Page 3 of 5 1 2 3 4 5
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: dvw] #1310724
09/27/12 12:39 AM
09/27/12 12:39 AM
In the tower
RonTheAnnouncer Offline
In the tower
The kid let me make the last pass of the night.
60 1.6923
330 4.5902
660 [Email]7.0379@100.05[/Email]
1000 9.1752
1320 [Email]10.996@123.65[/Email]
Lots left,I would venture low tens if the traction stays decent. It stays in 1st gear forever. Thought I missed the shift light. Best comment of the night came from the starting line guy at Milan. "Why did you guys turbo the worlds ugliest car?" I told him because he wanted a fast ugly car.
Doug
That's scootin' and very cool! Love to see a pic of it!
Ron H.
"Just when you think you have all of the answers...I change the questions!" "Rowdy" Roddy Piper
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: dvw] #1310725
09/27/12 12:47 AM
09/27/12 12:47 AM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Well... couldn't be happier with my results from the first time out with the car. Had a few issues, but nothing major.
I have the boost controller wiring screwed up, so I couldn't get it to initialize into the launch mode. Hence only running it at 8psi all night.
Also, had a bad connection at the trans brake button that wasted a few passes.
Once I got that fixed, I just kept adding RPM to the starting line, and it kept going quicker and quicker every pass.
It's pulling 1 degree of timing for every pound of boost, and it's only got 30 degree's in it to start. So basically a real conservative 8psi / 22 degree, tune up.
The car is SOOOOOOO easy to drive. As mentioned, it's in first gear FOREVER. Shifts at 5500 rpm, crosses the stripe at like 5200. As smooth of a 10 second pass as you could ever dream of.
I was really hoping it would dip into the 10's, but I never thought it would do it at such low boost. Can't wait to see what it'll do turned up, and with even more RPM/Boost/Timing on the launch.
I'll get some video posted up for you guys tomorrow.
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: dizuster] #1310726
09/27/12 12:48 AM
09/27/12 12:48 AM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: dizuster] #1310727
09/27/12 01:25 AM
09/27/12 01:25 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
That's so cool... still looks better than most GM 4 doors! LOL But I like the looks of a 70 Coronet.
It's not real quick in the first 1/8. I'm thinking it's lagging ~.2+ there.
I was close on the MPH, didn't think it would go that well et wise.
Great going for the first time out, sorting out bugs and all.
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: RobX4406] #1310728
09/27/12 06:20 AM
09/27/12 06:20 AM
Clinton Township, Michigan
Dartin Offline
Dartin  Offline
That is awesome! Nice numbers too! Glad things went relatively smooth for you. Do I see a "No ET" at Milan in the future???lol
Randy
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: RobX4406] #1310729
09/27/12 09:26 AM
09/27/12 09:26 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm sure the 2.76 gear is the problem in the first
half of the track ... the 3.23 or a bit steeper would
help get it rolling... but that 2.76 sure is loaded
to give the turbo some heat... you should have heard
the 3.23 gear that he bought used.... that thing was
SCARY BAD... when he gave me a ride I was really
wondering if we would make it back to my house
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: dizuster] #1310730
09/27/12 09:42 AM
09/27/12 09:42 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Mr. Yuck. Do you want mustard or catsup with that crow?
Still at Milan. 5th pass, Zero boost launch, 11.30 @ 122 so far on only 8psi. Time to turn up the launch and the boost.
More later.
good running! I'm glad I was wrong. Don't blow it up.
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: MR_P_BODY] #1310731
09/27/12 09:46 AM
09/27/12 09:46 AM
sweden
sshemi Offline
sshemi  Offline
sweden
Super cool!!!
Whats the specs on the engine?
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: Mr.Yuck] #1310732
09/27/12 10:00 AM
09/27/12 10:00 AM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
This thing had been dynoed and made like 470 at the rear tires, so doing the math not like is real accurate is making around 600+.
470 at the rear wheels is not 600+ HP otherwise I'd be over 600. I just don't see it in that build sorry. It's a very cool car and I hope it runs great. I just don't see 11's. Boost is boost S/C or turbo'd. The gear is going to hurt a bunch. and again I'm not sure how the converter is going to act w/ the boost and the lazy gear. It's like dropping the hammer at 5k in a pedal car w/ a highway gear, the rpms are going to sink way down, when that happens the boost will drop. I'd think it would run a ton better w/ a 3800 stall and 3.55's. I have a buddy that runs 8's at 160+ in a turbo SB. He runs a 4000 stall and 3.73 gears...and that thing has a 700+ lift cam.
