Page 1 of 4 1 2 3 4
Down on Power #1312198
09/29/12 12:38 AM
09/29/12 12:38 AM
Winnipeg ,Mb. CA.
chryco Offline OP
chryco  Offline OP
Winnipeg ,Mb. CA.
I had the car out last weekend testing a new converter and really think my et and mph should have been better. My 2800# Dart with a 557" aluminum hemi
.750" lift cam , 12:1 comp, tweeked heads , Barton intake w/1150 , Dyno`d @ 875hp @7000 / 750ft.lbs @ 5200 ran 9.71 @ 139.4 . The car felt like it was running strong and seemed to launch OK with the new converter ( Neal Chance custom 9" 5400 stall )and trans brake 1.39 60' . I think there`s more , but where ???
Ideas thought?
Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Down on Power [Re: chryco] #1312199
09/29/12 12:55 AM
09/29/12 12:55 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
generally speaking MPH is horsepower and ET is chassis, you're slow across the board which indicates it's down on power. imho properly tuned that car should be in the 8's at >150. start from the bottom and go over everything. can you post a time card?
BTW nice car
Re: Down on Power [Re: jamesc] #1312200
09/29/12 01:10 AM
09/29/12 01:10 AM
Out West
408strokerdart Offline
Out West
BTW nice car
at 2900 lbs it should be well into the 8's.
Re: Down on Power [Re: jamesc] #1312201
09/29/12 01:11 AM
09/29/12 01:11 AM
Winnipeg ,Mb. CA.
chryco Offline OP
chryco  Offline OP
Winnipeg ,Mb. CA.
Dang ! I`ll get them posted up ASAP I think their still out in the car !!!!!!
Re: Down on Power [Re: chryco] #1312202
09/29/12 01:33 AM
09/29/12 01:33 AM
Winnipeg ,Mb. CA.
chryco Offline OP
chryco  Offline OP
Winnipeg ,Mb. CA.
Some more info :
4.10 Dana
J.W. 'Glide w/ brake ladder bars , axle floaters
2 1/4" x 4" Hookers w/ 12" collector extensions
BG 400 fuel pump #10 line to BG regs @9# c112 fuel
MSD 7AL and Pro Billet Dist set 35deg (locked)
Thanks Again !
Chryco
Re: Down on Power [Re: chryco] #1312203
09/29/12 01:39 AM
09/29/12 01:39 AM
Guitar Jones Online laugh2
You say you were testing a new converter, what did it run with the old one? My car weighs near 2800 pounds and I know I'm not making anywhere near 875 HP.
Re: Down on Power [Re: Guitar Jones] #1312204
09/29/12 06:33 AM
09/29/12 06:33 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
According to the wallace calc, your present speed suggest a 9.51 with a quicker 60 ft. Based on 875 hp and 2800#, you should be running high 8,50's at nearly 160 mph.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Down on Power [Re: deaks] #1312205
09/29/12 08:02 AM
09/29/12 08:02 AM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
Possible that the big tires, 4.10 gear, and glide are hurting your times? IMO you need more gear.
Re: Down on Power [Re: Guitar Jones] #1312206
09/29/12 08:09 AM
09/29/12 08:09 AM
Winnipeg ,Mb. CA.
chryco Offline OP
chryco  Offline OP
Winnipeg ,Mb. CA.
The old converter was in my opinion a screw up on the part of the manufacturer even though I gave them the complete list of specs , they sent me a 4600 stall 9" . My 60' went from 1.45 to 1.39 NOT what I`d expected BUT an improvement just the same.Last time out there was a lateral cross wind 35 - 40 mph and I ran the 9.71 The previous time out VERY humid and hot with the old converter I went 9.74 both at the same MPH 139. Which is why I thought I`d have had bigger gains with the new converter.
Thx
chryco
Re: Down on Power [Re: deaks] #1312207
09/29/12 08:25 AM
09/29/12 08:25 AM
Winnipeg ,Mb. CA.
chryco Offline OP
chryco  Offline OP
Winnipeg ,Mb. CA.
