New Worst! Kaboom! UPDATE X2 Added pictures of Head
#1306132
09/18/12 03:29 AM
09/18/12 03:29 AM
Triple Threat
Renton Washington
Saturday in the semi's as I grabbed second gear the car laid over, shook pretty violently, made some real bad noises and died. Pulled off the side of the track, not leaking anything, steam coming out of my tail pipe. Went back to the pits pulled the plugs, #2 wasn't gonna come out, that's not good, lets pull the valve cover. Here is what I found Manley valve stem .....continued
Re: New Worst! Kaboom!
[Re: Triple Threat]
#1306133
09/18/12 03:31 AM
09/18/12 03:31 AM
Triple Threat
Renton Washington
brought the car home and after work today pushed it in the garage and pulled the intake off....
[Re: Triple Threat]
#1306138
09/18/12 03:45 AM
09/18/12 03:45 AM
Triple Threat
Renton Washington
Here is a the history of the car/engine. All new this season. https://board.moparts.org/ubbthreads/showflat.php?Cat=&Board=Racer&Number=7258607Trying to find a high point to all of this; I'm thankful the carnage stayed internal and that the car or myself weren't hurt. My wallet on the other hand The cause is TBD, Had about 150 runs on it, always had good oil pressure. It wont turn over in either direction (shocking) and its still in the car so I can't pull the pan. I snapped the pictures and walked away for the night. I will probably work on it again tomorrow and get ready to pull it out of the car. See if the heads can be fixed ETC.
[Re: Triple Threat]
#1306140
09/18/12 04:28 AM
09/18/12 04:28 AM
Posts: 43,230 Bend,OR USA
Cab_Burge
Dustin, I'm really sorry to see that kind of carnage, it is FUBARED I've broke some parts over the years but nothing like yours is, broken valve heads in Hemi motors, rolled rod bearings over and ended up breaking the rods, had a forged OEM M.W. piston come apart(bottom of piston broke off at the wrist pin, major carnage) about 100 ft. from the finish line at Pomona in 1984 Winternationals, not a good day ) Yours looks a lot worse Let us know what you find, sometimes it is easy to find the root cause and sometimes it isn't easy at all Good luck Glad your not hurt and the car isn't bent
[Re: rebel]
#1306142
09/18/12 07:41 AM
09/18/12 07:41 AM
Posts: 1,019 Finland
mafo
Finland
feel your pain mate, been there, done that. time to get the missus a second job so you can get this fixed asap.
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: mafo]
#1306143
09/18/12 08:17 AM
09/18/12 08:17 AM
Posts: 3,210 robin hood country
deaks
robin hood country
Sorry to see the carnage, keep us posted on what you find. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Triple Threat]
#1306146
09/18/12 09:06 AM
09/18/12 09:06 AM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Looking at those makes me feel ill. That sucks on many levels.
"Just a Bracket car dressed up like a streetcar"
