Largest 15" tire on a 65 A body?
#1305999
09/17/12 10:28 PM
09/17/12 10:28 PM
Posts: 2,048 N.E.Ohio
Polarabill
N.E.Ohio
I have a line on some 15" wheels in the small bolt pattern. The car currently has some worn out 13" tires on steel rims and I would like to upgrade.Any one know the largest tire I can put under this car with out causing steering woes or tire rubs?
This would be so much easier if I knew what I was doing...
Re: Largest 15" tire on a 65 A body?
[Re: Polarabill]
#1306003
09/18/12 11:01 AM
09/18/12 11:01 AM
RapidRobert
15's will very likely be too large of tire diameter in the front but maybe a very low profile 15" er would clear. See how much clearance you have now in the front with the 13's then check the dia of some low profile 15's. Rears would be fine as said with the correct width/offset. Unless you go with special tires those rims will not work for you
