69 roadrunner trunk weather striping #1311192
09/26/12 07:46 PM
09/26/12 07:46 PM
Florida,Plantation
Tyson Offline OP
Tyson  Offline OP
Florida,Plantation
Which is the correct way to install the trunk weather striping on a 69 roadrunner? Does anybody have a picture of what it's supposed to look like?
Re: 69 roadrunner trunk weather striping [Re: Tyson] #1311193
09/27/12 04:13 AM
09/27/12 04:13 AM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
Get your part from Soffseal. They have the best material. Their part is soft enough to provide a good seal but also allow your trunk lid to shut properly. Get a tube of 3M weatherstrip adhesive. Lay down a thin strip of seal starting to the left of center using your trunk latch as a reference. Lay down maybe a foot of 3M weatherstrip adhesive. Lay your seal down, and secure with fingers while the adhesive tacks up. Takes a couple minutes. Don't put to much seal on to where it splooges out the sides. Lay down another foot or so of adhesive and keep going. Do the whole thing in small increments. Do the corners seperately as they are a bit tougher to keep the seal in place while it sets. Keep going until you have come full circle. Once you are to the end, cut the seal about 1/4 inch beyond you starting point so that it butts nicely when finished. Lay down your last bit of seal and put a small dab on the end of the seal itself. Place it carefully into position let it set for a bit and you are done.
Re: 69 roadrunner trunk weather striping [Re: 70mopes] #1311194
09/27/12 08:29 AM
09/27/12 08:29 AM
Florida,Plantation
Tyson Offline OP
Tyson  Offline OP
Florida,Plantation
Thank you, very helpful!!!
Re: 69 roadrunner trunk weather striping [Re: Tyson] #1311195
09/27/12 10:03 AM
09/27/12 10:03 AM
Utah
E
Eagleone1983 Offline
E
Utah
I've also heard of people using clothes pins to hold the seal while it tacks up and dries so you don't have to sit there holding it your self.
Re: 69 roadrunner trunk weather striping [Re: Eagleone1983] #1311196
09/27/12 10:48 AM
09/27/12 10:48 AM
WV
JohnH Offline
JohnH  Offline
WV
I bought sever plastic clips from harbor frieght to hold the seal in place, and remover them as I went along and glued it in placed, then put the clip back in place after I glued it so I wouldn't pull it lose where I glued it, and remover them after a few hours, be careful just a small amount of glue or it will come out of the sides, and make your cut at the ends after you are done..
