Page 1 of 6 1 2 3 4 5 6
New Worst! Kaboom! UPDATE X2 Added pictures of Head #1306132
09/18/12 03:29 AM
09/18/12 03:29 AM
Renton Washington
Triple Threat Offline OP
Renton Washington
Saturday in the semi's as I grabbed second gear the car laid over, shook pretty violently, made some real bad noises and died. Pulled off the side of the track, not leaking anything, steam coming out of my tail pipe. Went back to the pits pulled the plugs, #2 wasn't gonna come out, that's not good, lets pull the valve cover. Here is what I found Manley valve stem .....continued
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: New Worst! Kaboom! [Re: Triple Threat] #1306133
09/18/12 03:31 AM
09/18/12 03:31 AM
Renton Washington
Renton Washington
brought the car home and after work today pushed it in the garage and pulled the intake off....
-Dustin
Re: New Worst! Kaboom! [Re: Triple Threat] #1306134
09/18/12 03:34 AM
09/18/12 03:34 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Re: New Worst! Kaboom! [Re: Triple Threat] #1306135
09/18/12 03:34 AM
09/18/12 03:34 AM
Renton Washington
Renton Washington
Re: New Worst! Kaboom! [Re: Triple Threat] #1306136
09/18/12 03:36 AM
09/18/12 03:36 AM
Renton Washington
Renton Washington
-Dustin
Re: New Worst! Kaboom! [Re: Triple Threat] #1306137
09/18/12 03:37 AM
09/18/12 03:37 AM
Renton Washington
Renton Washington
Re: New Worst! Kaboom! [Re: Triple Threat] #1306138
09/18/12 03:45 AM
09/18/12 03:45 AM
Renton Washington
Renton Washington
Here is a the history of the car/engine. All new this season.
https://board.moparts.org/ubbthreads/showflat.php?Cat=&Board=Racer&Number=7258607
Trying to find a high point to all of this; I'm thankful the carnage stayed internal and that the car or myself weren't hurt. My wallet on the other hand
The cause is TBD, Had about 150 runs on it, always had good oil pressure. It wont turn over in either direction (shocking) and its still in the car so I can't pull the pan. I snapped the pictures and walked away for the night. I will probably work on it again tomorrow and get ready to pull it out of the car. See if the heads can be fixed ETC.
-Dustin
Re: New Worst! Kaboom! [Re: Triple Threat] #1306139
09/18/12 04:21 AM
09/18/12 04:21 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
agh crapola
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: New Worst! Kaboom! [Re: Triple Threat] #1306140
09/18/12 04:28 AM
09/18/12 04:28 AM
Dustin, I'm really sorry to see that kind of carnage, it is FUBARED I've broke some parts over the years but nothing like yours is, broken valve heads in Hemi motors, rolled rod bearings over and ended up breaking the rods, had a forged OEM M.W. piston come apart(bottom of piston broke off at the wrist pin, major carnage) about 100 ft. from the finish line at Pomona in 1984 Winternationals, not a good day ) Yours looks a lot worse Let us know what you find, sometimes it is easy to find the root cause and sometimes it isn't easy at all Good luck Glad your not hurt and the car isn't bent
Re: New Worst! Kaboom! [Re: Cab_Burge] #1306141
09/18/12 05:33 AM
09/18/12 05:33 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
feel your pain mate, been there, done that. time to get the missus a second job so you can get this fixed asap.
Re: New Worst! Kaboom! [Re: rebel] #1306142
09/18/12 07:41 AM
09/18/12 07:41 AM
Finland
mafo Offline
mafo  Offline
Finland
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: New Worst! Kaboom! [Re: mafo] #1306143
09/18/12 08:17 AM
09/18/12 08:17 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Sorry to see the carnage, keep us posted on what you find.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: New Worst! Kaboom! [Re: Triple Threat] #1306144
09/18/12 08:28 AM
09/18/12 08:28 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Major BUMMER
Re: New Worst! Kaboom! [Re: Triple Threat] #1306145
09/18/12 08:46 AM
09/18/12 08:46 AM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
that sucks
Re: New Worst! Kaboom! [Re: Triple Threat] #1306146
09/18/12 09:06 AM
09/18/12 09:06 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Looking at those makes me feel ill. That sucks on many levels.
"Just a Bracket car dressed up like a streetcar"
Re: New Worst! Kaboom! [Re: Triple Threat] #1306147
09/18/12 09:17 AM
09/18/12 09:17 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Wow that looks not so good. At least you weren't at the big end at max speed. I kinda know how your piston looks w/o seeing it.
Coming soon!!!!
Re: New Worst! Kaboom! [Re: Triple Threat] #1306148
09/18/12 09:24 AM
09/18/12 09:24 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Sorry to see that! So???
Bigger Better faster???
Re: New Worst! Kaboom! [Re: Dodgem] #1306149
09/18/12 09:47 AM
09/18/12 09:47 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Real sorry to see that happen...
when the time comes, i have some spare parts leftover from my 430 build I can send your way - if that helps
Re: New Worst! Kaboom! [Re: Dodgem] #1306150
09/18/12 09:49 AM
09/18/12 09:49 AM
gregsdart Offline
gregsdart  Offline
Bummer! May the recovery time be short and less costly than it looks.
Re: New Worst! Kaboom! [Re: gregsdart] #1306151
09/18/12 09:57 AM
09/18/12 09:57 AM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
X2
Ouch!