Mick
Exactly ! This thing sounds strong and seemingly runs like a top ? I haven`t altered anything since it came off of Barton`s dyno as far a timing or jetting . I`m at 750' elevation and am pretty sure it`s not that far off where RBRE is located.
New plugs and oil oil pressure`s fine . I`m going to pull the valve covers and hope for the best Sunday , I`ll bet my valve lash is OK though.
I`ll also leak it down too .
Chryco
Re: Down on Power [Re: chryco] #1312208
09/29/12 08:28 AM
09/29/12 08:28 AM
Winnipeg ,Mb. CA.
chryco Offline OP
chryco  Offline OP
Winnipeg ,Mb. CA.
Hey ! What about hood scoop to carb clearance? There`s probably 3" above the air horn to the scoop.
Again , there`s no miss or hint of actual power loss other than what the dyno results would suggest.
Chryco
Re: Down on Power [Re: chryco] #1312209
09/29/12 08:44 AM
09/29/12 08:44 AM
ill
dennismopar73 Offline
ill
I don't believe the dyno #s are correct!!
Running 9.70s, everyone says it should be a sec faster, that thing , if it is not laying down, misfiring, boogging ,blowing the tires off , and tuned way out , those dyno # are wrong,
Something amiss in the build of the motor!!
Get a leak down on the motor after it is hot!! see what the # tell you then
J M O
Re: Down on Power [Re: chryco] #1312210
09/29/12 08:45 AM
09/29/12 08:45 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Bet the tune in the carb is off a little...Try cleaning the air bleeds and such with a shot of carb cleaner...After that, I would be reading plugs.
Ooor, you can send the engine my way, and I will re-tune it for you. You can have it back next season.
Re: Down on Power [Re: Dragula] #1312211
09/29/12 09:17 AM
09/29/12 09:17 AM
Mt.Vernon IL
Twin Turbo Mower Offline
Mt.Vernon IL
Are the throttle blades open all the way when you have the pedal to the floor?
Re: Down on Power [Re: Twin Turbo Mower] #1312212
09/29/12 09:42 AM
09/29/12 09:42 AM
Roanoke Va
gearjammerdart Offline
Roanoke Va
^^^^ this is my first thought^^^^
69 Dart swinger 417 W8 Liberty 5 speed
6.03 @114/9.49 @141 on motor 5.30 @131 on juice 1/8th mile 28x10.5's at 3200lbs
70 Challenger RT 440 4-speed 4:10 Dana
http://www.youtube.com/watch?v=VowFy4nDdfI
Re: Down on Power [Re: chryco] #1312213
09/29/12 09:47 AM
09/29/12 09:47 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Chryco
I'd like to hear the tourque nunmbers at what RPM. Also where is your timing, rear gear, jetting and carb size? what RPM are you going through the traps? Head flow numbers would help. There's more there for sure but the combo needs to be right. I'll go back over your post to see if I missed anything, but it takes around 950HP to run 8's at sea level
Re: Down on Power [Re: camastomcat] #1312214
09/29/12 10:01 AM
09/29/12 10:01 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I would go with more stall like 5800-6000, less timing, like 32*, stock jetting 92's square and start there. Like one guy said, you may need a 456, but I think 8's are in your future with the right tune up.
Re: Down on Power [Re: dennismopar73] #1312215
09/29/12 10:16 AM
09/29/12 10:16 AM
Winnipeg ,Mb. CA.
chryco Offline OP
chryco  Offline OP
Winnipeg ,Mb. CA.
J M O [/quote
Here`s the sheet..........
Re: Down on Power [Re: gearjammerdart] #1312216
09/29/12 10:19 AM
09/29/12 10:19 AM
Winnipeg ,Mb. CA.
chryco Offline OP
chryco  Offline OP
Winnipeg ,Mb. CA.
Checked and re checked.......................
Re: Down on Power [Re: Dragula] #1312217
09/29/12 10:20 AM
09/29/12 10:20 AM
Winnipeg ,Mb. CA.
chryco Offline OP
chryco  Offline OP
Winnipeg ,Mb. CA.
Something tells me it`s not going to be that easy ............
Page 1 of 4 1 2 3 4
