Wildwoods and OEM master cylinder??
#1302449
09/11/12 11:24 PM
09/11/12 11:24 PM
Posts: 454 Ashville, Manitoba, Canada
superbeeman69
super street
super street
I'm curious here....I want to run wilwoods dynalite front disc brake kit on my dart, PN 140-11023 but the kit doesn't come with the master cylinder. Seeing as I want my engine bay to look like a stock 68 Super stock car, can I use an original (the correct one for 68 SS cars) manual disc master cylinder with no problems? Or do i need a wilwood master? This may be a simple question but I want to double check. Chrysler PN on the master is 2823576. Thanks in advance! Evan
1970 FM3 Coronet 440, 1971 FJ6 Dude D100
Re: Wildwoods and OEM master cylinder??
[Re: DAYCLONA]
#1302451
09/12/12 04:07 PM
09/12/12 04:07 PM
superbeeman69
super street
super street
They will be the wilwood 4 piston calipers that come with the kit. My dart is a /6 car so I assume I have 9inch spindles. Wilwood offers kits for 9 or 10 inch drum spindles...I can use mine right? No need to upgrade to 10in? I can't see any benefit to larger spindles..
[Re: superbeeman69]
#1302452
09/12/12 04:23 PM
09/12/12 04:23 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
You need the size of the caliper pistons and the bore of the master cylinder. If they match you're good.
[Re: superbeeman69]
#1302454
09/13/12 07:06 AM
09/13/12 07:06 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Why dont you call Wilwood? Im sure they have a tech line..
I am truckless..
[Re: superbeeman69]
#1302457
09/13/12 01:11 PM
09/13/12 01:11 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
By my understanding, a master cylinder with 1.75 bore would be extremely hard to push.
He meant "match up" as in, they go together, not as in "they are the same size" a 1.75" bore master operating calipers with 1.75" bore cylinders will be impossible to create enough line pressure to stop the car.
like feets said, look at some of the other posts about brakes to learn about master bore sizes and caliper bore sizes.
I'm running viper calipers on all 4 corners with 42mm bore and a 38mm bore pistons. combined piston area is 3.90 square inches. my master cylinder is a 1 1/8" bore, or about .99 square inches.
I'm also running a power booster so pedal effort is about zero
However, in the thread about "how warm should discs be" I thought maybe I was lightly dragging a brake caliper(s) and in troubleshooting, disconnected the power booster.
pedal effort was noticeable, but not impossible. I could still stop the truck pretty easily. I would think that with a 1" master cylinder for manual brakes would be perfect for my combo.
anyway...find out how big the pistons are in the caliper you are going to be using.
**Photobucket sucks**