But hey prove me and a few others wrong and go put up the numbers.
I also have a friend small c.i. chevy twin turbo small block, small cam .3.00 gears super tight converter and last time to the track it ran 8.67 letting off around the 1000 ft mark. It used to have a stock short block cast crank rods with forged pistons and at low boost it went 10.20's.
67' charger 499 RB 10.57 at 127
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: Mr.Yuck] #1310733
09/27/12 10:06 AM
09/27/12 10:06 AM
MR_P_BODY Offline
MR_P_BODY  Offline
More later.
Yuck... isnt your car pressurized(boost)
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: MR_P_BODY] #1310734
09/27/12 10:18 AM
09/27/12 10:18 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
More later.
old one was, this one is just a 11:1 6-pack 440. Next one is going to be a 500ci wedge w/ 8-10lbs of boost. Boost is the way to go for sure. Especailly if you drive the car and from the track like me. I'm just not sure if I want to go turbo or centrif supercharger.
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: Mr.Yuck] #1310735
09/27/12 10:22 AM
09/27/12 10:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Ok... cause I know you have commented on boost
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: Mr.Yuck] #1310736
09/27/12 10:24 AM
09/27/12 10:24 AM
Finland
mafo Offline
mafo  Offline
Finland
wow, I know turbos work, but 10 s with that gear
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: dizuster] #1310737
09/27/12 12:07 PM
09/27/12 12:07 PM
In the tower
In the tower
No one in the world would guess that runs high 10s...so far! I love that, my new 2nd favorite car on Moparts!
Ron H.
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: mafo] #1310738
09/27/12 01:55 PM
09/27/12 01:55 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Which IMHO proves converter is more important than gear as has been posted here in the past. I think if the converter was tightened up 1000-1200 rpm when he turns up the boost, it will be the ugliest 9 sec car in the world with a 2.76 gear.
Kevin
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: Twostick] #1310739
09/27/12 01:58 PM
09/27/12 01:58 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
Lots of mph with gears like that.
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: dragram440] #1310740
09/27/12 02:19 PM
09/27/12 02:19 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Planning on bringing it out again anytime soon?
I'd love to check it out, and perhaps pick your brain a little
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Sleeper going to T&T tomorrow. What will it run?!? [Re: OUTLAWD] #1310741
09/27/12 02:30 PM
09/27/12 02:30 PM
Oakland, MI
dizuster Offline OP
dizuster  Offline OP
Oakland, MI
I don't think the converter is all that far off with the gear. Maybe a few hundred, but certainly not 1000.
You have to remember that if it only stalled 3500 or so under boost, that would have to be down around 2000rpm without boost. It would never spool the turbo at the line.
With the low gear needs it to flash up to near the peak torque to use it up to make the car move.
I'm not so sure the 2.76 gear is killing it all that much. It's not spinning the tires yet, so it'll take more torque (ie. boost). And if it spins with more boost, then the 3.23 gear was only gonna make it spin anyway. Plus it doesn't really want to pull much more then 5500 anyway. Already crossing the stripe at 5200~5300. A little more HP/MPH and it'll be right where it wants to be.
BTW... there is no way that it's going in the 9's at 123mph. Maybe 10.80's if it continues to hook as I turn up the RPM/Boost on the launch. It will definately go in the low 10's with the boost turned up some more though. No doubt about that.
I am actually moving to my new house in a week and a half, so I was lucky my wife was nice enough to let me run it yesterday... lol Maybe after the move towards the end of October I'll get it out again.
Feel free to PM me with any questions.
Amazing what a little boost will do isn't it?
Re: Sleeper going to T&T tomorrow. (WITH RESULTS!) [Re: dizuster] #1310742
09/27/12 02:50 PM
09/27/12 02:50 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Nice numbers, I like ugly fast cars. Congrats!
Re: Sleeper going to T&T tomorrow. (WITH RESULTS!) [Re: dustergirl340] #1310743
09/27/12 03:06 PM
09/27/12 03:06 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
That thing has DRAG WEEK written all over it.
68 Barracuda Formula S 340
