jetting 3705 (750) carters on a Vanke Intake #1309560
09/23/12 10:30 PM
09/23/12 10:30 PM
WI
ThunderLugs Offline OP
WI
Does anyone have jetting and metering rod specs for 3705 (750) carters, on a Vanke Intake? 426 is Running race gas, 557 cam, headers, and 11.5-1. Need a solid starting point. This is more for street use, and not so much the track. Thanks
Re: jetting 3705 (750) carters on a Vanke Intake [Re: ThunderLugs] #1309561
09/23/12 11:21 PM
09/23/12 11:21 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
The best way is to start off with stock jetting and do some real world test and tune work on your combo (dyno, track runs, etc.). Anyone telling you they can "set up" carburetors to offer best/max performance for any particular custom engine/chassis combo is blowing smoke.
*Since the older 3 step rods and jets are obsolete I'd reccomend buying new Edelbrock strip kits and swap all of them over to the new style 2 step rods and jets so you can have a nice selection of available tuning parts. www.walkerproducts.com sells them and can offer you cross reference info to match the old numbers to the new ones (which are different).
Re: jetting 3705 (750) carters on a Vanke Intake [Re: ScottSmith_Harms] #1309562
09/24/12 08:45 AM
09/24/12 08:45 AM
WI
WI
Thank You Sir.
Re: jetting 3705 (750) carters on a Vanke Intake [Re: ThunderLugs] #1309563
09/24/12 09:38 AM
09/24/12 09:38 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
left carb primary jet throttle side is .110, other side .107. secondary jet throttle side is .092, other side .065. 16-76 metering rod (.066-.053), 2 step rod.
right carb primary jet throttle side is .107, other side .107. secondary jet throttle side is .089, other side .065. 16-76 metering rod (.066-.053), 2 step rod.
Re: jetting 3705 (750) carters on a Vanke Intake [Re: lewtot184] #1309564
09/24/12 12:32 PM
09/24/12 12:32 PM
WI
WI
The carbs are front to rear. Which ones are your left and right? Which side of the car are you standing on? Thanks
Re: jetting 3705 (750) carters on a Vanke Intake [Re: ThunderLugs] #1309565
09/24/12 04:08 PM
09/24/12 04:08 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
right carb would be passenger side, left would be driver side. the opposite of standing in front of the engine looking back towards the firewall. of course this assumes your running cross ram carbs on a cross ram intake.
Re: jetting 3705 (750) carters on a Vanke Intake [Re: lewtot184] #1309566
09/24/12 04:26 PM
09/24/12 04:26 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
If the carbs are front to back, Is the driver's side the front of the car or is the passenger side the front of the car?
I'm fairly confident his engine is still in a longitudinal position.
- Stu Harmon
Re: jetting 3705 (750) carters on a Vanke Intake [Re: ThunderLugs] #1309567
09/24/12 04:59 PM
09/24/12 04:59 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The factory used to offer a rejetting kit specifically for the Vanke mod, I swear I saved the info but still looking.
Re: jetting 3705 (750) carters on a Vanke Intake [Re: John_Kunkel] #1309568
09/24/12 05:43 PM
09/24/12 05:43 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes they did, however they were not 3705 (early 64 Cross Ram Hemi or Max Wedge application) carbs, not to mention that they spec'd them for 30-40 year old engine technology.
Re: jetting 3705 (750) carters on a Vanke Intake [Re: John_Kunkel] #1309569
09/24/12 08:58 PM
09/24/12 08:58 PM
WI
WI
Thank You John. I will gladly look at all info that comes my way! All of it is Valuable,regardless of its vintage. Scotts points are are very well taken , given his incredible Expertise, and experience as being one of the best! I welcome your info, if you should find it. Time to go watch the Packers Beat Up on the Seahawks.....I think that might be Scotts Team?. Thanks! Tom
Re: jetting 3705 (750) carters on a Vanke Intake [Re: ThunderLugs] #1309570
09/24/12 10:05 PM
09/24/12 10:05 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
It's all good, I'm a Niners fan followed closely by Oakland (yea I know...... )
Re: jetting 3705 (750) carters on a Vanke Intake [Re: ScottSmith_Harms] #1309571
09/25/12 03:16 AM
09/25/12 03:16 AM
State of Fascism
52savoy Offline
52savoy  Offline
State of Fascism
A lot of difference between 3705 carbs and St Hemis... but anyhow, here is the sheet.
I should add... I ran my carbs this way using .600 to .700 lift cams without touching the carbs any farther.
Re: jetting 3705 (750) carters on a Vanke Intake [Re: 52savoy] #1309572
09/25/12 08:58 AM
09/25/12 08:58 AM
WI
WI
Thanks for the info! And your point is well taken. Information like this is Priceless..Thank You
Re: jetting 3705 (750) carters on a Vanke Intake [Re: ScottSmith_Harms] #1309573
09/25/12 09:05 AM
09/25/12 09:05 AM
WI
WI
How about those replacement officials??.... Bagdad Bob made more believable calls during the war!! NFL Fans World Wide, and Packer Nation Has Had ENOUGH!!!
