Re: Sleeper going to T&T tomorrow. What will it run?!?
[Re: dvw]
#1310725
09/27/12 12:47 AM
09/27/12 12:47 AM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Well... couldn't be happier with my results from the first time out with the car. Had a few issues, but nothing major. I have the boost controller wiring screwed up, so I couldn't get it to initialize into the launch mode. Hence only running it at 8psi all night. Also, had a bad connection at the trans brake button that wasted a few passes. Once I got that fixed, I just kept adding RPM to the starting line, and it kept going quicker and quicker every pass. It's pulling 1 degree of timing for every pound of boost, and it's only got 30 degree's in it to start. So basically a real conservative 8psi / 22 degree, tune up. The car is SOOOOOOO easy to drive. As mentioned, it's in first gear FOREVER. Shifts at 5500 rpm, crosses the stripe at like 5200. As smooth of a 10 second pass as you could ever dream of. I was really hoping it would dip into the 10's, but I never thought it would do it at such low boost. Can't wait to see what it'll do turned up, and with even more RPM/Boost/Timing on the launch. ![](/ubbthreads/images/graemlins/boogie.gif) I'll get some video posted up for you guys tomorrow.
[Re: RobX4406]
#1310729
09/27/12 09:26 AM
09/27/12 09:26 AM
Posts: 52,972 Romeo MI
MR_P_BODY
That's so cool... still looks better than most GM 4 doors! LOL But I like the looks of a 70 Coronet.
It's not real quick in the first 1/8. I'm thinking it's lagging ~.2+ there.
I was close on the MPH, didn't think it would go that well et wise.
Great going for the first time out, sorting out bugs and all.
I'm sure the 2.76 gear is the problem in the first half of the track ... the 3.23 or a bit steeper would help get it rolling... but that 2.76 sure is loaded to give the turbo some heat... you should have heard the 3.23 gear that he bought used.... that thing was SCARY BAD... when he gave me a ride I was really wondering if we would make it back to my house ![](/ubbthreads/images/graemlins/wave.gif)
[Re: dizuster]
#1310730
09/27/12 09:42 AM
09/27/12 09:42 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Mr. Yuck. Do you want mustard or catsup with that crow?
Still at Milan. 5th pass, Zero boost launch, 11.30 @ 122 so far on only 8psi. Time to turn up the launch and the boost.
More later.
good running! I'm glad I was wrong. Don't blow it up.
[Re: Mr.Yuck]
#1310732
09/27/12 10:00 AM
09/27/12 10:00 AM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
This thing had been dynoed and made like 470 at the rear tires, so doing the math not like is real accurate is making around 600+.
470 at the rear wheels is not 600+ HP otherwise I'd be over 600. I just don't see it in that build sorry. It's a very cool car and I hope it runs great. I just don't see 11's. Boost is boost S/C or turbo'd. The gear is going to hurt a bunch. and again I'm not sure how the converter is going to act w/ the boost and the lazy gear. It's like dropping the hammer at 5k in a pedal car w/ a highway gear, the rpms are going to sink way down, when that happens the boost will drop. I'd think it would run a ton better w/ a 3800 stall and 3.55's. I have a buddy that runs 8's at 160+ in a turbo SB. He runs a 4000 stall and 3.73 gears...and that thing has a 700+ lift cam. But hey prove me and a few others wrong and go put up the numbers.
I also have a friend small c.i. chevy twin turbo small block, small cam .3.00 gears super tight converter and last time to the track it ran 8.67 letting off around the 1000 ft mark. It used to have a stock short block cast crank rods with forged pistons and at low boost it went 10.20's.
67' charger 499 RB
10.57 at 127
[Re: Mr.Yuck]
#1310733
09/27/12 10:06 AM
09/27/12 10:06 AM
MR_P_BODY
More later.
Yuck... isnt your car pressurized(boost) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#1310734
09/27/12 10:18 AM
09/27/12 10:18 AM
Mr.Yuck
Brookeville, Md
More later.
old one was, this one is just a 11:1 6-pack 440. Next one is going to be a 500ci wedge w/ 8-10lbs of boost. Boost is the way to go for sure. Especailly if you drive the car and from the track like me. I'm just not sure if I want to go turbo or centrif supercharger.
[Re: Mr.Yuck]
#1310736
09/27/12 10:24 AM
09/27/12 10:24 AM
Posts: 1,019 Finland
mafo
Finland
wow, I know turbos work, but 10 s with that gear ![](/ubbthreads/images/graemlins/beer.gif)
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: Twostick]
#1310739
09/27/12 01:58 PM
09/27/12 01:58 PM
dragram440
bigfork mn
Lots of mph with gears like that.
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#1310740
09/27/12 02:19 PM
09/27/12 02:19 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Planning on bringing it out again anytime soon? I'd love to check it out, and perhaps pick your brain a little ![](/ubbthreads/images/graemlins/thumbs.gif)
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: OUTLAWD]
#1310741
09/27/12 02:30 PM
09/27/12 02:30 PM
dizuster
Oakland, MI
I don't think the converter is all that far off with the gear. Maybe a few hundred, but certainly not 1000. You have to remember that if it only stalled 3500 or so under boost, that would have to be down around 2000rpm without boost. It would never spool the turbo at the line. With the low gear needs it to flash up to near the peak torque to use it up to make the car move. I'm not so sure the 2.76 gear is killing it all that much. It's not spinning the tires yet, so it'll take more torque (ie. boost). And if it spins with more boost, then the 3.23 gear was only gonna make it spin anyway. Plus it doesn't really want to pull much more then 5500 anyway. Already crossing the stripe at 5200~5300. A little more HP/MPH and it'll be right where it wants to be. BTW... there is no way that it's going in the 9's at 123mph. Maybe 10.80's if it continues to hook as I turn up the RPM/Boost on the launch. It will definately go in the low 10's with the boost turned up some more though. No doubt about that. I am actually moving to my new house in a week and a half, so I was lucky my wife was nice enough to let me run it yesterday... lol Maybe after the move towards the end of October I'll get it out again. Feel free to PM me with any questions. Amazing what a little boost will do isn't it? ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: Sleeper going to T&T tomorrow. (WITH RESULTS!)
[Re: dustergirl340]
#1310743
09/27/12 03:06 PM
09/27/12 03:06 PM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
That thing has DRAG WEEK written all over it.
68 Barracuda Formula S 340
