Re: New Worst! Kaboom!
[Re: Dragula]
#1306152
09/18/12 10:29 AM
09/18/12 10:29 AM
Posts: 1,178 Indy
FlyFish
Indy
YEEEOW!! That's some serious carnage...sooo sorry for you loss.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: Dragula]
#1306153
09/18/12 10:30 AM
09/18/12 10:30 AM
dartman366
Mt. Vernon, Ohio
looking at that was painful enough to make a grown man cry. ![](/ubbthreads/images/graemlins/bawling.gif) sorry about the carnage, glad you and the car are undamaged.
[Re: Mr.Yuck]
#1306154
09/18/12 10:31 AM
09/18/12 10:31 AM
Triple Threat
Renton Washington
I kinda know how your piston looks w/o seeing it.
If you look at the last picture of parts on the paper tower left to right it it, Piston, pushrods, lifters, cam and pieces of the block.
[Re: Dragula]
#1306155
09/18/12 10:33 AM
09/18/12 10:33 AM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
That is a bummer of the first magnitude. Glad it didn't wind up worse , but in spite of confining the damage to inside the motor , that is plenty ugly. Ouch ! ![](/ubbthreads/images/graemlins/eeek.gif)
[Re: SCATPACK 1]
#1306164
09/18/12 12:14 PM
09/18/12 12:14 PM
Posts: 864 St Paul MN
73swinger
St Paul MN
Sorry to see that, OUCH! Glad you are OK.
Chris Schwartz
73 Swinger 340 12.451 @ 108.78
73 Gold Duster, needs a plan.
[Re: Jeremiah]
#1306165
09/18/12 12:16 PM
09/18/12 12:16 PM
Triple Threat
Renton Washington
Could a broken valve spring cause that chain of events to begin?
The springs (Comp) and retainer (Comp tool steel?) both look fine, Need to check the pressure on it. So far found I have found 1 of the 2 keepers, other is probably in the bottom of the pan or something, I haven't spent too much time looking around.
At this point I think the entire short block is a write off. The crank was already 10/10 so I doubt it will clean up. I don't remember what series valve it was off the top of my head, it wasn't top tier but it wasn't bottom shelf either. I don't think the valve is to blame, but I could be wrong. I had a ton of P to V clearance.
I'm pretty sure the head can be fixed/saved, but wont know for sure until I take it off. At this point I'm thinking about switching to a big block or maybe 3G Hemi. If anybody has anything feel free to PM me.
I'm wearing all black today...
[Re: Triple Threat]
#1306166
09/18/12 12:54 PM
09/18/12 12:54 PM
Posts: 11,688 W. Kentucky
justinp61
W. Kentucky
Is the stem straight? What was the open pressure of the springs?
[Re: Triple Threat]
#1306167
09/18/12 12:58 PM
09/18/12 12:58 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
Did it turn a bearing and cause the rod to break or break a rod bolt? Could be something else but most times that's what happens.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
