complete exhaust systems #1309200
09/23/12 09:36 AM
09/23/12 09:36 AM
Spring Mount, PA
MOPAULY Offline OP
MOPAULY  Offline OP
Spring Mount, PA
Any specific vendors to look at? I need to add full exhaust from the manifolds back on my 68 Charger this winter and need a complete system....something that fits and doesn't require me beating the hell out of it would be nice.
Re: complete exhaust systems [Re: MOPAULY] #1309201
09/23/12 10:15 AM
09/23/12 10:15 AM
near New Haven, CT
fireeng Offline
fireeng  Offline
near New Haven, CT
Accurate exhaust. It's not cheap but the system bolted right on to my 71 challenger, looks stock and sounds awesome.
2016 Diesel Ram 3500 Mason Dump
1971 Challenger
2013 Jeep Wrangler
1979 Dodge Ram Power Wagon 400 Mini Pumper
My other car is a Fire Truck.
Re: complete exhaust systems [Re: MOPAULY] #1309202
09/23/12 10:57 AM
09/23/12 10:57 AM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Pypes Exhaust, just up the road a bit.
Re: complete exhaust systems [Re: fireeng] #1309203
09/23/12 01:05 PM
09/23/12 01:05 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Re: complete exhaust systems [Re: dart4forte] #1309204
09/23/12 04:28 PM
09/23/12 04:28 PM
Minnesota
72blubird Offline
72blubird  Offline
Minnesota
I have manifolds and upgraded to tti went to 2 1/2 inch with H-pipe. It bolted up great although the brackets are different than stock. Overall I am very happy and have had my system for probably close to 10 years on the road runner still sounds and performs great.
What was I thinking....
Re: complete exhaust systems [Re: MOPAULY] #1309205
09/23/12 04:59 PM
09/23/12 04:59 PM
MO, USA
Tom Hand Offline
Tom Hand  Offline
MO, USA
Contact Waldron's and ask for Ruth and check into their systems. They make nice fitting ones that will not kill your pocket book.
WaldronsExhaust.com.
Tom
Re: complete exhaust systems [Re: 72blubird] #1309206
09/23/12 05:02 PM
09/23/12 05:02 PM
Franklin CT
syleng1 Offline
syleng1  Offline
Franklin CT
Just my 2cents worth:
On the 340 Demon I have a 2.5" H-pipe TTI system and even thought it is awsome, I need to change the mufflers for a drowning noise while at low rpm (2k rpm specifically) in 4th gear. It's not the systems fault I probably need more gearing I run a 3.23 rear gear now. Good ground clearance and neat clean bends. After 5 years it still look awsome. Also I am running factory exhaust manifolds. Very helpful when deciding on what part to use.
On the /6 66 Barracuda automatic I went Accurate and went with the upgraded diameter. Not only does it look awsome but nobody knows is not factory. Quiet and clean.
Both systems are awsome. Good luck.
Joe
Re: complete exhaust systems [Re: Tom Hand] #1309207
09/23/12 09:18 PM
09/23/12 09:18 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Tom
Joe is by far one of the nicest guys you will ever deal with!!
Here's another fantastic option, but not cheap...
http://www.gardnerexhaust.com/1968-moparb-body-exhaust-system.html
Admiration For Multiple Carburetor Vehicles...
Re: complete exhaust systems [Re: Stewpar] #1309208
09/24/12 01:33 AM
09/24/12 01:33 AM
Florida, US
72ls5fla Offline
72ls5fla  Offline
Florida, US
Just an FYI -
I purchased Eric Gardener's exhaust for my 70 Challenger -
BEST thing ever. Perfect fit, finish and sound!
Also I previously purchased exhaust from him for my 67 435HP Vette and 72 454 Vette. Same quality and received around 90% of the NCRS judging points - anyone that know NCRS , its says a whole hell of alot about the exhaust.
Bill
Got me a NEW Project
1970 GTX 440+6, 4 spd, 4.10 Dana and N96 FE5 (top/bottom) and black bucket interior.
Original transmission and Dana - Engine is a service replacement block.
Body has all stamped #s + VIN/TRIM tag and door sticker. Been hunting like all hell to find the Build Sheet.
garage find, only had 41,850 miles on ODO.
Re: complete exhaust systems [Re: 72ls5fla] #1309209
09/24/12 04:42 PM
09/24/12 04:42 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
APPARENTLY GARDNER only does 440 and 426 e bodies?
Re: complete exhaust systems [Re: 05dakota] #1309210
09/24/12 08:37 PM
09/24/12 08:37 PM
Spring Mount, PA
MOPAULY Offline OP
MOPAULY  Offline OP
Spring Mount, PA
Thanks guys ill check em all out
Re: complete exhaust systems [Re: MOPAULY] #1309211
09/25/12 10:36 AM
09/25/12 10:36 AM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
I'm pretty sure I've seen a Gardner add with an F8 A12 SuperBee...FWIW a friend of mine bought a setup from Gardner for his 70 GS Stage 1 Buick - went on with zero issues at all - it was perfect - my next door neighbor did a TTI setup on his 68 Charger R/T - also - no issues at all - Gardners had the crimps in all the right places (I guess) looks loke OE, TTI obviously aftermarket with smooth radius bends for performance - never have seen Accurate in person, I'd think would be like Gardner OE look
Re: complete exhaust systems [Re: 05dakota] #1309212
09/25/12 10:26 PM
09/25/12 10:26 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
Nope, click on the link I posted previously......
Re: complete exhaust systems [Re: Stewpar] #1309213
09/26/12 06:03 PM
09/26/12 06:03 PM
Spring Mount, PA
MOPAULY Offline OP
MOPAULY  Offline OP
Spring Mount, PA
Waldrons may end up being the best bet...accurate looks nice but yes expensive (unless they have sales), pypes website scares the hell out of me and is tough to navigate the sales page.
