12 07:51 PM
09/29/12 07:51 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
You need to add shims to get the proper positioning.
Take the rockers and shaft, insert 1 or 2 shims so to get each rocker centered over the respective valve stem. When doing this we suggest taking another head for trial fitting. And if needed a shim can be cut down by using the Dremel and sanding wheel. Add what ever shims (# and/or thickness) are needed for each rocker alignment. Also note that after layouting out the shaft, rockers and shims fit the shaft/rockers on the head and torque it down. Sometimes after torqueing down the shaft the # of required shims and/or thickness may need to be revised as the alignment can change after torque down..
Yes it takes some time to optimize but once done, the end-result will be worth it.
Just my $0.02..
Re: Ductile rocker contact patch issue [Re: PJ68RT] #1312443
09/29/12 09:04 PM
09/29/12 09:04 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i would get the pads resurfaced flat so they are contacting the whole valve stem. check ur scrub pattern after that. the way they are now will side load the valve.
Re: Ductile rocker contact patch issue [Re: rickraw] #1312444
09/30/12 03:33 PM
09/30/12 03:33 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
This, if you look at the first couple pictures the rocker isn't offset so far that the pad misses the valve, the pad just isn't parallel to the valve stem..
Re: Ductile rocker contact patch issue [Re: 1_WILD_RT] #1312445
09/30/12 04:14 PM
09/30/12 04:14 PM
Colo
P
PJ68RT Offline OP
PJ68RT  Offline OP
P
Colo
Thats correct. The pad is not parallel to the valve. Weird thing is they are all the same. Seems like they were all machined 2-3 thou out of parallel with the rocker shaft bore..ugg
Re: Ductile rocker contact patch issue [Re: PJ68RT] #1312446
09/30/12 05:54 PM
09/30/12 05:54 PM
New York
polyspheric Offline
polyspheric  Offline
New York
It's got to be fixed. Find an old auto shop with a Sioux or Quickway valve refacing machine, the fancy ones have rocker re-facing attachments that pilot off the shaft hole and restore the pad to parallel. RAS can do this if you don't have any locals.
Make sure the bushing is a good fit, or it won't really be fixed.
There are videos on Youtube of these tools in use on Ford Y blocks.
Boffin Emeritus
Re: Ductile rocker contact patch issue [Re: polyspheric] #1312447
09/30/12 06:16 PM
09/30/12 06:16 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I wish RAS was better at customer service/getting jobs out.. I've never heard a complaint about quality but I've heard & experienced the black hole of sending parts in & not getting them back for over two years...
Re: Ductile rocker contact patch issue [Re: 1_WILD_RT] #1312448
10/02/12 05:26 PM
10/02/12 05:26 PM
mckinney texas
shoebox Offline
shoebox  Offline
mckinney texas
I'm 12 months into my Ras nightmare. Never one phone call or email
Just what seem like sincere apologies when I can get Gary on the phone
74 dart sport 440 www.Csucarbs.com
Re: Ductile rocker contact patch issue [Re: shoebox] #1312449
10/02/12 05:34 PM
10/02/12 05:34 PM
JohnRR Offline
JohnRR  Offline
I'm glad now I paid a little extra and bought a set of ductiles redone by RAS off a member last/earlier this year ... Thanks Woody ...
Re: Ductile rocker contact patch issue [Re: PJ68RT] #1312450
10/02/12 05:34 PM
10/02/12 05:34 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
When I was using those rockers I had to cut the small tabs off the holddowns to get the pads properly positioned on the valve. Regardless,
you should be running a hardened shim between the holddown and the rocker or the softer iron rocker is going to wear and put a load of crap in the motor.
Re: Ductile rocker contact patch issue [Re: Stanton] #1312451
10/02/12 07:09 PM
10/02/12 07:09 PM
Colo
P
PJ68RT Offline OP
PJ68RT  Offline OP
P
Colo
I broke down and bought a set of Hughes rockers. Got my fingers crossed that my smithbros pushrods i used with the Ductiles will work with these new Hughes units.
Re: Ductile rocker contact patch issue [Re: PJ68RT] #1312452
10/02/12 07:26 PM
10/02/12 07:26 PM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
You can fix it yourself by using a knife-sharpening stone, some TLC and checking. Not difficult, and minimum cost. My
Re: Ductile rocker contact patch issue [Re: PJ68RT] #1312453
10/02/12 07:51 PM
10/02/12 07:51 PM
NEW HAMPSHIRE AND MAINE
BIGSTROKER Offline
BIGSTROKER  Offline
do a pattern with the spring your going to run,the lite springs dont have enough pressure to set the rocker
Re: Ductile rocker contact patch issue [Re: BIGSTROKER] #1312454
10/02/12 08:44 PM
10/02/12 08:44 PM
Colo
P
PJ68RT Offline OP
PJ68RT  Offline OP
P
Colo
I checked the pattern with the actual valve springs too. It is still on the edge. These were given to me about 10 years ago so i have nothing invested.
