I have a line on some 15" wheels in the small bolt pattern. The car currently has some worn out 13" tires on steel rims and I would like to upgrade.Any one know the largest tire I can put under this car with out causing steering woes or tire rubs?
This would be so much easier if I knew what I was doing...
