Re: Hang an A833 behind a 3rd Gen Hemi?
[Re: Daty Rogers]
#1307235
09/20/12 08:34 AM
09/20/12 08:34 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
You can do it. They have the same pattern as a small lock LA/magnum engine. QuickTime makes a blow proof bell that uses a 130 tooth flywheel to install the 833.
**Photobucket sucks**
[Re: Pale_Roader]
#1307237
09/20/12 09:42 AM
09/20/12 09:42 AM
Posts: 75,092 A Banana Republic near you.
JohnRR
The question is why???
You can bolt a modern, useful manual transmission to that engine. Why go backwards?
Maybe he is doing it in a car that he doesn't want to hack the floor pan on to fit a modern option to , or he is going to buy a Passon 5 speed ?
[Re: Pale_Roader]
#1307238
09/20/12 11:12 AM
09/20/12 11:12 AM
Posts: 12,481 Chino Valley
RodStRace
Chino Valley
Using what he has is the short answer. I asked him that too. At this point, he's exploring options. This car is second or third in line in his projects. He's got a done '70 Hemi Cuda clone, a 5.7L Hemi Jeep with full aftermarket steering, suspension, axles and transfer, 2 '68 Darts to be done (one will be 5.7L, the other 426) and an A-100 PU. His dad is putting finishing touches on a '65 Coronet injected Hemi and has a '70 Challenger 5.7L Hemi in the paint shop. A lot of this is being done with stuff they have collected over the years and while the finished cars are very nice, they are NOT checkbook cars. They BUILD them.
[Re: astjp2]
#1307242
09/20/12 01:13 PM
09/20/12 01:13 PM
RodStRace
Chino Valley
The jeep started out as a burn salvage. They got a wrecked 4X4 hemi ram and built the Jeep up from the frame. Painted the body in the back yard. Hung the engine/trans/transfer with bought engine mounts, although they have the ability and tools to fab them. Wired the whole thing using the truck harness adapted to fit, including the cluster and computer. Fuel system, brake pedal, steering mount, throttle, transfer shifter all needed modification. As pictured before he added the new transfer, axles and suspension, he probably had less than 7K in it. It hauls and crawls. Yes, they know the EFI stuff, some through hard knocks. They also put together a 3rd gen Hemi Honcho for another guy. The son's wife drives a 65 Dart with a full EFI 360 magnum swap connected to a push-button 904. I'm proud to know them both. The question was to ensure that what they had found before with autos also applied to stick stuff on the 3rd gen hemis. They asked me and I asked here.
[Re: 70Cuda383]
#1307244
09/20/12 10:05 PM
09/20/12 10:05 PM
moparpollack
Lil Herman
Lil Herman
85086
A stock bell housing from a 69 340 car will work also. Mopar sells a hemi specific flywheel that Mancini racing sells.
[Re: Pale_Roader]
#1307245
09/21/12 12:27 AM
09/21/12 12:27 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
Well, I hate to tell you this but you are fired for being non-constructive and arrogant in too many posts. You sir, have been placed on the ignore list.
[Re: kz5rt2]
#1307247
12/20/14 04:09 PM
12/20/14 04:09 PM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
https://board.moparts.org/ubbthreads/show...e=0&fpart=1I did it. It wasn't a step back for me. I'm only out the cost of a clutch when I decide to swap to something wth more years. The 5.7/6.1 uses such a small cam in a stock shortblock format that it can push 2.76 gears with a 1:1 top gear with ease. I wouldn't run more than. 3.23 with a short tire on any stock transmission swap.
