Re: Changing Big Block oil filter ideas?
[Re: superbeejim]
#1311360
09/27/12 09:53 AM
09/27/12 09:53 AM
Posts: 2,806 Northern NJ
StukaJU87
Northern NJ
A piece of tin foil draped and shaped to guide the oil away from the k frame and into the drain pan.
Scott
1969 Super Bee, 383/4 speed
[Re: superbeejim]
#1311361
09/27/12 09:53 AM
09/27/12 09:53 AM
Posts: 4,576 Motor City
6PKRTSE
Motor City
I just use a rag on the K frame & pull out after I put the new filter on. Still sometimes makes a little mess.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#1311362
09/27/12 10:02 AM
09/27/12 10:02 AM
Posts: 632 Casco, MI
Savoy1964
Casco, MI
Took a triangle shaped sheet metal added a lip on the back side and curved it a little. Place under filter with smaller end pointed into drain pan and undo filter.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph 2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
[Re: topside]
#1311368
09/27/12 09:44 PM
09/27/12 09:44 PM
Posts: 12,239 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I just use several layers of newspapers pushed back to the motor mount bracket. It usually catches all the oil. The only trick is to not spill the oil while pulling the newspaper out.
Master, again and still
[Re: 6PKRTSE]
#1311370
09/27/12 10:07 PM
09/27/12 10:07 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
me too,
[Re: Kern Dog]
#1311373
09/27/12 11:01 PM
09/27/12 11:01 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Does anyone here have the guts to admit that they used to pull the drain plug and let the oil just drain into a freshly dug hole??
ive done that when i was real young but i would never do it now.
[Re: RapidRobert]
#1311375
09/28/12 12:06 AM
09/28/12 12:06 AM
Posts: 43,282 Bend,OR USA
Cab_Burge
[Re: 69L78Nova]
#1311378
09/28/12 12:13 AM
09/28/12 12:13 AM
Posts: 902 Seattle, WA
rss
Seattle, WA
Why not? I've got myself a nice hole in the corner of the yard where all of my oil, ATF, gear oil and coolant goes. I'm not a hippie environmentalist. What worked 30+ years ago, works today
Hopefully you and the neighbors are on city water.
