Roll bar main hoop question #1304342
09/15/12 06:15 PM
09/15/12 06:15 PM
Champion City
The Sphinx Offline OP
Champion City
Is it better to weld the main hoop to the 6X6 plates or would it be better to just run a 2X3 brace from the subframe connecter to the rocker panel and weld the hoop to. Subframe connecters come through the floor as would the 2X3 brace. My main worry is that the floor pan (its rust free) is about as thick as a common Miller light beer can.
Re: Roll bar main hoop question [Re: The Sphinx] #1304343
09/15/12 10:48 PM
09/15/12 10:48 PM
Roanoke Va
gearjammerdart Offline
Roanoke Va
You can use 2x2 1/8" wall from the sub frame connector to the rocker but make sure you plate the rocker. I use the 6x6 1/8" plate cut down to fit.
69 Dart swinger 417 W8 Liberty 5 speed
6.03 @114/9.49 @141 on motor 5.30 @131 on juice 1/8th mile 28x10.5's at 3200lbs
70 Challenger RT 440 4-speed 4:10 Dana
http://www.youtube.com/watch?v=VowFy4nDdfI
Re: Roll bar main hoop question [Re: The Sphinx] #1304344
09/15/12 11:47 PM
09/15/12 11:47 PM
Locomotion Offline
Locomotion  Offline
Unless you are already planning it, it will help chassis stiffness if you run "inboard" bars behind the seats from the main hoop/crossbar junction to the frame connectors as well.
Re: Roll bar main hoop question [Re: Locomotion] #1304345
09/16/12 09:57 AM
09/16/12 09:57 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep
Re: Roll bar main hoop question [Re: gearjammerdart] #1304346
09/16/12 06:43 PM
09/16/12 06:43 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Yep simply welding to the rocker is OK with mild steel but, better to plate and weld plate to the rocker with MIG. Then especially if using 1 5/8 moly tube you can TIG the support member to the plate. I like using round tube for this and do not weld any portion of the cage or support members to the car until everything is welded all the way around. Then simply put everything back in the permament position and crying about welds you can't make you can leave to people who know no better.
Leon
